Hello all,
An attempt has been made to use Opensuse 10.3 with a NVIDIA chipset. So far, this has not been successful. The information I have is as follows:
—> uname -a
Linux simba 2.6.22.5-31-default #1 SMP 2007/09/21 22:29:00 UTC x86_64 x86_64 x86_64 GNU/Linux
Unfortunately, I have an HPa6500f. It seems as though the chipset is defined as follows: GPU/VPU: NVIDIA GeForce 7100 nForce 630i
At first, I thought the “forcedeth” driver had not been loaded, so I did the following:
simba:/ # modprobe -l | grep force
/lib/modules/2.6.22.5-31-default/kernel/drivers/input/joystick/iforce/iforce.ko
/lib/modules/2.6.22.5-31-default/kernel/drivers/net/forcedeth.ko
/lib/modules/2.6.22.5-31-default/kernel/drivers/i2c/busses/i2c-nforce2.ko
simba:/ # lsmod | grep forcedeth
forcedeth 65416 0
simba:/ # modprobe -r forcedeth
simba:/ # modprobe forcedeth msi=0 msix=0
simba:/ # /etc/init.d/network restart
Shutting down network interfaces:
Shutting down service network . . . . . . . . . . . . . done.
Setting up network interfaces:
lo
lo IP address: 127.0.0.1/8
Checking for network time protocol daemon (NTPD): doneed
Setting up service network . . . . . . . . . . . . . . done.
simba:/ # ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:22 errors:0 dropped:0 overruns:0 frame:0
TX packets:22 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1492 (1.4 Kb) TX bytes:1492 (1.4 Kb)
[b]I did “modprobe forcedeth msi=0 msix=0†and “modprobe forcedethâ€. Neither of them worked.
[/b]
I got the troubleshooting tips from here:
http://www.nvnews.net/vbulletin/show…=680i+ethernet
I also tried the following:
Place “options forcedeth msi = 0 msix=0†in /etc/modprobe.conf
Modprobe -r forcedeth
Modprobe forcedeth
This did not work either.
Again, I have an HP Pavilion a6500f. It seems as though the chipset is defined as follows:
http://h10010.www1.hp.com/wwpc/ca/en…6-3733085.html
Chipset
a6535c-b / a6528p / a6512p-b / a6552f: Intel® G33 Express Chipset
a6500f: nVidia GeForce 7100 nForce 630i
a6518f: nVIDIA nForce 430
a6534f: nVidia nForce 430 Chipset
a6502f / a6547c-b / a6530f: nVIDIA nForce 430 Chipset
I also found the following discussion:
It talks about a bug in the bios of the software
I then went to this page:
http://www.nvidia.com/Download/Find.aspx?lang=en-us
And downloaded (according to the entries):
NVIDIA-Linux-x86_64-173.14.12-pkg2.run which was created on: July 30, 2008
Could this solve the problem? I am somewhat hesitant to run this package as I don’t know whether or not it will trash the system altogether. The preference is to locate another forcedeth driver
On this page: https://bugs.launchpad.net/ubuntu/+s…ux/+bug/117411
Someone with UBUTU went to kernel 2.6.24.17.19 and found that it solved his problem but I am on Suse with a kernel version of 2.6.22.5-31. Also, his problem is with nforce 680i while mine is with 630i.
QUESTION: Would running this “.run” file mess up the system beyond repair? If this ethernet thing does not work, what other options do I have for connecting to the internet? Can I get another ethernet card or something like that?
Is there any solution to this at all?? The hope is not to use one of the PCI expansion slots for another ethernet card because this one doesn’t work …
Any help, hints or advice is appreciated :)
TIA
PS: Below, is a partial listing of what happened when typing lspci -nnvv
00:0a.0 PCI bridge [Class 0604]: nVidia Corporation Unknown device [10de:056d] (rev a1) (prog-if 01 [Subtractive decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR-
Latency: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: efb00000-efbfffff
Prefetchable memory behind bridge: efa00000-efafffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
Capabilities: [b8] Subsystem: Hewlett-Packard Company Unknown device [103c:2a64]
00:0b.0 PCI bridge [Class 0604]: nVidia Corporation Unknown device [10de:056e] (rev a1) (prog-if 00 [Normal decode])
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR-
Latency: 0, Cache Line Size: 64 bytes
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: ef900000-ef9fffff
Prefetchable memory behind bridge: 00000000ef800000-00000000ef8fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Capabilities: [40] Subsystem: nVidia Corporation Unknown device [10de:0000]
Capabilities: [48] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit+ Queue=0/1 Enable+
Address: 00000000fee0300c Data: 4149
Capabilities: [80] Express Root Port (Slot+) IRQ 0
Device: Supported: MaxPayload 256 bytes, PhantFunc 0, ExtTag+
Device: Latency L0s <64ns, L1 <1us
Device: Errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
Device: RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
Device: MaxPayload 256 bytes, MaxReadReq 512 bytes
Link: Supported Speed 2.5Gb/s, Width x16, ASPM L0s L1, Port 0
Link: Latency L0s <512ns, L1 <4us
Link: ASPM Disabled RCB 64 bytes CommClk- ExtSynch-
Link: Speed 2.5Gb/s, Width x16
Slot: AtnBtn- PwrCtrl- MRL- AtnInd- PwrInd- HotPlug- Surpise-
Slot: Number 1, PowerLimit 75.000000
Slot: Enabled AtnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq-
Slot: AttnInd Off, PwrInd On, Power-
Root: Correctable- Non-Fatal- Fatal- PME-
Capabilities: [100] Virtual Channel
00:0c.0 PCI bridge [Class 0604]: nVidia Corporation Unknown device [10de:056f] (rev a1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: ef700000-ef7fffff
Prefetchable memory behind bridge: 00000000efe00000-00000000efefffff
Address: 00000000fee0300c Data: 4151
Link: Supported Speed 2.5Gb/s, Width x1, ASPM L0s L1, Port 1
Slot: Number 2, PowerLimit 10.000000
00:0d.0 PCI bridge [Class 0604]: nVidia Corporation Unknown device [10de:056f] (rev a1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: efd00000-efdfffff
Prefetchable memory behind bridge: 00000000efc00000-00000000efcfffff
Address: 00000000fee0300c Data: 4159
Device: MaxPayload 128 bytes, MaxReadReq 512 bytes
Link: Supported Speed 2.5Gb/s, Width x1, ASPM L0s L1, Port 2
Slot: Number 3, PowerLimit 10.000000
00:0e.0 IDE interface [Class 0101]: nVidia Corporation Unknown device [10de:07f0] (rev a2) (prog-if 85 [Master SecO PriO])
Latency: 0 (750ns min, 250ns max)
Interrupt: pin A routed to IRQ 4348
Region 0: I/O ports at 09f0
Region 1: I/O ports at 0bf0
Region 2: I/O ports at 0970
Region 3: I/O ports at 0b70
Region 4: I/O ports at f700
Region 5: Memory at efff8000 (32-bit, non-prefetchable)
Capabilities: [44] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [8c] #12 [0010]
Capabilities: [b0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/3 Enable+
Address: 00000000fee0200c Data: 4169
00:0f.0 Ethernet controller [Class 0200]: nVidia Corporation Unknown device [10de:07dc] (rev a2)
Latency: 0 (250ns min, 5000ns max)
Interrupt: pin A routed to IRQ 15
Region 0: Memory at efffd000 (32-bit, non-prefetchable)
Region 1: I/O ports at f600
Region 2: Memory at efffc000 (32-bit, non-prefetchable)
Region 3: Memory at efffb000 (32-bit, non-prefetchable)
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [50] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/3 Enable-
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
