Nvidia driver with GTX 650 and arch linux. refusing more than 1024x768 [solved]
Hello pals. I’m a folding at home fan, but, since last month, when I own my GTX 650Ti I’m not so happy.
Let’s go
  • Driver: NVIDIA-Linux-x86_64-319.49-custom Distro: arch linux 64-bits, systemd, with kernel 3.10.10-1-ARCH
Other drivers i’ve tried: 326 beta, 319 stock (directly from installer, without “–add-this-kernel”)
314-XX (from official repositories of arch linux)
Any experience with nvidia drivers on linux? yes, on my 9500GT (XFX brand) with ubuntu 7. Any ok…
Issue.
If I make a xorg.conf with “nvidia-xconfig” (root) I only ups X with 640x480 or less.
Without Xorg.conf, up to 1024. but not with 1440x900, but no folding (don’t detects the GPU)
solution to folding: /etc/X11/xorg.conf.d/nvidia.conf with the contents
Section "Device"
  Identifier "nvidia"
  Driver     "nvidia"
  BusID      "PCI:1:0:0"
EndSection
grub options
nomodeset rdblacklist=nouveau noapic clocksource=hpet
Any of these options have you tried without? Yes, rdblacklist, noapic, nomodeset
but, doesn’t matter what I do… I can’t looks 1440x900. It’s go until 1024x768. Screen is a Samsung SyncMaster 920LM
On windows, everything ok, including 3D stereo, what means, everything ok with the GPU
Let’s see bugreport
____________________________________________
Start of NVIDIA bug report log file.  Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
nvidia-bug-report.sh Version: 15313852
Date: Sun Sep  1 16:24:03 BRT 2013
uname: Linux arch-o-ilkyest 3.10.10-1-ARCH #1 SMP PREEMPT Fri Aug 30 11:30:06 CEST 2013 x86_64 GNU/Linux
command line flags:
What may I do?
Same posts I did on arch linux forums, but nothing else
https://bbs.archlinux.org/viewtopic.php?pid=1316149#p1316149
Another thing I’ve seen now…
On installer, module’s installer, from AUR, there’s this command
gzip "${pkgdir}/usr/lib/modules/${_extramodules}/nvidia.ko"
With
pkgver=325.15
_extramodules=extramodules-3.10-lqx
_kernver="$(cat /usr/lib/modules/${_extramodules}/version)"
pkgrel=1
pkgdesc="NVIDIA drivers for linux-lqx."
arch=('i686' 'x86_64')
url="http://www.nvidia.com/"
depends=('linux-lqx>=3.10' 'linux-lqx<3.11' "nvidia-utils=${pkgver}")
But, on “kernel source folder” there’s not this “nvidia.ko”
Use gzip to extract the bug report as I was informed by a dev on my thread the bug reported uses gzip segments and does not extract properly with some archive programs so use gzip at your console and it should show the full bug report.
[code]____________________________________________
or by sending email to ‘linux-bugs@nvidia.com’.
Date: Mon Sep 2 18:03:55 BRT 2013
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 20 2013-05-31 15:40:23.000000000 -0300 /etc/issue
Arch Linux \r (\l)
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 5067 2013-09-01 14:01:46.525590546 -0300 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Sun Sep 1 14:01:00 2013
installer version: 319.49
PATH: /usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/core_perl
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
WARNING: Skipping the runlevel check (the utility runlevel failed to run).
-> License accepted.
-> Installing NVIDIA driver version 319.49.
-> There appears to already be a driver installed on your system (version: 319.49). As part of installing this driver (version: 319.49), the existing driver will be uninstalled. Are you sure you want to continue? (‘no’ will abort installation) (Answer: Yes)
-> A precompiled kernel interface for kernel ‘Linux 3.10.10-1-ARCH #1 SMP PREEMPT Fri Aug 30 11:30:06 CEST 2013 x86_64’ has been found here: ./kernel/precompiled/precompiled-nv-linux.o-319.49.1378054791.
executing: ‘cd ./kernel; /usr/bin/ld -d -r -o nvidia.ko precompiled-nv-linux.o nv-kernel.o’…
-> Kernel module linked successfully.
-> Unable to determine if Secure Boot is enabled: No such file or directory
-> Kernel messages:
[ 16.411678] WARNING! power/level is deprecated; use power/control instead
[ 16.635251] usblp 7-3:1.0: usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3D17
[ 16.635316] usbcore: registered new interface driver usblp
[ 16.767377] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: data=ordered
[ 21.797795] r8169 0000:06:00.0 enp6s0: link down
[ 21.797802] r8169 0000:06:00.0 enp6s0: link down
[ 21.797836] IPv6: ADDRCONF(NETDEV_UP): enp6s0: link is not ready
[ 23.381273] r8169 0000:06:00.0 enp6s0: link up
[ 23.381289] IPv6: ADDRCONF(NETDEV_CHANGE): enp6s0: link becomes ready
[ 27.541998] usblp0: removed
[ 62.932576] usb 2-5: USB disconnect, device number 2
[ 64.612872] usb 2-5: new low-speed USB device number 3 using ohci_hcd
[ 64.778631] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb2/2-5/2-5:1.0/input/input6
[ 64.778917] hid-generic 0003:093A:2510.0004: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:12.0-5/input0
[ 124.743723] usb 2-5: USB disconnect, device number 3
[ 126.423922] usb 2-5: new low-speed USB device number 4 using ohci_hcd
[ 126.590728] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb2/2-5/2-5:1.0/input/input7
[ 126.591018] hid-generic 0003:093A:2510.0005: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:12.0-5/input0
[ 160.934934] [drm] Initialized drm 1.1.0 20060810
[ 160.945488] nvidia: module license ‘NVIDIA’ taints kernel.
[ 160.945492] Disabling lock debugging due to kernel taint
[ 160.953904] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 160.954209] [drm] Initialized nvidia-drm 0.0.0 20130102 for 0000:01:00.0 on minor 0
[ 160.954215] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 319.49 Tue Aug 13 21:15:53 PDT 2013
[ 160.957023] [drm] Module unloaded
-> Installing both new and classic TLS OpenGL libraries.
-> Installing classic TLS 32bit OpenGL libraries.
-> Install NVIDIA’s 32-bit compatibility OpenGL libraries? (Answer: No)
-> Parsing log file:
-> done.
-> Validating previous installation:
-> The previously installed file ‘/usr/lib/libGL.la’ seems to have changed, but prelink -u failed; unable to restore ‘/usr/lib/libGL.la’ to an un-prelinked state.
-> Un-prelinking unsuccessful: ‘/usr/lib/libGL.la’ will not be uninstalled.
-> done.
WARNING: Your driver installation has been altered since it was initially installed; this may happen, for example, if you have since installed the NVIDIA driver through a mechanism other than nvidia-installer (such as your distribution’s native package management system). nvidia-installer will attempt to uninstall as best it can. Please see the file ‘/var/log/nvidia-installer.log’ for details.
-> Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-31949 (319.49)):
-> done.
-> Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (319.49) is complete.
-> Searching for conflicting X files:
-> done.
-> Searching for conflicting OpenGL files:
-> done.
-> Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (319.49):
executing: ‘/usr/bin/ldconfig’…
executing: ‘/usr/bin/depmod -aq’…
-> done.
-> Driver file installation is complete.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Shared memory test passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
-> Your X configuration file has been successfully updated. Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 319.49) is now complete.
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 26554 2013-09-01 16:01:12.556419440 -0300 /var/log/Xorg.0.log
[ 9.725]
X.Org X Server 1.14.2
Release Date: 2013-06-25
[ 9.725] X Protocol Version 11, Revision 0
[ 9.725] Build Operating System: Linux 3.9.7-1-ARCH x86_64
[ 9.725] Current Operating System: Linux arch-o-ilkyest 3.10.10-1-ARCH #1 SMP PREEMPT Fri Aug 30 11:30:06 CEST 2013 x86_64
[ 9.725] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=ba71ff2e-5f93-452d-a384-3e719918b7d9 rw nomodeset rdblacklist=nouveau noapic clocksource=hpet quiet
[ 9.725] Build Date: 01 July 2013 10:48:42AM
[ 9.725]
[ 9.725] Current version of pixman: 0.30.2
[ 9.725] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 9.725] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 9.725] (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Sep 1 16:00:35 2013
[ 9.735] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 9.819] (==) No Layout section. Using the first Screen section.
[ 9.819] (==) No screen section available. Using defaults.
[ 9.819] (
) |–>Screen “Default Screen Section” (0)
[ 9.819] () | |–>Monitor “”
[ 9.820] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 9.820] (
) | |–>Device “nvidia”
[ 9.820] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 9.820] (==) Automatically adding devices
[ 9.820] (==) Automatically enabling devices
[ 9.820] (==) Automatically adding GPU devices
[ 9.854] (WW) The directory “/usr/share/fonts/OTF/” does not exist.
[ 9.854] Entry deleted from font path.
[ 9.854] (WW) The directory “/usr/share/fonts/Type1/” does not exist.
[ 9.854] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/". [ 9.854] Entry deleted from font path. [ 9.854] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/"). [ 9.863] (WW) fonts.dir’ not found (or not valid) in “/usr/share/fonts/75dpi/”.
[ 9.863] Entry deleted from font path.
[ 9.863] (Run ‘mkfontdir’ on “/usr/share/fonts/75dpi/”).
