I loaded nvidia module and restarted the system, the nvidia module closes the port, then it’s not openable again!
netstat -na | grep 6000
{returns nothing - the port is no longer listening and services needing it no longer working}
So, is there some settings for the nvidia module related to this? Actually, even nvidia driver itself requires DisallowTCP=false (allowing tcp connection on port 6000) so Genlock can work!
The GDM setting DisallowTCP=false just starts Xorg with “-listen tcp”, the nvidia driver doesn’t have any influence on that. Did you check you’re still running an Xsession when the nvidia module is loaded or a Wayland session? ps a |grep X
Thanks for pointing this out… Actually I was not running wayland, but by troubleshooting and trying multiple options between Xorg, and wayland, I found what causes the problem, when gdm detects nvidia gpu, it applies some rules to force using X, it seems that there was something wrong when these rules are applied!!
I disabled these rules, and I selected X11 manually (although this was my default), but now when gdm rules are disabled, the problem is resolved.
