Version 440.59 3.2.2020 now is succesfully installed.
Thank you!
![](https://global.discourse-cdn.com/nvidia/optimized/3X/3/1/3197daf5565c6657f1af4758d2a9b3178181cfa5_2_64x64.jpeg)
NVIDIA 440.64 - Kernel 5.6 ($1945940) Ā· Snippets Ā· GitLab
GitLab.com
Thank you!
Thereās a change from fops to proc_ops in the latest git linux 5.5.0 and nvidia drivers no longer compile. Any patch for that?
Thanks,
Jeff
Version 440.59 3.2.2020 for linux 5.6.0-rc1 not installed too
As in, youāre unable to build the driver on 5.6-rc1? In that case, Iāve had a go at making a patch a few days ago:
fwiw, here the patched verion BUILDS ok ā just fails (non-fatally) on run,
Thank you! patch is work for 5.6-rc1
Hi Isaak,
Thanks so much for your work! I came across your patch in this thread and it has worked flawlessly for me. Keep up the good work, much appreciated!
This worked great for 5.6-rc2 but not for 5.6-rc3. It compiles but X will not start. Using Kubuntu 19.10 with Nvidia RTX-2080 mobile (not Max-Q).
Hi, error with new build
ERROR: Failed to run /usr/sbin/dkms build -m nvidia -v 440.64 -k 5.6.0-050600rc5-generic
Kernel preparation unnecessary for this kernel. Skippingā¦
Building module:
cleaning build area...
'make' -j16 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=5.6.0-050600rc5-generic IGNORE_CC_MISMATCH='' modules....(bad exit
status: 2)
ERROR (dkms apport): binary package for nvidia: 440.64 not found
Error! Bad return status for module build on kernel: 5.6.0-050600rc5-generic (x86_64)
Consult /var/lib/dkms/nvidia/440.64/build/make.log for more information.
But Version 440.59 and patch is worked
Kernel preparation unnecessary for this kernel. Skippingā¦Building module: cleaning build area... 'make' -j16 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=5.6.0-050600rc5-generic IGNORE_CC_MISMATCH='' modules....(bad exit status: 2) ERROR (dkms apport): binary package for nvidia: 440.64 not found Error! Bad return status for module build on kernel: 5.6.0-050600rc5-generic (x86_64) Consult /var/lib/dkms/nvidia/440.64/build/make.log for more information.
While NVIDIA fixed that specific part in 440.59, the rest of the issues remains and you still need a patch for 440.64. The old one wonāt work, however, you need to either remove the ioremap_nocache part of it, or use the new one Iāve already posted on GitLab, here:
GitLab.com
sealse:
Thats cool man, thanks a ton, finally i can use kernel-5.6 :D
Ive successfully patched 440.64 and its working, im excited^^
Thanks again, the patch is still working with 440.66.02 .