[ 9.863] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/
[ 9.863] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 9.863] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 9.864] (II) Loader magic: 0x7fdc20
[ 9.864] (II) Module ABI versions:
[ 9.864] X.Org ANSI C Emulation: 0.4
[ 9.864] X.Org Video Driver: 14.1
[ 9.864] X.Org XInput driver : 19.1
[ 9.864] X.Org Server Extension : 7.0
[ 9.864] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9.867] (–) PCI:*(0:1:0:0) 10de:11c6:0000:0000 rev 161, Mem @ 0xfd000000/16777216, 0xf0000000/134217728, 0xf8000000/33554432, I/O @ 0x0000bc00/128, BIOS @ 0x???/524288
[ 9.871] Initializing built-in extension Generic Event Extension
[ 9.871] Initializing built-in extension SHAPE
[ 9.871] Initializing built-in extension MIT-SHM
[ 9.871] Initializing built-in extension XInputExtension
[ 9.871] Initializing built-in extension XTEST
[ 9.871] Initializing built-in extension BIG-REQUESTS
[ 9.871] Initializing built-in extension SYNC
[ 9.871] Initializing built-in extension XKEYBOARD
[ 9.871] Initializing built-in extension XC-MISC
[ 9.871] Initializing built-in extension SECURITY
[ 9.871] Initializing built-in extension XINERAMA
[ 9.871] Initializing built-in extension XFIXES
[ 9.871] Initializing built-in extension RENDER
[ 9.871] Initializing built-in extension RANDR
[ 9.871] Initializing built-in extension COMPOSITE
[ 9.871] Initializing built-in extension DAMAGE
[ 9.871] Initializing built-in extension MIT-SCREEN-SAVER
[ 9.871] Initializing built-in extension DOUBLE-BUFFER
[ 9.871] Initializing built-in extension RECORD
[ 9.871] Initializing built-in extension DPMS
[ 9.871] Initializing built-in extension X-Resource
[ 9.871] Initializing built-in extension XVideo
[ 9.871] Initializing built-in extension XVideo-MotionCompensation
[ 9.871] Initializing built-in extension XFree86-VidModeExtension
[ 9.871] Initializing built-in extension XFree86-DGA
[ 9.871] Initializing built-in extension XFree86-DRI
[ 9.871] Initializing built-in extension DRI2
[ 9.871] (II) LoadModule: “glx”
[ 9.886] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.458] (II) Module glx: vendor=“NVIDIA Corporation”
[ 11.458] compiled for 4.0.2, module version = 1.0.0
[ 11.458] Module class: X.Org Server Extension
[ 11.458] (II) NVIDIA GLX Module 319.49 Tue Aug 13 19:53:22 PDT 2013
[ 11.469] Loading extension GLX
[ 11.469] (II) LoadModule: “nvidia”
[ 11.470] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 11.658] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 11.658] compiled for 4.0.2, module version = 1.0.0
[ 11.658] Module class: X.Org Video Driver
[ 11.701] (II) NVIDIA dlloader X Driver 319.49 Tue Aug 13 19:34:58 PDT 2013
[ 11.701] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 11.710] (++) using VT number 7
[ 11.735] (II) Loading sub module “fb”
[ 11.735] (II) LoadModule: “fb”
[ 11.763] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.806] (II) Module fb: vendor=“X.Org Foundation”
[ 11.806] compiled for 1.14.2, module version = 1.0.0
[ 11.806] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.806] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 11.806] (II) Loading sub module “wfb”
[ 11.806] (II) LoadModule: “wfb”
[ 11.806] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 11.829] (II) Module wfb: vendor=“X.Org Foundation”
[ 11.829] compiled for 1.14.2, module version = 1.0.0
[ 11.829] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.829] (II) Loading sub module “shadow”
[ 11.829] (II) LoadModule: “shadow”
[ 11.829] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 11.861] (II) Module shadow: vendor=“X.Org Foundation”
[ 11.861] compiled for 1.14.2, module version = 1.1.0
[ 11.861] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.861] (II) Loading sub module “ramdac”
[ 11.861] (II) LoadModule: “ramdac”
[ 11.861] (II) Module “ramdac” already built-in
[ 11.869] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 11.869] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 11.869] (==) NVIDIA(0): RGB weight 888
[ 11.869] (==) NVIDIA(0): Default visual is TrueColor
[ 11.869] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.870] () NVIDIA(0): Enabling 2D acceleration
[ 12.618] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 12.618] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 12.618] (–) NVIDIA(GPU-0):
[ 12.618] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 12.618] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 12.618] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 12.618] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 12.618] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 12.618] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 12.618] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 12.618] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 12.618] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 12.618] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 12.620] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti (GK106) at PCI:1:0:0 (GPU-0)
[ 12.620] (–) NVIDIA(0): Memory: 1048576 kBytes
[ 12.620] (–) NVIDIA(0): VideoBIOS: 80.06.21.00.14
[ 12.620] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 12.625] (–) NVIDIA(0): Valid display device(s) on GeForce GTX 650 Ti at PCI:1:0:0
[ 12.625] (–) NVIDIA(0): CRT-0 (boot, connected)
[ 12.625] (–) NVIDIA(0): DFP-0
[ 12.625] (–) NVIDIA(0): DFP-1
[ 12.625] (–) NVIDIA(0): DFP-2
[ 12.625] (–) NVIDIA(0): CRT-0: 480.0 MHz maximum pixel clock
[ 12.625] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 12.625] (–) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 12.625] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 12.625] (–) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 12.625] (–) NVIDIA(0): DFP-2: 330.0 MHz maximum pixel clock
[ 12.625] (–) NVIDIA(0): DFP-2: Internal Single Link TMDS
[ 12.625] (
) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 12.625] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 12.625] (
) NVIDIA(0): all display devices.)
[ 12.626] (==) NVIDIA(0):
[ 12.626] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 12.626] (==) NVIDIA(0): will be used as the requested mode.
[ 12.626] (II) NVIDIA(0): Validated MetaModes:
[ 12.626] (II) NVIDIA(0): “CRT-0:nvidia-auto-select{}”
[ 12.626] (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
[ 12.657] (WW) NVIDIA(0): Unable to get display device CRT-0’s EDID; cannot compute DPI
[ 12.657] (WW) NVIDIA(0): from CRT-0’s EDID.
[ 12.657] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 12.657] (–) Depth 24 pixmap format is 32 bpp
[ 12.657] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 12.657] (II) NVIDIA: access.
[ 12.678] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 12.678] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 12.678] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 12.678] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 12.678] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 12.678] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 12.678] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 12.678] (II) NVIDIA(0): Config Options in the README.
[ 12.682] (II) NVIDIA(0): Setting mode “CRT-0:nvidia-auto-select{}”
[ 12.720] Loading extension NV-GLX
[ 12.763] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 12.763] (==) NVIDIA(0): Backing store disabled
[ 12.763] (==) NVIDIA(0): Silken mouse enabled
[ 12.763] (==) NVIDIA(0): DPMS enabled
[ 12.763] Loading extension NV-CONTROL
[ 12.764] Loading extension XINERAMA
[ 12.764] (II) Loading sub module “dri2”
[ 12.764] (II) LoadModule: “dri2”
[ 12.764] (II) Module “dri2” already built-in
[ 12.764] (II) NVIDIA(0): [DRI2] Setup complete
[ 12.764] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 12.764] (–) RandR disabled
[ 12.777] (II) Initializing extension GLX
[ 13.308] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 13.308] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 13.308] (II) LoadModule: “evdev”
[ 13.308] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 13.317] (II) Module evdev: vendor=“X.Org Foundation”
[ 13.317] compiled for 1.14.2, module version = 2.8.1
[ 13.317] Module class: X.Org XInput Driver
[ 13.317] ABI class: X.Org XInput driver, version 19.1
[ 13.317] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 13.317] (
) Power Button: always reports core events
[ 13.317] () evdev: Power Button: Device: “/dev/input/event3”
[ 13.317] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 13.317] (–) evdev: Power Button: Found keys
[ 13.317] (II) evdev: Power Button: Configuring as keyboard
[ 13.317] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3”
[ 13.317] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 13.317] () Option “xkb_rules” “evdev”
[ 13.317] (
) Option “xkb_model” “pc104”
[ 13.317] () Option “xkb_layout” “us”
[ 13.351] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 13.351] (
[ 13.351] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 13.351] () Power Button: always reports core events
[ 13.351] (
) evdev: Power Button: Device: “/dev/input/event2”
[ 13.351] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 13.351] (–) evdev: Power Button: Found keys
[ 13.351] (II) evdev: Power Button: Configuring as keyboard
[ 13.351] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event2”
[ 13.351] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 13.351] (
[ 13.351] () Option “xkb_model” “pc104”
[ 13.351] (
[ 13.352] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 13.352] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event0)
[ 13.352] () PixArt USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 13.352] (II) Using input driver ‘evdev’ for ‘PixArt USB Optical Mouse’
[ 13.352] (
) PixArt USB Optical Mouse: always reports core events
[ 13.352] () evdev: PixArt USB Optical Mouse: Device: “/dev/input/event0”
[ 13.352] (–) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[ 13.352] (–) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[ 13.352] (–) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[ 13.352] (–) evdev: PixArt USB Optical Mouse: Found relative axes
[ 13.352] (–) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[ 13.352] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[ 13.352] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[ 13.352] (
) evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 13.352] () evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 13.352] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-5/3-5:1.0/input/input0/event0”
[ 13.352] (II) XINPUT: Adding extended input device “PixArt USB Optical Mouse” (type: MOUSE, id 8)
[ 13.353] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[ 13.353] () PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 13.353] (
) PixArt USB Optical Mouse: (accel) acceleration profile 0
[ 13.353] () PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[ 13.353] (
) PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[ 13.354] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[ 13.354] (II) No input driver specified, ignoring this device.
[ 13.354] (II) This device may have been added with another device file.
[ 13.354] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event1)
[ 13.354] () SIGMACHIP USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 13.354] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 13.354] (
) SIGMACHIP USB Keyboard: always reports core events
[ 13.354] () evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event1”
[ 13.354] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x16
[ 13.354] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 13.354] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 13.354] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb4/4-1/4-1:1.0/input/input1/event1”
[ 13.354] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 9)
[ 13.354] () Option “xkb_rules” “evdev”
[ 13.355] (
[ 13.355] () Option “xkb_layout” “us”
[ 13.355] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 13.355] (II) No input driver specified, ignoring this device.
