I’m running a GeForce RTX 2060 SUPER on Fedora 43 and nVidia driver 580.159.04 (the latest version in RPM Fusion repository) with nvidia_drm.fbdev=0. After upgrading kernel from 6.19.7 (the latest 6.X kernel in Fedora repository) to 7.0.4 (the first 7.X kernel in Fedora repository) and on all newer kernels I get a black screen (or rather, the monitor does not detect a signal) when switching to another virtual terminal or after exiting Xorg.
Changing to nvidia_drm.fbdev=1 makes the VTs work. But after loading nvidia_drm module VT viewport changes from native 3840x2160 to 1920x1080. And this cannot be fixed without rebuilding the kernel with CONFIG_FB_DEVICE=y. I wrote about this earlier here:
Loading nvidia_drm module changes the tty resolution
As a temporary solution, I reverted the kernel to version 6.19.7.
Is there another solution to use the driver with nvidia_drm.fbdev=0 and kernel 7.X?
