NVIDIA GLSL compiler bug: -(-c*x)/c becomes -x
A GLSL compiler bug seems to incorrectly simplify -(-c*x)/c to -x, where c is a constant and x is varying.
Using glslViewer to run the following shader on my RTX 3060 (driver 596.36) or my GTX 1070 (driver 581.80) results in a diagonal line from top-left to bottom-right, which seems incorrect. The same shader shows a line from bottom-left to top-right on my laptop with a Radeon iGPU.
#version 330
uniform vec2 u_resolution;
out vec4 fragColor;
void main() {
    // normalize, [0, 1]
    vec2 uv = gl_FragCoord.xy/u_resolution;
    // center origin, [-1, 1]
    vec2 p = 2.0*uv - 1.0;
    float c = 3.0;
    float x = p.x;
    float y = -(-c * x) / c;  // should equal x
    float plot = 1.0 - smoothstep(0.0, 0.02, abs(p.y - y));
    fragColor = vec4(uv.x, uv.y, plot, 1.0);
Using glGetProgramBinary gave back NV ARB assembly in plaintext:
!!NVfp5.0
OPTION NV_internal;
OPTION NV_bindless_texture;
PARAM c[1] = { program.local[0] };
ATTRIB fragment_position = fragment.position;
TEMP R0, R1;
TEMP T;
OUTPUT result_color0 = result.color;
RCP.F32 R0.y, c[0].y;
RCP.F32 R0.x, c[0].x;
MUL.F32 R0.xy, fragment.position, R0;
MAD.F32 R0.zw, R0.xyxy, {2, -1, 0, 0}.x, {2, -1, 0, 0}.y;
ADD.F32 R0.z, R0.w, R0;
MUL.F32.SAT R0.z, |R0|, {50, 0, 0, 0}.x;
MUL.F32 R1.x, R0.z, R0.z;
MAD.F32 R0.z, -R0, {2, 3, 0, 0}.x, {2, 3, 0, 0}.y;
MOV.F R0.w, {1, 0, 0, 0}.x;
MAD.F32 R0.z, -R1.x, R0, {1, 0, 0, 0}.x;
MOV.F result_color0, R0;
It seems like ADD.F32 R0.z, R0.w, R0; was incorrectly emitted instead of SUB.F32 R0.z, R0.w, R0;. At this point, R0 = (uv.x, uv.y, p.x, p.y) so this results in p.y + p.x instead of p.y - p.x.
Update: Also filed using the bug submission form, Bug ID 6134133. Repro project sent to NVSDKIssues@nvidia.com.