[ 13.355] (II) This device may have been added with another device file.
[ 13.363] (II) config/udev: removing device SIGMACHIP USB Keyboard
[ 13.446] (II) evdev: SIGMACHIP USB Keyboard: Close
[ 13.446] (II) UnloadModule: “evdev”
[ 13.447] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event1)
[ 13.447] (
[ 13.447] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 13.447] () SIGMACHIP USB Keyboard: always reports core events
[ 13.447] (
[ 13.447] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x16
[ 13.447] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 13.447] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 13.447] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb4/4-1/4-1:1.0/input/input1/event1”
[ 13.447] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 9)
[ 13.447] (
[ 13.447] () Option “xkb_model” “pc104”
[ 13.447] (
[ 13.448] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event5)
[ 13.448] () SIGMACHIP USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 13.448] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 13.448] (
[ 13.448] () evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event5”
[ 13.448] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x16
[ 13.448] (–) evdev: SIGMACHIP USB Keyboard: Found 1 mouse buttons
[ 13.448] (–) evdev: SIGMACHIP USB Keyboard: Found scroll wheel(s)
[ 13.448] (–) evdev: SIGMACHIP USB Keyboard: Found relative axes
[ 13.448] (II) evdev: SIGMACHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 13.448] (–) evdev: SIGMACHIP USB Keyboard: Found absolute axes
[ 13.448] (II) evdev: SIGMACHIP USB Keyboard: Forcing absolute x/y axes to exist.
[ 13.448] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 13.448] (II) evdev: SIGMACHIP USB Keyboard: Configuring as mouse
[ 13.448] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 13.448] (II) evdev: SIGMACHIP USB Keyboard: Adding scrollwheel support
[ 13.449] (
) evdev: SIGMACHIP USB Keyboard: YAxisMapping: buttons 4 and 5
[ 13.449] () evdev: SIGMACHIP USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 13.449] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb4/4-1/4-1:1.1/input/input5/event5”
[ 13.449] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 10)
[ 13.449] () Option “xkb_rules” “evdev”
[ 13.449] (
[ 13.449] () Option “xkb_layout” “us”
[ 13.449] (II) evdev: SIGMACHIP USB Keyboard: initialized for relative axes.
[ 13.449] (WW) evdev: SIGMACHIP USB Keyboard: ignoring absolute axes.
[ 13.450] (
) SIGMACHIP USB Keyboard: (accel) keeping acceleration scheme 1
[ 13.450] () SIGMACHIP USB Keyboard: (accel) acceleration profile 0
[ 13.450] (
) SIGMACHIP USB Keyboard: (accel) acceleration factor: 2.000
[ 13.450] () SIGMACHIP USB Keyboard: (accel) acceleration threshold: 4
[ 30.437] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 30.437] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 30.437] (–) NVIDIA(GPU-0):
[ 30.437] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 30.437] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 30.437] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 30.437] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 30.437] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 30.437] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 30.437] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 30.437] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 30.437] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 30.437] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 30.437] (
[ 30.437] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 30.437] (
[ 41.929] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 41.929] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 41.929] (–) NVIDIA(GPU-0):
[ 41.929] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 41.929] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 41.929] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 41.929] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 41.929] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 41.929] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 41.929] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 41.930] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 41.930] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 41.930] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 41.930] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 41.930] (
[ 41.930] () NVIDIA(0): all display devices.)
[ 46.510] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 46.510] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 46.510] (–) NVIDIA(GPU-0):
[ 46.510] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 46.510] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 46.510] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 46.510] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 46.510] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 46.510] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 46.510] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 46.510] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 46.510] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 46.510] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 46.510] (
[ 46.510] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 46.510] (
*** /etc/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2013-07-01 07:49:50.000000000 -0300 /etc/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /etc/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 377 2013-07-01 07:49:52.000000000 -0300 /etc/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
http://bugs.freedesktop.org/show_bug.cgi?id=22442
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
*** /etc/X11/xorg.conf.d/nvidia.conf
*** ls: -rw-r–r-- 1 root root 97 2013-09-01 14:09:00.346543768 -0300 /etc/X11/xorg.conf.d/nvidia.conf
Section “Device”
Identifier “nvidia”
Driver “nvidia”
BusID “PCI:1:0:0”
EndSection
*** /var/log/Xorg.1.log
*** ls: -rw-r–r-- 1 root root 22861 2013-08-23 15:39:33.180028630 -0300 /var/log/Xorg.1.log
[ 1210.040]
[ 1210.046] X Protocol Version 11, Revision 0
[ 1210.047] Build Operating System: Linux 3.9.7-1-ARCH x86_64
[ 1210.050] Current Operating System: Linux arch-o-ilkyest 3.10.7-1-ARCH #1 SMP PREEMPT Thu Aug 15 11:55:34 CEST 2013 x86_64
[ 1210.050] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=ba71ff2e-5f93-452d-a384-3e719918b7d9 rw nomodeset rdblacklist=nouveau noapic clocksource=hpet quiet
[ 1210.055] Build Date: 01 July 2013 10:48:42AM
[ 1210.057]
[ 1210.058] Current version of pixman: 0.30.2
[ 1210.061] Before reporting problems, check http://wiki.x.org
[ 1210.061] Markers: (–) probed, () from config file, (==) default setting,
[ 1210.067] (==) Log file: “/var/log/Xorg.1.log”, Time: Fri Aug 23 15:39:32 2013
[ 1210.069] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 1210.069] (==) No Layout section. Using the first Screen section.
[ 1210.069] (==) No screen section available. Using defaults.
[ 1210.069] (
[ 1210.069] (**) | |–>Monitor “”
[ 1210.069] (==) No monitor specified for screen “Default Screen Section”.
[ 1210.069] (==) Automatically adding devices
[ 1210.069] (==) Automatically enabling devices
[ 1210.069] (==) Automatically adding GPU devices
[ 1210.069] (WW) The directory “/usr/share/fonts/OTF/” does not exist.
[ 1210.069] Entry deleted from font path.
[ 1210.069] (WW) The directory “/usr/share/fonts/Type1/” does not exist.
[ 1210.069] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/". [ 1210.069] Entry deleted from font path. [ 1210.069] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/"). [ 1210.069] (WW) fonts.dir’ not found (or not valid) in “/usr/share/fonts/75dpi/”.
[ 1210.069] (Run ‘mkfontdir’ on “/usr/share/fonts/75dpi/”).
[ 1210.069] (==) FontPath set to:
[ 1210.069] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 1210.069] (II) The server relies on udev to provide the list of input devices.
[ 1210.069] (II) Loader magic: 0x7fdc20
[ 1210.069] (II) Module ABI versions:
[ 1210.069] X.Org ANSI C Emulation: 0.4
[ 1210.069] X.Org Video Driver: 14.1
[ 1210.069] X.Org XInput driver : 19.1
[ 1210.069] X.Org Server Extension : 7.0
[ 1210.069] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1210.070] setversion 1.4 failed
[ 1210.072] (–) PCI:*(0:1:0:0) 10de:11c6:0000:0000 rev 161, Mem @ 0xfd000000/16777216, 0xf0000000/134217728, 0xf8000000/33554432, I/O @ 0x0000bc00/128, BIOS @ 0x???/524288
[ 1210.073] Initializing built-in extension Generic Event Extension
[ 1210.075] Initializing built-in extension SHAPE
[ 1210.076] Initializing built-in extension MIT-SHM
[ 1210.078] Initializing built-in extension XInputExtension
[ 1210.079] Initializing built-in extension XTEST
[ 1210.081] Initializing built-in extension BIG-REQUESTS
[ 1210.082] Initializing built-in extension SYNC
[ 1210.084] Initializing built-in extension XKEYBOARD
[ 1210.085] Initializing built-in extension XC-MISC
[ 1210.087] Initializing built-in extension SECURITY
[ 1210.088] Initializing built-in extension XINERAMA
[ 1210.090] Initializing built-in extension XFIXES
[ 1210.091] Initializing built-in extension RENDER
[ 1210.092] Initializing built-in extension RANDR
[ 1210.094] Initializing built-in extension COMPOSITE
[ 1210.095] Initializing built-in extension DAMAGE
[ 1210.096] Initializing built-in extension MIT-SCREEN-SAVER
[ 1210.097] Initializing built-in extension DOUBLE-BUFFER
[ 1210.098] Initializing built-in extension RECORD
[ 1210.099] Initializing built-in extension DPMS
[ 1210.100] Initializing built-in extension X-Resource
[ 1210.101] Initializing built-in extension XVideo
[ 1210.101] Initializing built-in extension XVideo-MotionCompensation
[ 1210.102] Initializing built-in extension XFree86-VidModeExtension
[ 1210.103] Initializing built-in extension XFree86-DGA
[ 1210.104] Initializing built-in extension XFree86-DRI
[ 1210.104] Initializing built-in extension DRI2
[ 1210.104] (II) LoadModule: “glx”
[ 1210.105] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1210.115] (II) Module glx: vendor=“NVIDIA Corporation”
[ 1210.115] compiled for 4.0.2, module version = 1.0.0
[ 1210.115] Module class: X.Org Server Extension
[ 1210.115] (II) NVIDIA GLX Module 325.15 Wed Jul 31 18:12:00 PDT 2013
[ 1210.116] Loading extension GLX
[ 1210.116] (==) Matched nouveau as autoconfigured driver 0
[ 1210.116] (==) Matched nvidia as autoconfigured driver 1
[ 1210.116] (==) Matched nv as autoconfigured driver 2
[ 1210.116] (==) Matched vesa as autoconfigured driver 3
[ 1210.116] (==) Matched modesetting as autoconfigured driver 4
