NVIDIA drive time clock jump back
Dear @tingguang.wang1,
Also, please select target hardware DRIVE AGX Xavier/pegasus to install require cross compilation setup on host. You can choose skip flashing later when asked.
I tried on installations. Before I can select to skip flashing target, I just need to power on the drive platform,correct?
Howerver, there is some error logs like
“unable to acquire the dpkg fronted lock…
Fingerprint was not found”
Should I just continue on my crosscompling trials or it is necessary to fix those errors even to flash the target before next step?
Please fix the host environment. Under target components, except Flash option everything should have marked green in UI.
