Hi all,
Is there a good document on how to enable GPUDirect on Bluefield2 to work with Nvidia A100 GPUs?
We tried doca sdk installation in this document but we failed in section 5. Is it only for the NVIDIA converged cards? or it should work on any Bluefield2 devices as well?
Here is the error we are getting when we run
apt-get -y install cuda
Creating config file /etc/gdm3/greeter.dconf-defaults with new version
gdm.service is not active, cannot reload.
invoke-rc.d: initscript gdm3, action “reload” failed.
Setting up nvidia-settings (515.43.04-0ubuntu1) …
Setting up network-manager-gnome (1.8.24-1ubuntu3) …
Processing triggers for sgml-base (1.29.1) …
Setting up sgml-data (2.0.11) …
Setting up docbook-xml (4.5-9) …
Processing triggers for initramfs-tools (0.136ubuntu6.7) …
update-initramfs: Generating /boot/initrd.img-5.4.0-1035-bluefield
Unsupported platform on EFI system, doing nothing.
Processing triggers for dbus (1.12.16-2ubuntu2.2) …
Processing triggers for dictionaries-common (1.28.1) …
aspell-autobuildhash: processing: en [en-common].
aspell-autobuildhash: processing: en [en-variant_0].
aspell-autobuildhash: processing: en [en-variant_1].
aspell-autobuildhash: processing: en [en-variant_2].
aspell-autobuildhash: processing: en [en-w_accents-only].
aspell-autobuildhash: processing: en [en-wo_accents-only].
aspell-autobuildhash: processing: en [en_AU-variant_0].
aspell-autobuildhash: processing: en [en_AU-variant_1].
aspell-autobuildhash: processing: en [en_AU-w_accents-only].
aspell-autobuildhash: processing: en [en_AU-wo_accents-only].
aspell-autobuildhash: processing: en [en_CA-variant_0].
aspell-autobuildhash: processing: en [en_CA-variant_1].
aspell-autobuildhash: processing: en [en_CA-w_accents-only].
aspell-autobuildhash: processing: en [en_CA-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-ise-w_accents-only].
aspell-autobuildhash: processing: en [en_GB-ise-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-ize-w_accents-only].
aspell-autobuildhash: processing: en [en_GB-ize-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-variant_0].
aspell-autobuildhash: processing: en [en_GB-variant_1].
aspell-autobuildhash: processing: en [en_US-w_accents-only].
aspell-autobuildhash: processing: en [en_US-wo_accents-only].
Processing triggers for libgdk-pixbuf2.0-0:arm64 (2.40.0+dfsg-3ubuntu0.2) …
Processing triggers for rygel (0.38.3-1ubuntu1) …
Processing triggers for libc-bin (2.31-0ubuntu9.7) …
Processing triggers for systemd (245.4-4ubuntu3.16) …
Errors were encountered while processing:
nvidia-dkms-515
cuda-drivers-515
cuda-drivers
cuda-runtime-11-7
cuda-11-7
cuda
E: Sub-process /usr/bin/dpkg returned an error code (1)