[ 1210.116] (==) Matched fbdev as autoconfigured driver 5
[ 1210.116] (==) Assigned the driver to the xf86ConfigLayout
[ 1210.116] (II) LoadModule: “nouveau”
[ 1210.116] (WW) Warning, couldn’t open module nouveau
[ 1210.116] (II) UnloadModule: “nouveau”
[ 1210.116] (II) Unloading nouveau
[ 1210.116] (EE) Failed to load module “nouveau” (module does not exist, 0)
[ 1210.116] (II) LoadModule: “nvidia”
[ 1210.116] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 1210.117] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 1210.117] compiled for 4.0.2, module version = 1.0.0
[ 1210.117] Module class: X.Org Video Driver
[ 1210.117] (II) LoadModule: “nv”
[ 1210.117] (WW) Warning, couldn’t open module nv
[ 1210.117] (II) UnloadModule: “nv”
[ 1210.117] (II) Unloading nv
[ 1210.117] (EE) Failed to load module “nv” (module does not exist, 0)
[ 1210.117] (II) LoadModule: “vesa”
[ 1210.117] (WW) Warning, couldn’t open module vesa
[ 1210.117] (II) UnloadModule: “vesa”
[ 1210.117] (II) Unloading vesa
[ 1210.117] (EE) Failed to load module “vesa” (module does not exist, 0)
[ 1210.117] (II) LoadModule: “modesetting”
[ 1210.117] (WW) Warning, couldn’t open module modesetting
[ 1210.117] (II) UnloadModule: “modesetting”
[ 1210.117] (II) Unloading modesetting
[ 1210.117] (EE) Failed to load module “modesetting” (module does not exist, 0)
[ 1210.117] (II) LoadModule: “fbdev”
[ 1210.117] (WW) Warning, couldn’t open module fbdev
[ 1210.117] (II) UnloadModule: “fbdev”
[ 1210.117] (II) Unloading fbdev
[ 1210.117] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 1210.117] (II) NVIDIA dlloader X Driver 325.15 Wed Jul 31 17:50:57 PDT 2013
[ 1210.117] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 1210.117] (++) using VT number 1
[ 1210.117] (II) Loading sub module “fb”
[ 1210.117] (II) LoadModule: “fb”
[ 1210.117] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 1210.117] (II) Module fb: vendor=“X.Org Foundation”
[ 1210.117] compiled for 1.14.2, module version = 1.0.0
[ 1210.117] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1210.117] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 1210.117] (II) Loading sub module “wfb”
[ 1210.117] (II) LoadModule: “wfb”
[ 1210.117] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 1210.117] (II) Module wfb: vendor=“X.Org Foundation”
[ 1210.117] (II) Loading sub module “shadow”
[ 1210.117] (II) LoadModule: “shadow”
[ 1210.117] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 1210.117] (II) Module shadow: vendor=“X.Org Foundation”
[ 1210.117] compiled for 1.14.2, module version = 1.1.0
[ 1210.117] (II) Loading sub module “ramdac”
[ 1210.117] (II) LoadModule: “ramdac”
[ 1210.118] (II) Module “ramdac” already built-in
[ 1210.118] (II) NVIDIA(0): Creating default Display subsection in Screen section
[ 1210.118] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 1210.118] (==) NVIDIA(0): RGB weight 888
[ 1210.118] (==) NVIDIA(0): Default visual is TrueColor
[ 1210.118] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1210.118] () NVIDIA(0): Enabling 2D acceleration
[ 1210.121] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[ 1210.313] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 1210.313] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 1210.313] (–) NVIDIA(GPU-0):
[ 1210.313] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 1210.313] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 1210.313] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 1210.313] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 1210.313] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 1210.313] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 1210.313] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 1210.313] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 1210.313] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 1210.313] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1210.313] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti (GK106) at PCI:1:0:0 (GPU-0)
[ 1210.313] (–) NVIDIA(0): Memory: 1048576 kBytes
[ 1210.313] (–) NVIDIA(0): VideoBIOS: 80.06.21.00.14
[ 1210.313] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 1210.317] (–) NVIDIA(0): Valid display device(s) on GeForce GTX 650 Ti at PCI:1:0:0
[ 1210.317] (–) NVIDIA(0): CRT-0 (boot, connected)
[ 1210.317] (–) NVIDIA(0): DFP-0
[ 1210.317] (–) NVIDIA(0): DFP-1
[ 1210.317] (–) NVIDIA(0): DFP-2
[ 1210.317] (–) NVIDIA(0): CRT-0: 480.0 MHz maximum pixel clock
[ 1210.317] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 1210.317] (–) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 1210.317] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 1210.317] (–) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 1210.317] (–) NVIDIA(0): DFP-2: 330.0 MHz maximum pixel clock
[ 1210.317] (–) NVIDIA(0): DFP-2: Internal Single Link TMDS
[ 1210.317] (
[ 1210.317] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 1210.317] (
[ 1210.319] (==) NVIDIA(0):
[ 1210.319] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 1210.319] (==) NVIDIA(0): will be used as the requested mode.
[ 1210.319] (II) NVIDIA(0): Validated MetaModes:
[ 1210.319] (II) NVIDIA(0): “CRT-0:nvidia-auto-select{}”
[ 1210.319] (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
[ 1210.350] (WW) NVIDIA(0): Unable to get display device CRT-0’s EDID; cannot compute DPI
[ 1210.350] (WW) NVIDIA(0): from CRT-0’s EDID.
[ 1210.350] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 1210.350] (–) Depth 24 pixmap format is 32 bpp
[ 1210.350] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 1210.350] (II) NVIDIA: access.
[ 1210.354] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 1210.354] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 1210.354] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 1210.354] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 1210.354] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 1210.354] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 1210.354] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 1210.354] (II) NVIDIA(0): Config Options in the README.
[ 1210.358] (II) NVIDIA(0): Setting mode “CRT-0:nvidia-auto-select{}”
[ 1210.399] Loading extension NV-GLX
[ 1210.416] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 1210.416] (==) NVIDIA(0): Backing store disabled
[ 1210.416] (==) NVIDIA(0): Silken mouse enabled
[ 1210.417] (==) NVIDIA(0): DPMS enabled
[ 1210.417] Loading extension NV-CONTROL
[ 1210.417] Loading extension XINERAMA
[ 1210.417] (II) Loading sub module “dri2”
[ 1210.417] (II) LoadModule: “dri2”
[ 1210.417] (II) Module “dri2” already built-in
[ 1210.417] (II) NVIDIA(0): [DRI2] Setup complete
[ 1210.417] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 1210.418] (–) RandR disabled
[ 1210.421] (II) Initializing extension GLX
[ 1210.464] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 1210.464] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 1210.464] (II) LoadModule: “evdev”
[ 1210.464] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 1210.465] (II) Module evdev: vendor=“X.Org Foundation”
[ 1210.465] compiled for 1.14.2, module version = 2.8.1
[ 1210.465] Module class: X.Org XInput Driver
[ 1210.465] ABI class: X.Org XInput driver, version 19.1
[ 1210.465] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 1210.465] (
[ 1210.465] () evdev: Power Button: Device: “/dev/input/event4”
[ 1210.465] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 1210.465] (–) evdev: Power Button: Found keys
[ 1210.465] (II) evdev: Power Button: Configuring as keyboard
[ 1210.465] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4”
[ 1210.465] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 1210.465] () Option “xkb_rules” “evdev”
[ 1210.465] (
[ 1210.465] () Option “xkb_layout” “us”
[ 1210.489] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 1210.489] (
[ 1210.489] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 1210.489] () Power Button: always reports core events
[ 1210.489] (
[ 1210.489] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 1210.489] (–) evdev: Power Button: Found keys
[ 1210.489] (II) evdev: Power Button: Configuring as keyboard
[ 1210.489] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3/event3”
[ 1210.489] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 1210.489] (
[ 1210.489] () Option “xkb_model” “pc104”
[ 1210.489] (
[ 1210.490] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 1210.490] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1210.490] setversion 1.4 failed
[ 1210.491] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event6)
[ 1210.491] (II) No input driver specified, ignoring this device.
[ 1210.491] (II) This device may have been added with another device file.
[ 1210.491] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event7)
[ 1210.492] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[ 1210.492] (II) No input driver specified, ignoring this device.
[ 1210.492] (II) This device may have been added with another device file.
[ 1210.492] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 1210.493] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event1)
[ 1210.493] () PixArt USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 1210.493] (II) Using input driver ‘evdev’ for ‘PixArt USB Optical Mouse’
[ 1210.493] (
[ 1210.493] () evdev: PixArt USB Optical Mouse: Device: “/dev/input/event1”
[ 1210.493] (–) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[ 1210.493] (–) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[ 1210.493] (–) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[ 1210.493] (–) evdev: PixArt USB Optical Mouse: Found relative axes
[ 1210.493] (–) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[ 1210.493] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[ 1210.493] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[ 1210.493] (
[ 1210.493] () evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 1210.493] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-5/6-5:1.0/input/input11/event1”
[ 1210.493] (II) XINPUT: Adding extended input device “PixArt USB Optical Mouse” (type: MOUSE, id 8)
[ 1210.493] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[ 1210.494] () PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 1210.494] (
[ 1210.494] () PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[ 1210.494] (
[ 1210.494] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[ 1210.494] (II) No input driver specified, ignoring this device.
[ 1210.494] (II) This device may have been added with another device file.
