I’ve tried installing them through the command line and the .run file. None of them work
This is the log file for the .run installer
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Jan 20 08:50:22 2020
installer version: 390.87
PATH: /usr/local/sbin:/usr/local/bin:/usr/bin:/opt/intel/mediasdk/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Unable to load: nvidia-installer ncurses user interface
Using built-in stream user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
-> Installing NVIDIA driver version 390.87.
ERROR: The Nouveau kernel driver is currently in use by your system. This driver is incompatible with the NVIDIA driver, and must be disabled before proceeding. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /usr/lib/modprobe.d/nvidia-installer-disable-nouveau.conf, /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
