Ubuntu 16.04 Server edition, Cuda 10.0 installed with the local deb like: “sudo apt install cuda-10-0”
Have I done something wrong or might this be an upstream bug? The driver works fine on the old 410 kernel, just won’t build against the new kernel.
Output of install command:
Adding new group `nvidia-persistenced' (GID 122) ... [31/545]
Adding new user `nvidia-persistenced' (UID 113) with group `nvidia-persistenced' ...
Not creating home directory `/'.
Loading new nvidia-410-410.48 DKMS files...
First Installation: checking all kernels...
Building for 4.4.0-142-generic and 4.4.0-170-generic
Building for architecture x86_64
Building initial module for 4.4.0-142-generic
Secure Boot not enabled on this system.
Done.
nvidia_410:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/4.4.0-142-generic/updates/dkms/
nvidia_410_modeset.ko:
- Original module
- Installation
nvidia_410_drm.ko:
- Original module
- Installation
nvidia_410_uvm.ko:
- Original module
- Installation
depmod....
DKMS: install completed.
Building initial module for 4.4.0-170-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-410.0.crash'
Error! Bad return status for module build on kernel: 4.4.0-170-generic (x86_64)
Consult /var/lib/dkms/nvidia-410/410.48/build/make.log for more information.
Setting up nvidia-410-dev (410.48-0ubuntu1) ...
Setting up libcuda1-410 (410.48-0ubuntu1) ...
Setting up nvidia-opencl-icd-410 (410.48-0ubuntu1) ...
Setting up nvidia-modprobe (410.48-0ubuntu1) ...
Setting up nvidia-settings (410.48-0ubuntu1) ...
Setting up cuda-drivers (410.48-1) ...
Setting up cuda-runtime-10-0 (10.0.130-1) ...
Setting up cuda-demo-suite-10-0 (10.0.130-1) ...
Setting up cuda-10-0 (10.0.130-1) ...
Setting up nvidia-prime (0.8.2) ...
Processing triggers for libc-bin (2.23-0ubuntu11) ...
Processing triggers for initramfs-tools (0.122ubuntu8.16) ...
update-initramfs: Generating /boot/initrd.img-4.4.0-170-generic
Processing triggers for ureadahead (0.100.0-19.1) ...
Contents of /var/lib/dkms/nvidia-410/410.48/build/make.log
In file included from /var/lib/dkms/nvidia-410/410.48/build/common/inc/nv-linux.h:21:0,
from /var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.c:15:
/var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.c: In function ‘os_lock_user_pages’:
/var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.c:120:48: warning: passing argument 6 of ‘get_user_pages’ makes pointer from integer without a cast [-Wint-conversion]
page_count, write, force, user_pages, NULL);
/var/lib/dkms/nvidia-410/410.48/build/common/inc/nv-mm.h:44:70: note: in definition of macro ‘NV_GET_USER_PAGES’
get_user_pages(current, current->mm, start, nr_pages, write, force, pages, vmas)
In file included from /var/lib/dkms/nvidia-410/410.48/build/common/inc/nv-pgprot.h:17:0,
from /var/lib/dkms/nvidia-410/410.48/build/common/inc/nv-linux.h:20,
include/linux/mm.h:1256:6: note: expected ‘struct page **’ but argument is of type ‘NvBool {aka unsigned char}’
long get_user_pages(struct task_struct *tsk, struct mm_struct *mm,
/var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.c:120:55: warning: passing argument 7 of ‘get_user_pages’ from incompatible pointer type [-Wincompatible-pointer-types]
/var/lib/dkms/nvidia-410/410.48/build/common/inc/nv-mm.h:44:77: note: in definition of macro ‘NV_GET_USER_PAGES’
include/linux/mm.h:1256:6: note: expected ‘struct vm_area_struct **’ but argument is of type ‘struct page **’
/var/lib/dkms/nvidia-410/410.48/build/common/inc/nv-mm.h:44:9: error: too many arguments to function ‘get_user_pages’
/var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.c:119:11: note: in expansion of macro ‘NV_GET_USER_PAGES’
ret = NV_GET_USER_PAGES((unsigned long)address,
include/linux/mm.h:1256:6: note: declared here
scripts/Makefile.build:285: recipe for target '/var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.o' failed
make[2]: *** [/var/lib/dkms/nvidia-410/410.48/build/nvidia/os-mlock.o] Error 1
make[2]: *** Waiting for unfinished jobs....
Makefile:1460: recipe for target '_module_/var/lib/dkms/nvidia-410/410.48/build' failed
make[1]: *** [_module_/var/lib/dkms/nvidia-410/410.48/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.4.0-170-generic'
Makefile:79: recipe for target 'modules' failed
make: *** [modules] Error 2