[ 1210.495] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event0)
[ 1210.495] () SIGMACHIP USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 1210.495] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 1210.495] (
[ 1210.495] () evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event0”
[ 1210.495] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x16
[ 1210.495] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 1210.495] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 1210.495] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb7/7-1/7-1:1.0/input/input0/event0”
[ 1210.495] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 9)
[ 1210.495] () Option “xkb_rules” “evdev”
[ 1210.495] (
[ 1210.495] () Option “xkb_layout” “us”
[ 1210.496] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event2)
[ 1210.496] (
[ 1210.496] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 1210.496] () SIGMACHIP USB Keyboard: always reports core events
[ 1210.496] (
) evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event2”
[ 1210.496] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x16
[ 1210.496] (–) evdev: SIGMACHIP USB Keyboard: Found 1 mouse buttons
[ 1210.496] (–) evdev: SIGMACHIP USB Keyboard: Found scroll wheel(s)
[ 1210.496] (–) evdev: SIGMACHIP USB Keyboard: Found relative axes
[ 1210.496] (II) evdev: SIGMACHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 1210.496] (–) evdev: SIGMACHIP USB Keyboard: Found absolute axes
[ 1210.496] (II) evdev: SIGMACHIP USB Keyboard: Forcing absolute x/y axes to exist.
[ 1210.496] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 1210.496] (II) evdev: SIGMACHIP USB Keyboard: Configuring as mouse
[ 1210.496] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 1210.496] (II) evdev: SIGMACHIP USB Keyboard: Adding scrollwheel support
[ 1210.496] () evdev: SIGMACHIP USB Keyboard: YAxisMapping: buttons 4 and 5
[ 1210.496] (
[ 1210.496] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb7/7-1/7-1:1.1/input/input2/event2”
[ 1210.496] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 10)
[ 1210.496] (
[ 1210.496] () Option “xkb_model” “pc104”
[ 1210.496] (
[ 1210.496] (II) evdev: SIGMACHIP USB Keyboard: initialized for relative axes.
[ 1210.496] (WW) evdev: SIGMACHIP USB Keyboard: ignoring absolute axes.
[ 1210.496] () SIGMACHIP USB Keyboard: (accel) keeping acceleration scheme 1
[ 1210.496] (
[ 1210.496] () SIGMACHIP USB Keyboard: (accel) acceleration factor: 2.000
[ 1210.496] (
[ 1210.497] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 1210.497] (II) No input driver specified, ignoring this device.
[ 1210.497] (II) This device may have been added with another device file.
[ 1210.803] (II) evdev: SIGMACHIP USB Keyboard: Close
[ 1210.803] (II) UnloadModule: “evdev”
[ 1210.803] (II) evdev: PixArt USB Optical Mouse: Close
[ 1210.803] (II) evdev: Power Button: Close
[ 1211.088] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 1211.091] (EE) Server terminated successfully (0). Closing log file.
*** /usr/share/nvidia/nvidia-application-profiles-319.49-rc
*** ls: -r–r--r-- 1 root root 652 2013-09-01 14:01:32.039003832 -0300 /usr/share/nvidia/nvidia-application-profiles-319.49-rc
Application profiles for the NVIDIA Linux graphics driver, version 319.49
Last modified: Tue Aug 13 19:56:21 PDT 2013
These profiles were provided by NVIDIA and should not be modified. If you
wish to change the defaults provided here, you can override them by creating
custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
(which will apply to that particular user). See the "APPLICATION PROFILE
SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
information.
“profiles” : [
“rules” : [
ldd /sbin/glxinfo
linux-vdso.so.1 (0x00007ffff3eee000)
libGL.so.1 => /usr/lib/libGL.so.1 (0x00007f4bdd83c000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007f4bdd501000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007f4bdd157000)
libnvidia-tls.so.319.49 => /usr/lib/tls/libnvidia-tls.so.319.49 (0x00007f4bdcf54000)
libnvidia-glcore.so.319.49 => /usr/lib/libnvidia-glcore.so.319.49 (0x00007f4bda9fc000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007f4bda7ea000)
libdl.so.2 => /usr/lib/libdl.so.2 (0x00007f4bda5e6000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007f4bda3c7000)
/lib64/ld-linux-x86-64.so.2 (0x00007f4bddb6a000)
libm.so.6 => /usr/lib/libm.so.6 (0x00007f4bda0c4000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007f4bd9ec0000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007f4bd9cba000)
/sbin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 650 Ti] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at fd000000 (32-bit, non-prefetchable)
Memory at f0000000 (64-bit, prefetchable)
Memory at f8000000 (64-bit, prefetchable)
I/O ports at bc00
[virtual] Expansion ROM at fe880000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia
00: de 10 c6 11 07 00 10 00 a1 00 00 03 00 00 80 00
10: 00 00 00 fd 0c 00 00 f0 00 00 00 00 0c 00 00 f8
20: 00 00 00 00 01 bc 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 60 00 00 00 00 00 00 00 0a 01 00 00
40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 b4 02 00 e1 8d 2c 01
80: 10 29 00 00 02 3d 45 00 40 01 02 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
a0: 00 00 00 00 00 00 00 00 02 00 01 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01:00.1 Audio device: NVIDIA Corporation Device 0e0b (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 9
Memory at fe87c000 (32-bit, non-prefetchable)
Kernel modules: snd_hda_intel
00: de 10 0b 0e 06 01 10 00 a1 00 03 04 10 00 80 00
10: 00 c0 87 fe 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 0
hm… so interesting.
may be 'cause?
If yes… I’ve changed, about 30 seconds ago, the fourth one
by the last one (that came with the GPU) but, the same resolution without Xorg.conf (1024x768) and the worst one (640x480) with it
Another thing that may help
nvidia-xconfig --metamodes=1440x900+0+0 --force-generate
<b>Package xorg-server was not found in the pkg-config search path.</b>
Perhaps you should add the directory containing `xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
<b>No package 'xorg-server' found</b>
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.nvidia-xconfig-original'
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
It’s installed… but I couldn’t find any xorg-server.pc and, not even where I change the PKG_CONFIG_PATH
More tries… (repository driver) and same issue
even with “vga=normal”
Important note is that effects (kwin) work normally, also folding at home, so the driver is working, but don’t at full resolution
It sounds like your monitor is broken. You can try to work around it by setting the IgnoreEDIDChecksum option in the Device section of /etc/X11/xorg.conf, but please be aware that depending on how broken the EDID really is, this can cause the driver to output a signal that the monitor doesn’t support and in the (extremely unlikely) worst case, damage the monitor hardware.
aplattner It’s sound strange cause on windows all works normally. I think that it’s GPU’s BIOS (zogis brand) that someone “forget include linux” on support, but let’s see
Tries and more tries, the same issue I’ve got on fedora… without xorg.conf 1024, with it, 640… so I tried kubuntu. At this moment, I’m on 1360x768. I’ve used gtf and xrandr to create parameters to 10-monitor.conf.
At this moment, my /etc/X11/xorg.conf.d/10-monitor.conf has these contents
Identifier     "Screen0"
    Device         "DVI-I-0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    Modes          "1680x1050_60.00" "1440x900_60.00" "1280x1024_60.00" "1024x768_60.00"
    EndSubSection
EndSection
About ignore EDID, well, I’ve not found this option, however thought about this, 'cause on CLI isn’t shown all options…
At this moment, I’ll back to arch linux (reinstalling all) 'cause kubuntu sounds so strange to me.
but, I repeat that on windows it works at all, including 1440x1050 (with new driver), so, I think that not all problem are located on EDID, but I’ll try evenmore
To try help us, this is the bug report from kubuntu. I don’t know if it helps… but, here goes
And, by the way, excuse my english. I’m brazilian, and about eight years I don’t review my speaking/writting, and I don’t believe in google translator
nvidia-bug-report.sh Version: 14583860
Date: Qui Set 5 00:38:51 BRT 2013
uname: Linux ilkyest 3.8.0-19-generic #30-Ubuntu SMP Wed May 1 16:35:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 20 2013-04-19 06:03:59.000000000 -0300 /etc/issue
Ubuntu 13.04 \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2012-10-28 01:43:19.000000000 -0200 /etc/debian_version
wheezy/sid
*** ls: -rw-r–r-- 1 root root 1014 2013-09-04 22:20:52.357720097 -0300 /var/log/nvidia-installer.log
creation time: Wed Sep 4 22:20:40 2013
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
./nvidia-installer
-> Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
-> done.
-> The distribution-provided pre-install script failed! Continue installation anyway? (Answer: Yes)
ERROR: Unable to find the development tool cc in your path; please make sure that you have the package ‘gcc’ installed. If gcc is installed on your system, then please check that cc is in your PATH.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
*** ls: -rw-r–r-- 1 root root 40594 2013-09-05 00:28:07.250658646 -0300 /var/log/Xorg.0.log
[ 30.875]
X.Org X Server 1.13.3
Release Date: 2013-03-07
[ 30.875] X Protocol Version 11, Revision 0
[ 30.875] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[ 30.875] Current Operating System: Linux ilkyest 3.8.0-19-generic #30-Ubuntu SMP Wed May 1 16:35:23 UTC 2013 x86_64
[ 30.875] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.8.0-19-generic root=UUID=a7fba431-fa58-48fb-b2f3-7c64dac4c9a6 ro noapic nomodeset locale=pt_BR quiet splash
[ 30.875] Build Date: 17 April 2013 10:43:13PM
[ 30.875] xorg-server 2:1.13.3-0ubuntu6 (For technical support please see http://www.ubuntu.com/support)
[ 30.875] Current version of pixman: 0.28.2
[ 30.875] Before reporting problems, check http://wiki.x.org
[ 30.875] Markers: (–) probed, () from config file, (==) default setting,
[ 30.875] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Sep 5 00:27:26 2013
[ 30.886] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 30.886] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 30.893] (==) No Layout section. Using the first Screen section.
[ 30.893] (
) |–>Screen “Screen0” (0)
[ 30.893] (**) | |–>Monitor “Monitor0”
[ 30.893] (==) Automatically adding devices
[ 30.893] (==) Automatically enabling devices
[ 30.893] (==) Automatically adding GPU devices
[ 30.893] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 30.893] Entry deleted from font path.
