Hi there.
I have a notebook ASUS K56C with Nvidia GeForce 635M and an integrated Intel video cards.
I am running Ubuntu 14.04 and I have Nvidia driver 331.49 version installed from the packages.
The problem is that all OpenGL apps have huge FPS which causes awful tearing and glitches.
I know it can be solved gracefully by enabling VSYNC ON, but I do not have that option available on Ubuntu in nvidia-settings app.
Moreover, I’ve been experimenting with some OpenGL tiny programs, tried to enable VSYNC by using ““glXSwapIntervalEXT(dy, drawable, 1)””. It gets invoked correctly, but has no impact on the application (i.e. I see that the FPS remains really large, say, 1200-1500 FPS or alike). I still have VSYNC disabled and, as a result, bad tearing.
as for my glxinfo output, here it is:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_float_buffer, GLX_NV_multisample_coverage, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_NV_copy_image, GLX_NV_float_buffer, GLX_NV_multisample_coverage,
GLX_NV_present_video, GLX_NV_swap_group, GLX_NV_video_capture,
GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX version: 1.4
GLX extensions:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GT 635M/PCIe/SSE2
OpenGL core profile version string: 4.3.0 NVIDIA 331.113
OpenGL core profile shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_multi_draw_indirect, GL_ARB_ES2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_geometry_shader4, GL_ARB_get_program_binary, GL_ARB_gpu_shader5,
GL_ARB_gpu_shader_fp64, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_imaging, GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior,
GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_separate_shader_objects,
GL_ARB_shader_atomic_counters, GL_ARB_shader_bit_encoding,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_texture,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range,
GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_import_sync_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_shader_objects, GL_EXT_separate_specular_color,
GL_EXT_shader_image_load_store, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KHR_debug, GL_KTX_buffer_region,
GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
GL_NV_ES1_1_compatibility, GL_NV_bindless_multi_draw_indirect,
GL_NV_blend_equation_advanced, GL_NV_blend_square, GL_NV_compute_program5,
GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
GL_NV_depth_buffer_float, GL_NV_depth_clamp, GL_NV_draw_texture,
GL_NV_explicit_multisample, GL_NV_fence, GL_NV_float_buffer,
GL_NV_fog_distance, GL_NV_fragment_program, GL_NV_fragment_program2,
GL_NV_fragment_program_option, GL_NV_framebuffer_multisample_coverage,
GL_NV_geometry_shader4, GL_NV_gpu_program4, GL_NV_gpu_program4_1,
GL_NV_gpu_program5, GL_NV_gpu_program5_mem_extended,
GL_NV_gpu_program_fp64, GL_NV_gpu_shader5, GL_NV_half_float,
GL_NV_light_max_exponent, GL_NV_multisample_coverage,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
GL_NV_register_combiners, GL_NV_register_combiners2,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
GL_NV_shader_buffer_load, GL_NV_shader_storage_buffer_object,
GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
GL_NV_texture_expand_normal, GL_NV_texture_multisample,
GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
GL_NV_texture_shader3, GL_NV_transform_feedback,
GL_NV_transform_feedback2, GL_NV_vdpau_interop, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_attrib_integer_64bit,
GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3, GL_S3_s3tc,
GL_SGIS_generate_mipmap, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SUN_slice_accum
OpenGL version string: 4.4.0 NVIDIA 331.113
OpenGL shading language version string: 4.40 NVIDIA via Cg compiler
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_debug_output,
GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture,
228 GLX Visuals
According to the oputput ““glXSwapIntervalEXT”” is available for my video card.
Could you clarify, is it possible at all to enable VSYNC ON on my notebook and if yes, why executing ““glXSwapIntervalEXT”” makes no changes? I’ll be glad to provide more details regarding my hardware and software settings.
Thank you.
