I have the following:
Problem: When I launch Matlab I get the following nasty message:
I do not know if it is leading to bad rendering of my graphics in Matlab. I do not know what is working wrong either, apart from this message.
com.jogamp.opengl.GLException: X11GLXDrawableFactory - Could not
initialize shared resources for X11GraphicsDevice[type .x11,
connection :0, unitID 0, handle 0x0, owner false,
ResourceToolkitLock[obj 0x317fa8ef, isOwner false, <342bfc4c,
33c0fc56>[count 0, qsz 0, owner ]]] at
jogamp.opengl.x11.glx.X11GLXDrawableFactory$SharedResourceImplementation.createSharedResource(X11GLXDrawableFactory.java:326)
at
jogamp.opengl.SharedResourceRunner.run(SharedResourceRunner.java:297)
at java.lang.Thread.run(Unknown Source) Caused by:
com.jogamp.opengl.GLException: glXGetConfig(0x1) failed: error code
Unknown error code 6 at
jogamp.opengl.x11.glx.X11GLXGraphicsConfiguration.glXGetConfig(X11GLXGraphicsConfiguration.java:570)
at
jogamp.opengl.x11.glx.X11GLXGraphicsConfiguration.XVisualInfo2GLCapabilities(X11GLXGraphicsConfiguration.java:500)
at
jogamp.opengl.x11.glx.X11GLXGraphicsConfigurationFactory.chooseGraphicsConfigurationXVisual(X11GLXGraphicsConfigurationFactory.java:434)
at
jogamp.opengl.x11.glx.X11GLXGraphicsConfigurationFactory.chooseGraphicsConfigurationStatic(X11GLXGraphicsConfigurationFactory.java:240)
at
jogamp.opengl.x11.glx.X11GLXDrawableFactory.createMutableSurfaceImpl(X11GLXDrawableFactory.java:524)
at
jogamp.opengl.x11.glx.X11GLXDrawableFactory.createDummySurfaceImpl(X11GLXDrawableFactory.java:535)
at
jogamp.opengl.x11.glx.X11GLXDrawableFactory$SharedResourceImplementation.createSharedResource(X11GLXDrawableFactory.java:283)
… 2 more
If I try to plot something. I get this error:
MATLAB has experienced a low-level graphics error, and may not have
drawn correctly. Read about what you can do to prevent this issue at
Resolving Low-Level Graphics Issues then restart MATLAB. To share
details of this issue with MathWorks technical support, please include
this file with your service request.
“this file” contains the following:
com.jogamp.opengl.GLException: Profile GL_DEFAULT is not available on
X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x0,
owner false, ResourceToolkitLock[obj 0x317fa8ef, isOwner false,
<342bfc4c, 33c0fc56>[count 0, qsz 0, owner ]]], but: at
com.jogamp.opengl.GLProfile.get(GLProfile.java:990) at
com.jogamp.opengl.GLProfile.getDefault(GLProfile.java:721) at
com.jogamp.opengl.GLCapabilities.(GLCapabilities.java:84) at
com.mathworks.hg.peer.JavaSceneServerPeer.getCaps(JavaSceneServerPeer.java:214)
at
com.mathworks.hg.peer.JavaSceneServerPeer.doCreateCanvas(JavaSceneServerPeer.java:925)
at
com.mathworks.hg.peer.JavaSceneServerPeer.access$500(JavaSceneServerPeer.java:54)
at
com.mathworks.hg.peer.JavaSceneServerPeer$2.run(JavaSceneServerPeer.java:890)
at java.awt.event.InvocationEvent.dispatch(Unknown Source) at
java.awt.EventQueue.dispatchEventImpl(Unknown Source) at
java.awt.EventQueue.access$200(Unknown Source) at
java.awt.EventQueue$3.run(Unknown Source) at
java.security.AccessController.doPrivileged(Native Method) at
java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown
Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown
Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at
java.awt.EventDispatchThread.run(Unknown Source)
Other symptoms:
- Crashes Matlab upon start at times and I have to do a process kill
- The plots look okay as far as I can see - tried the example plots of surf and mesh
Other data:
- The content in the file:
/usr/share/applications/matlab.desktop
is
#!/usr/bin/env xdg-open
[Desktop Entry]
Type=Application
Icon=/usr/share/icons/matlab.png
Name=MATLAB R2017a
Comment=Start MATLAB - The Language of Technical Computing
Exec=matlab -desktop
Categories=Development;
Comment=Scientific computing environment
StartupNotify=true
StartupWMClass=com-mathworks-util-PostVMInit
Terminal=false
- The suggested NVIDIA driver on the webpage was:
Version:375.66
Date:2017.5.4
System:Linux 64-bit
- Running
opengl info
on Matlab prompt gives the following output:
MATLAB has experienced a low-level graphics error, and may not have drawn correctly.Read about what you can do to prevent this issue at Resolving Low-Level Graphics Issues then restart MATLAB.To share details of this issue with MathWorks technical support,please include this file with your service request.
Version: ''
Vendor: ''
Renderer: 'None'
RendererDriverVersion: ''
RendererDriverReleaseDate: ''
MaxTextureSize: 0
Visual: ''
Software: 1
HardwareSupportLevel: 'none'
SupportsGraphicsSmoothing: 0
SupportsDepthPeelTransparency: 0
SupportsAlignVertexCenters: 0
Extensions: {}
MaxFrameBufferSize: 0
lspci | grep 'VGA'
gives me the following output:
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K2000M] (rev a1)
- I have already checked the discussion thread and many other similar ones. None have helped yet:
[1]: drivers - MATLAB com.jogamp.opengl.GLException: X11GLXDrawableFactory error - Ask Ubuntu
[2]: 361.28 crashes Matlab R2016a - Linux - NVIDIA Developer Forums