[ 30.893] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 30.893] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 30.893] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 30.893] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 30.893] (WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
[ 30.893] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 30.893] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 30.893] (II) The server relies on udev to provide the list of input devices.
[ 30.893] (II) Loader magic: 0x7f905ec79d20
[ 30.893] (II) Module ABI versions:
[ 30.893] X.Org ANSI C Emulation: 0.4
[ 30.893] X.Org Video Driver: 13.1
[ 30.893] X.Org XInput driver : 18.0
[ 30.893] X.Org Server Extension : 7.0
[ 30.894] (–) PCI:*(0:1:0:0) 10de:11c6:0000:0000 rev 161, Mem @ 0xfd000000/16777216, 0xf0000000/134217728, 0xf8000000/33554432, I/O @ 0x0000bc00/128, BIOS @ 0x???/524288
[ 30.894] (II) Open ACPI successful (/var/run/acpid.socket)
[ 30.894] Initializing built-in extension Generic Event Extension
[ 30.894] Initializing built-in extension SHAPE
[ 30.894] Initializing built-in extension MIT-SHM
[ 30.894] Initializing built-in extension XInputExtension
[ 30.894] Initializing built-in extension XTEST
[ 30.894] Initializing built-in extension BIG-REQUESTS
[ 30.894] Initializing built-in extension SYNC
[ 30.894] Initializing built-in extension XKEYBOARD
[ 30.894] Initializing built-in extension XC-MISC
[ 30.894] Initializing built-in extension SECURITY
[ 30.894] Initializing built-in extension XINERAMA
[ 30.894] Initializing built-in extension XFIXES
[ 30.894] Initializing built-in extension RENDER
[ 30.894] Initializing built-in extension RANDR
[ 30.894] Initializing built-in extension COMPOSITE
[ 30.894] Initializing built-in extension DAMAGE
[ 30.894] Initializing built-in extension MIT-SCREEN-SAVER
[ 30.894] Initializing built-in extension DOUBLE-BUFFER
[ 30.894] Initializing built-in extension RECORD
[ 30.894] Initializing built-in extension DPMS
[ 30.894] Initializing built-in extension X-Resource
[ 30.894] Initializing built-in extension XVideo
[ 30.894] Initializing built-in extension XVideo-MotionCompensation
[ 30.894] Initializing built-in extension SELinux
[ 30.894] Initializing built-in extension XFree86-VidModeExtension
[ 30.894] Initializing built-in extension XFree86-DGA
[ 30.894] Initializing built-in extension XFree86-DRI
[ 30.894] Initializing built-in extension DRI2
[ 30.894] (II) LoadModule: “glx”
[ 30.903] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 31.677] (II) Module glx: vendor=“NVIDIA Corporation”
[ 31.677] compiled for 4.0.2, module version = 1.0.0
[ 31.677] Module class: X.Org Server Extension
[ 31.677] (II) NVIDIA GLX Module 313.30 Wed Mar 27 15:51:21 PDT 2013
[ 31.691] Loading extension GLX
[ 31.691] (==) Matched nvidia as autoconfigured driver 0
[ 31.691] (==) Matched nouveau as autoconfigured driver 1
[ 31.691] (==) Matched vesa as autoconfigured driver 2
[ 31.691] (==) Matched modesetting as autoconfigured driver 3
[ 31.691] (==) Matched fbdev as autoconfigured driver 4
[ 31.691] (==) Assigned the driver to the xf86ConfigLayout
[ 31.691] (II) LoadModule: “nvidia”
[ 31.691] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 31.722] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 31.722] compiled for 4.0.2, module version = 1.0.0
[ 31.722] Module class: X.Org Video Driver
[ 31.741] (II) LoadModule: “nouveau”
[ 31.742] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 31.752] (II) Module nouveau: vendor=“X.Org Foundation”
[ 31.752] compiled for 1.13.3, module version = 1.0.7
[ 31.752] Module class: X.Org Video Driver
[ 31.752] ABI class: X.Org Video Driver, version 13.1
[ 31.752] (II) LoadModule: “vesa”
[ 31.752] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 31.752] (II) Module vesa: vendor=“X.Org Foundation”
[ 31.752] compiled for 1.12.99.902, module version = 2.3.2
[ 31.752] ABI class: X.Org Video Driver, version 13.0
[ 31.752] (II) LoadModule: “modesetting”
[ 31.752] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 31.753] (II) Module modesetting: vendor=“X.Org Foundation”
[ 31.753] compiled for 1.13.3, module version = 0.7.0
[ 31.753] Module class: X.Org Video Driver
[ 31.753] ABI class: X.Org Video Driver, version 13.1
[ 31.753] (II) LoadModule: “fbdev”
[ 31.753] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 31.753] (II) Module fbdev: vendor=“X.Org Foundation”
[ 31.753] compiled for 1.12.99.902, module version = 0.4.3
[ 31.753] ABI class: X.Org Video Driver, version 13.0
[ 31.753] (II) NVIDIA dlloader X Driver 313.30 Wed Mar 27 15:33:21 PDT 2013
[ 31.753] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 31.768] (II) NOUVEAU driver Date: Wed Mar 27 09:50:03 2013 +0100
[ 31.768] (II) NOUVEAU driver for NVIDIA chipset families :
[ 31.768] RIVA TNT (NV04)
[ 31.768] RIVA TNT2 (NV05)
[ 31.768] GeForce 256 (NV10)
[ 31.768] GeForce 2 (NV11, NV15)
[ 31.768] GeForce 4MX (NV17, NV18)
[ 31.768] GeForce 3 (NV20)
[ 31.768] GeForce 4Ti (NV25, NV28)
[ 31.768] GeForce FX (NV3x)
[ 31.768] GeForce 6 (NV4x)
[ 31.768] GeForce 7 (G7x)
[ 31.768] GeForce 8 (G8x)
[ 31.768] GeForce GTX 200 (NVA0)
[ 31.768] GeForce GTX 400 (NVC0)
[ 31.768] (II) VESA: driver for VESA chipsets: vesa
[ 31.768] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 31.768] (II) FBDEV: driver for framebuffer: fbdev
[ 31.768] (++) using VT number 7
[ 31.769] (II) Loading sub module “wfb”
[ 31.769] (II) LoadModule: “wfb”
[ 31.778] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 31.792] (II) Module wfb: vendor=“X.Org Foundation”
[ 31.792] compiled for 1.13.3, module version = 1.0.0
[ 31.792] ABI class: X.Org ANSI C Emulation, version 0.4
[ 31.792] (II) Loading sub module “ramdac”
[ 31.792] (II) LoadModule: “ramdac”
[ 31.792] (II) Module “ramdac” already built-in
[ 31.793] (WW) Falling back to old probe method for vesa
[ 31.793] (WW) Falling back to old probe method for modesetting
[ 31.793] (EE) open /dev/dri/card0: No such file or directory
[ 31.793] (WW) Falling back to old probe method for fbdev
[ 31.793] (II) Loading sub module “fbdevhw”
[ 31.793] (II) LoadModule: “fbdevhw”
[ 31.793] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 31.793] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 31.793] compiled for 1.13.3, module version = 0.0.2
[ 31.793] ABI class: X.Org Video Driver, version 13.1
[ 31.793] (EE) open /dev/fb0: No such file or directory
[ 31.793] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 31.793] (==) NVIDIA(0): RGB weight 888
[ 31.793] (==) NVIDIA(0): Default visual is TrueColor
[ 31.793] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 31.804] (
[ 32.292] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 32.292] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 32.292] (–) NVIDIA(GPU-0):
[ 32.292] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 32.292] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 32.292] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 32.292] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 32.292] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 32.292] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 32.292] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 32.292] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 32.292] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 32.292] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 32.293] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti (GK106) at PCI:1:0:0 (GPU-0)
[ 32.293] (–) NVIDIA(0): Memory: 1048576 kBytes
[ 32.293] (–) NVIDIA(0): VideoBIOS: 80.06.21.00.14
[ 32.293] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 32.296] (–) NVIDIA(0): Valid display device(s) on GeForce GTX 650 Ti at PCI:1:0:0
[ 32.296] (–) NVIDIA(0): CRT-0 (connected)
[ 32.296] (–) NVIDIA(0): DFP-0
[ 32.296] (–) NVIDIA(0): DFP-1
[ 32.296] (–) NVIDIA(0): DFP-2
[ 32.296] (–) NVIDIA(0): CRT-0: 480.0 MHz maximum pixel clock
[ 32.296] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 32.296] (–) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 32.296] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 32.296] (–) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 32.296] (–) NVIDIA(0): DFP-2: 330.0 MHz maximum pixel clock
[ 32.296] (–) NVIDIA(0): DFP-2: Internal Single Link TMDS
[ 32.296] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 32.296] (
[ 32.296] () NVIDIA(0): all display devices.)
[ 32.298] (WW) NVIDIA(0): No valid modes for “CRT-0:1680x1050_60.00”; removing.
[ 32.298] (WW) NVIDIA(0): No valid modes for “CRT-0:1440x900_60.00”; removing.
[ 32.298] (WW) NVIDIA(0): No valid modes for “CRT-0:1280x1024_60.00”; removing.
[ 32.298] (WW) NVIDIA(0): No valid modes for “CRT-0:1024x768_60.00”; removing.
[ 32.298] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[ 32.298] (WW) NVIDIA(0): “nvidia-auto-select”.
[ 32.298] (II) NVIDIA(0): Validated MetaModes:
[ 32.298] (II) NVIDIA(0): “CRT-0:nvidia-auto-select”
[ 32.298] (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
[ 32.333] (WW) NVIDIA(0): Unable to get display device CRT-0’s EDID; cannot compute DPI
[ 32.333] (WW) NVIDIA(0): from CRT-0’s EDID.
