NVIDIA Drive - Unable to access the third camera
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to access three camera through json file and it is throwing an error…
./sample_camera --rig=/usr/local/driveworks/data/samples/sensors/camera/camera/rig2.json
[29-09-2023 09:21:22] Platform: Detected DDPX - Tegra A
[29-09-2023 09:21:22] TimeSource: monotonic epoch time offset is 1695967337769573
[29-09-2023 09:21:22] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[29-09-2023 09:21:22] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[29-09-2023 09:21:22] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[29-09-2023 09:21:22] Platform: number of GPU devices detected 1
[29-09-2023 09:21:22] Platform: currently selected GPU device integrated ID 0
[29-09-2023 09:21:22] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/bin/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/bin/data/[.pak]’
[29-09-2023 09:21:22] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/bin/…/data
[29-09-2023 09:21:22] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/bin/…/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/bin/…/data/[.pak]’
[29-09-2023 09:21:22] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/data
[29-09-2023 09:21:22] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/data/[.pak]’
[29-09-2023 09:21:22] SDK: No resources(.pak) mounted, some modules will not function properly
[29-09-2023 09:21:22] SDK: Create NvMediaDevice
[29-09-2023 09:21:22] SDK: Create NvMedia2D
[29-09-2023 09:21:22] SDK: use EGL display as provided
[29-09-2023 09:21:22] TimeSource: monotonic epoch time offset is 1695967337769572
[29-09-2023 09:21:22] Initialize DriveWorks SDK v4.0.0
[29-09-2023 09:21:22] Release build with GNU 7.3.1 from no-gitversion-build against Drive PDK v5.2.6.0
[29-09-2023 09:21:22] Rig::fromFile: Loading rig file: /usr/local/driveworks/data/samples/sensors/camera/camera/rig2.json
[29-09-2023 09:21:22] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[29-09-2023 09:21:22] Driveworks exception thrown: DW_FILE_INVALID: JsonInputArchive: fail to parse json
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2023-09-29 09:21:22] DW Error DW_FILE_INVALID executing DW function:
dwRig_initializeFromFile(&rigConfig, m_context, getArgument(“rig”).c_str())
at samples/sensors/camera/camera/main.cpp:212
Aborted (core dumped)
rig2.txt (3.2 KB)
Dear @siva.ariram,
Could you check connecting SF3324 camera at link1 as well.
In the process of testing nvsipl, I lost my display by ‘Sudo pkill X’, Now I am trying to get back the display
Xavier B is working fine, but the problem is with Xavier A, I can able to access it through SSH but not sure whether it is Xavier A or B.
Could you please provide a solution for this? Do I need to reflash the board ? is that the only solution?
Dear @siva.ariram,
Please reboot the target using aurix or hard reboot. eth0:200 interface IP can tell Xavier A/B. 10.42.0.28/29 denotes Xavier A/B.
Could you please file a seperate topic for display issue with details. This helps to provide better support for each topic
Back to the camera access error…I have tried with link 0 and 1, still the same error
I solved the display issue by reflashing the board.
rig_log.txt (14.0 KB)
@SivaRamaKrishnaNV I have uploaded the error file in here, I tried with link 1 and 0, but the third camera is not showing up. The file is working with Two cameras (SF3324 and SF3325)
Note: It is visualizing SF3324 and SF3325, even if I give both the camera name as SF3324.
Dear @siva.ariram,
Could you keep same camera type in one camera group. You can connect 2 SF3324 cameras to one port and connect other SF3325 to another camera group.
We have only one camera group cable with us!
Dear @siva.ariram,
using different camera module with a single camera group is not supported.
Thank you! Please let me know where can I find these camera group connectors. It is difficult to find them from nvidia shop!
Please reach out to your NVIDIA representative. He/she can assist you in sourcing these connectors effectively.
