I used the following commands to install
sudo add-apt-repository ppa:graphics-drivers
sudo apt-get update
sudo apt-get install nvidia-384
Installation appears fine with no errors, but I don’t see any NVIDIA folder under /dev.
When I run smi,
nvidia-smi
modprobe: ERROR: could not insert ‘nvidia_384’: No such device
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
How do I correctly install the latest NVIDIA driver correctly?
are you referring to the driver NVIDIA-Linux-x86_64-384.90.run?
I have the same problem.
I am trying to install the driver for a NVIDIA Quadro M4000 8GB on Ubuntu 16.04.
have you tried installing the driver in a complete non-gui mode?
https://askubuntu.com/questions/378046/how-to-run-ubuntu-xubuntu-in-a-complete-non-gui-mode
I found this video to be very helpful.
Install Nvidia Driver on Ubuntu 16.04 (GUI Method for Beginners)
@naruto.uzamaki7thhokage
What is the return of lspci? Does it list Nvidia GPU hardware?
You may use different driver installation methods that include installation from .deb or .run.
I am just wondering if you have managed to resolve the issue.