[ 32.333] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 32.333] (II) UnloadModule: “nouveau”
[ 32.333] (II) Unloading nouveau
[ 32.333] (II) UnloadModule: “vesa”
[ 32.333] (II) Unloading vesa
[ 32.333] (II) UnloadModule: “modesetting”
[ 32.333] (II) Unloading modesetting
[ 32.333] (II) UnloadModule: “fbdev”
[ 32.333] (II) Unloading fbdev
[ 32.333] (II) UnloadSubModule: “fbdevhw”
[ 32.333] (II) Unloading fbdevhw
[ 32.333] (–) Depth 24 pixmap format is 32 bpp
[ 32.333] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 32.333] (II) NVIDIA: access.
[ 32.339] (II) NVIDIA(0): Setting mode “CRT-0:nvidia-auto-select”
[ 32.379] Loading extension NV-GLX
[ 32.400] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 32.400] (==) NVIDIA(0): Backing store disabled
[ 32.400] (==) NVIDIA(0): Silken mouse enabled
[ 32.400] (==) NVIDIA(0): DPMS enabled
[ 32.400] Loading extension NV-CONTROL
[ 32.400] Loading extension XINERAMA
[ 32.400] (II) Loading sub module “dri2”
[ 32.400] (II) LoadModule: “dri2”
[ 32.400] (II) Module “dri2” already built-in
[ 32.400] (II) NVIDIA(0): [DRI2] Setup complete
[ 32.400] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 32.400] (–) RandR disabled
[ 32.404] (II) SELinux: Disabled on system
[ 32.404] (II) Initializing extension GLX
[ 32.491] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 32.493] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 32.493] (
[ 32.493] (II) LoadModule: “evdev”
[ 32.493] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 32.504] (II) Module evdev: vendor=“X.Org Foundation”
[ 32.504] compiled for 1.13.3, module version = 2.7.3
[ 32.504] Module class: X.Org XInput Driver
[ 32.504] ABI class: X.Org XInput driver, version 18.0
[ 32.504] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 32.504] () Power Button: always reports core events
[ 32.504] (
) evdev: Power Button: Device: “/dev/input/event1”
[ 32.504] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 32.504] (–) evdev: Power Button: Found keys
[ 32.504] (II) evdev: Power Button: Configuring as keyboard
[ 32.504] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 32.504] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 32.504] (
[ 32.504] () Option “xkb_model” “pc105”
[ 32.504] (
) Option “xkb_layout” “br”
[ 32.505] (II) XKB: reuse xkmfile /var/lib/xkb/server-A37B2EFB8B2398771EA3BE2A51A1034B516E3F38.xkm
[ 32.505] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 32.505] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 32.505] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 32.505] (
[ 32.505] () evdev: Power Button: Device: “/dev/input/event0”
[ 32.505] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 32.505] (–) evdev: Power Button: Found keys
[ 32.505] (II) evdev: Power Button: Configuring as keyboard
[ 32.505] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0”
[ 32.505] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 32.505] () Option “xkb_rules” “evdev”
[ 32.505] (
[ 32.505] () Option “xkb_layout” “br”
[ 32.506] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event5)
[ 32.506] (II) No input driver specified, ignoring this device.
[ 32.506] (II) This device may have been added with another device file.
[ 32.506] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[ 32.506] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event7)
[ 32.506] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[ 32.506] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event4)
[ 32.506] (
[ 32.506] (II) Using input driver ‘evdev’ for ‘PixArt USB Optical Mouse’
[ 32.506] () PixArt USB Optical Mouse: always reports core events
[ 32.506] (
) evdev: PixArt USB Optical Mouse: Device: “/dev/input/event4”
[ 32.506] (–) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[ 32.506] (–) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[ 32.506] (–) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[ 32.506] (–) evdev: PixArt USB Optical Mouse: Found relative axes
[ 32.506] (–) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[ 32.506] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[ 32.506] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[ 32.506] () evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 32.506] (
[ 32.506] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:12.0/usb4/4-5/4-5:1.0/input/input4/event4”
[ 32.506] (II) XINPUT: Adding extended input device “PixArt USB Optical Mouse” (type: MOUSE, id 8)
[ 32.506] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[ 32.506] (
[ 32.506] () PixArt USB Optical Mouse: (accel) acceleration profile 0
[ 32.506] (
[ 32.506] () PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[ 32.507] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[ 32.507] (II) No input driver specified, ignoring this device.
[ 32.507] (II) This device may have been added with another device file.
[ 32.507] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event2)
[ 32.507] (
[ 32.507] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 32.507] () SIGMACHIP USB Keyboard: always reports core events
[ 32.507] (
[ 32.507] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x16
[ 32.507] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 32.507] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 32.507] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb5/5-1/5-1:1.0/input/input2/event2”
[ 32.507] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 9)
[ 32.507] (
[ 32.507] () Option “xkb_model” “pc105”
[ 32.507] (
[ 32.507] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event3)
[ 32.507] () SIGMACHIP USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 32.507] (
[ 32.507] () evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event3”
[ 32.507] (–) evdev: SIGMACHIP USB Keyboard: Found 1 mouse buttons
[ 32.507] (–) evdev: SIGMACHIP USB Keyboard: Found scroll wheel(s)
[ 32.507] (–) evdev: SIGMACHIP USB Keyboard: Found relative axes
[ 32.507] (II) evdev: SIGMACHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 32.507] (–) evdev: SIGMACHIP USB Keyboard: Found absolute axes
[ 32.507] (II) evdev: SIGMACHIP USB Keyboard: Forcing absolute x/y axes to exist.
[ 32.507] (II) evdev: SIGMACHIP USB Keyboard: Configuring as mouse
[ 32.507] (II) evdev: SIGMACHIP USB Keyboard: Adding scrollwheel support
[ 32.507] (
[ 32.507] () evdev: SIGMACHIP USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 32.507] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:13.0/usb5/5-1/5-1:1.1/input/input3/event3”
[ 32.507] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 10)
[ 32.507] () Option “xkb_rules” “evdev”
[ 32.507] (
[ 32.507] () Option “xkb_layout” “br”
[ 32.507] (II) evdev: SIGMACHIP USB Keyboard: initialized for relative axes.
[ 32.507] (WW) evdev: SIGMACHIP USB Keyboard: ignoring absolute axes.
[ 32.507] (
[ 32.508] () SIGMACHIP USB Keyboard: (accel) acceleration profile 0
[ 32.508] (
[ 32.508] () SIGMACHIP USB Keyboard: (accel) acceleration threshold: 4
[ 45.385] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 45.385] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 45.385] (–) NVIDIA(GPU-0):
[ 45.385] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 45.385] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 45.385] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 45.385] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 45.385] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 45.385] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 45.385] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 45.385] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 45.385] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 45.385] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 45.385] (
[ 45.385] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 45.385] (
[ 45.468] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 45.468] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 45.468] (–) NVIDIA(GPU-0):
[ 45.468] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 45.468] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 45.468] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 45.468] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 45.468] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 45.468] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 45.468] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 45.468] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 45.468] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 45.468] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 45.468] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 45.468] (
[ 45.468] () NVIDIA(0): all display devices.)
[ 45.908] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 45.908] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 45.908] (–) NVIDIA(GPU-0):
[ 45.908] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 45.908] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 45.908] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 45.908] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 45.908] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 45.908] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 45.908] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 45.908] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 45.908] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 45.908] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 45.908] (
[ 45.908] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 45.908] (
[ 46.142] (II) NVIDIA(0): Setting mode “DVI-I-0: 1152x864 @1152x864 +0+0 {ViewPortIn=1152x864, ViewPortOut=1152x864+0+0}”
[ 46.227] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 46.227] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 46.227] (–) NVIDIA(GPU-0):
[ 46.227] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 46.227] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 46.227] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 46.227] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 46.227] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 46.227] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 46.227] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 46.227] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 46.227] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 46.227] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 46.227] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 46.227] (
[ 46.227] () NVIDIA(0): all display devices.)
[ 46.277] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 46.277] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 46.277] (–) NVIDIA(GPU-0):
[ 46.277] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 46.277] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 46.277] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 46.277] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 46.277] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 46.277] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 46.277] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 46.277] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 46.277] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 46.277] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 46.277] (
[ 46.277] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 46.277] (
[ 46.327] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 46.327] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 46.327] (–) NVIDIA(GPU-0):
[ 46.327] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 46.327] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 46.327] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 46.327] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 46.327] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 46.327] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 46.327] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 46.327] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 46.327] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 46.327] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 46.327] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 46.327] (
[ 46.327] () NVIDIA(0): all display devices.)
[ 46.377] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 46.377] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 46.377] (–) NVIDIA(GPU-0):
[ 46.377] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 46.377] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 46.377] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 46.377] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 46.377] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 46.377] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 46.377] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 46.377] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 46.377] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 46.377] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 46.377] (
[ 46.377] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 46.377] (
[ 71.607] (II) NVIDIA(0): Setting mode “DVI-I-0:1360x768”
[ 71.703] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 71.703] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 71.703] (–) NVIDIA(GPU-0):
[ 71.703] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 71.703] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 71.703] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 71.703] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 71.703] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 71.703] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 71.703] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 71.703] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 71.703] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 71.703] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.703] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 71.703] (
[ 71.703] () NVIDIA(0): all display devices.)
[ 71.736] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[ 71.736] (WW) NVIDIA(GPU-0): checksum for EDID version 1 is invalid.
[ 71.736] (–) NVIDIA(GPU-0):
[ 71.736] (–) NVIDIA(GPU-0): Raw EDID bytes:
[ 71.736] (–) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4c 2d ad 02 39 31 4a 57
[ 71.736] (–) NVIDIA(GPU-0): 03 12 01 03 6c 29 1b 78 2a dc 55 a3 59 48 9e 24
[ 71.736] (–) NVIDIA(GPU-0): 11 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f
[ 71.736] (–) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[ 71.736] (–) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 38 4b 1e
[ 71.736] (–) NVIDIA(GPU-0): 51 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53
[ 71.736] (–) NVIDIA(GPU-0): 79 6e 63 4d 61 73 74 65 72 0a 20 20 00 00 00 ff
[ 71.736] (–) NVIDIA(GPU-0): 00 48 39 46 51 31 30 35 37 32 35 0a 20 20 00 a2
[ 71.736] (–) NVIDIA(GPU-0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.736] (
[ 71.736] () NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 71.736] (
*** /etc/X11/xorg.conf.d/10-monitor.conf
*** ls: -rw-r–r-- 1 root root 788 2013-09-05 00:06:46.065400911 -0300 /etc/X11/xorg.conf.d/10-monitor.conf
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 313.30 (buildd@lamiak) Wed Apr 10 17:19:51 UTC 2013
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 313.30 (buildmeister@swio-display-x86-rhel47-05) Wed Mar 27 16:37:22 PDT 2013
Section “Monitor”
Identifier “Monitor0”
Modeline “1680x1050_60.00” 147.14 1680 1784 1968 2256 1050 1051 1054 1087 -HSync +Vsync
EndSection
Section “Screen”
Identifier “Screen0”
Device “DVI-I-0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
Modes “1680x1050_60.00” “1440x900_60.00” “1280x1024_60.00” “1024x768_60.00”
EndSubSection
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2013-04-17 19:45:37.000000000 -0300 /usr/share/X11/xorg.conf.d/10-evdev.conf
MatchIsPointer “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
Driver “evdev”
EndSection
MatchIsTablet “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2013-03-15 10:29:22.000000000 -0300 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-input-evdev/+bug/325581
https://bugs.freedesktop.org/show_bug.cgi?id=32882
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2013-03-15 10:29:22.000000000 -0300 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option “Emulate3Buttons” “true”
Option “EmulateWheel” “true”
Option “EmulateWheelButton” “2”
Option “XAxisMapping” “6 7”
Option “YAxisMapping” “4 5”
EndSection
*** /usr/share/X11/xorg.conf.d/50-synaptics.conf
*** ls: -rw-r–r-- 1 root root 1593 2013-01-17 09:38:34.000000000 -0200 /usr/share/X11/xorg.conf.d/50-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Identifier “touchpad catchall”
Driver “synaptics”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
  MatchDevicePath "/dev/input/event*"
EndSection
Identifier “touchpad ignore duplicates”
MatchOS “Linux”
MatchDevicePath “/dev/input/mouse*”
EndSection
This option enables the bottom right corner to be a right button on
non-synaptics clickpads.
This option is only interpreted by clickpads.
Identifier “Default clickpad buttons”
MatchDriver “synaptics”
Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
EndSection
This option disables software buttons on Apple touchpads.
Identifier “Disable clickpad buttons on Apple touchpads”
MatchProduct “Apple|bcm5974”
Option “SoftButtonAreas” “0 0 0 0 0 0 0 0”
EndSection
*** /usr/share/X11/xorg.conf.d/50-vmmouse.conf
*** ls: -rw-r–r-- 1 root root 115 2012-09-24 06:37:26.000000000 -0300 /usr/share/X11/xorg.conf.d/50-vmmouse.conf
Section “InputClass”
Identifier “vmmouse”
MatchIsPointer “on”
MatchTag “vmmouse”
Driver “vmmouse”
EndSection
*** /usr/share/X11/xorg.conf.d/50-wacom.conf
*** ls: -rw-r–r-- 1 root root 842 2013-01-18 07:18:02.000000000 -0200 /usr/share/X11/xorg.conf.d/50-wacom.conf
Identifier “Wacom class”
MatchProduct “Wacom|WACOM|Hanwang|PTK-540WL|ISD-V4”
MatchDevicePath “/dev/input/event*”
Driver “wacom”
EndSection
Identifier “Wacom serial class”
MatchProduct “Serial Wacom Tablet”
Driver “wacom”
EndSection
Identifier “Wacom serial class identifiers”
MatchProduct “WACf|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Waltop tablets
Identifier “Waltop class”
MatchProduct “WALTOP”
MatchIsTablet “on”
Driver “wacom”
EndSection
N-Trig Duosense Electromagnetic Digitizer
Identifier “Wacom N-Trig class”
MatchProduct “HID 1b96:0001|N-Trig Pen”
Driver “wacom”
Option “Button2” “3”
EndSection
*** /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2013-01-17 09:38:12.000000000 -0200 /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
Identifier “Dell Inspiron embedded buttons quirks”
MatchTag “inspiron_1011|inspiron_1012”
Driver “synaptics”
Option “JumpyCursorThreshold” “90”
EndSection
Identifier “Dell Inspiron quirks”
MatchTag “inspiron_1120”
Driver “synaptics”
Option “JumpyCursorThreshold” “250”
EndSection
Identifier “HP Mininote quirks”
MatchTag “mininote_1000”
Driver “synaptics”
Option “JumpyCursorThreshold” “20”
EndSection
Skipping ldd output (glxinfo not found)
/usr/bin/lspci -d “10de:*” -v -xxx
I/O ports at bc00
80: 10 29 00 00 02 3d 45 00 40 01 01 11 00 00 00 00
Kernel driver in use: snd_hda_intel
30: 00 00 00 00 60 00 00 00 00 00 00 00 09 02 00 00
50: 00 00 00 00 00 00 00 00 ce d6 23 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 02 00 e1 8d 2c 01
80: 00 29 00 00 02 3d 45 00 40 01 01 11 00 00 00 00
a0: 00 00 00 00 06 00 00 00 00 00 01 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
/usr/bin/lspci -d “10b5:*” -v -xxx
/usr/bin/lspci -t
-[0000:00]-±00.0
±02.0-[01]–±00.0
| -00.1
±09.0-[02]–±00.0
| -00.1
±0a.0-[03]----00.0
±11.0
±12.0
±12.2
±13.0
±13.2
±14.0
±14.3
±14.4-[04]–±07.0
| ±07.1
| -07.2
±14.5
±15.0-[05]–
±15.1-[06]----00.0
±16.0
±16.2
±18.0
±18.1
±18.2
±18.3
-18.4
/usr/bin/lspci -nn
00:00.0 Host bridge [0600]: Advanced Micro Devices [AMD] RS880 Host Bridge [1022:9601]
00:02.0 PCI bridge [0604]: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (ext gfx port 0) [1022:9603]
00:09.0 PCI bridge [0604]: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 4) [1022:9608]
00:0a.0 PCI bridge [0604]: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 5) [1022:9609]
00:11.0 SATA controller [0106]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] [1002:4391] (rev 40)
00:12.0 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller [1002:4397]
00:12.2 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller [1002:4396]
00:13.0 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller [1002:4397]
00:13.2 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller [1002:4396]
00:14.0 SMBus [0c05]: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller [1002:4385] (rev 42)
00:14.3 ISA bridge [0601]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 LPC host controller [1002:439d] (rev 40)
00:14.4 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge [1002:4384] (rev 40)
00:14.5 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI2 Controller [1002:4399]
00:15.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0) [1002:43a0]
00:15.1 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI SB700/SB800/SB900 PCI to PCI bridge (PCIE port 1) [1002:43a1]
00:16.0 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller [1002:4397]
00:16.2 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller [1002:4396]
00:18.0 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration [1022:1200]
00:18.1 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor Address Map [1022:1201]
00:18.2 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller [1022:1202]
00:18.3 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control [1022:1203]
00:18.4 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor Link Control [1022:1204]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK106 [GeForce GTX 650 Ti] [10de:11c6] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:0e0b] (rev a1)
02:00.0 FireWire (IEEE 1394) [0c00]: VIA Technologies, Inc. VT6315 Series Firewire Controller [1106:3403]
02:00.1 IDE interface [0101]: VIA Technologies, Inc. VT6415 PATA IDE Host Controller [1106:0415] (rev a0)
03:00.0 USB controller [0c03]: NEC Corporation uPD720200 USB 3.0 Host Controller [1033:0194] (rev 03)
04:07.0 Multimedia audio controller [0401]: Creative Labs SB Audigy [1102:0004] (rev 03)
04:07.1 Input device controller [0980]: Creative Labs SB Audigy Game Port [1102:7003] (rev 03)
04:07.2 FireWire (IEEE 1394) [0c00]: Creative Labs SB Audigy FireWire Port [1102:4001] (rev 01)
06:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller [10ec:8168] (rev 06)
/usr/bin/lsusb
Bus 001 Device 002: ID 03f0:3d17 Hewlett-Packard LaserJet P1005
Bus 003 Device 035: ID 05e3:070e Genesys Logic, Inc. USB 2.0 Card Reader
Bus 004 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 005 Device 002: ID 1c4f:0016 SiGma Micro
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
/usr/sbin/dmidecode
dmidecode 2.11
SMBIOS 2.5 present.
66 structures occupying 2433 bytes.
Table at 0x0009F000.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 2301
Release Date: 08/09/2012
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 8.15
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: System manufacturer
Product Name: System Product Name
Version: System Version
Serial Number: System Serial Number
UUID: 80D4001E-8C00-0035-47A6-20CF30E42AF1
Wake-up Type: Power Switch
SKU Number: To Be Filled By O.E.M.
Family: To Be Filled By O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: M4A88TD-V EVO/USB3
Version: Rev X.0x
Serial Number: MT700A009100142
Asset Ta
Where does the installer store his files? wich directories?
I think that something is mistaken with my distro, and I want compare the “stock driver” with my distro ones.
The variety of distros, and specifically arch linux that isn’t .deb, nor .rpm I think is the key
Solved…
thanks so much to aplattner
Option "IgnoreEDIDChecksum" "DVI-I-0"
Great, I’m glad it’s working for you. I don’t believe that Windows verifies the EDID checksum, so there is little incentive for monitor manufacturers to make sure that it’s actually correct.
