Nvidia gtx 1050 (mobile) and Ubuntu 22.04 has problems
I have a problem, but i don’t know what problem. I want someone to help me with that step by step. Here is some diagnostic command results i found trying to fix the issues.
I need GPU to train NNs. I already tried to reinstall drivers:
  1. At first a deleted all drivers with sudo apt remove --purge '^nvidia-.’ → sudo apt autoremove --purge (also i did udo apt-get purge nvidia libnvidia* linux-modules-nvidia* )
  2. Then i installed using sudo ubuntu-drivers install (without specifing version)
Idk, may be my card i dead or version of Ubuntu 22.04 is problematic. May be it is old bios, idk.
~ » nvidia-smi raph@raphtop
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
~ » nvtop 9 ↵ raph@raphtop
No GPU to monitor.
~ » raph@raphtop
~ » dpkg -l | grep -i nvidia raph@raphtop
ii libnvidia-cfg1-565:amd64 565.57.01-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-565 565.57.01-0ubuntu1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-565:amd64 565.57.01-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-565:i386 565.57.01-0ubuntu1 i386 NVIDIA libcompute package
ii libnvidia-decode-565:amd64 565.57.01-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-565:i386 565.57.01-0ubuntu1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-565:amd64 565.57.01-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-565:i386 565.57.01-0ubuntu1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-565:amd64 565.57.01-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-565:amd64 565.57.01-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-565:i386 565.57.01-0ubuntu1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-565:amd64 565.57.01-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-565:i386 565.57.01-0ubuntu1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc linux-objects-nvidia-535-6.8.0-40-generic 6.8.0-40.40~22.04.3+1 amd64 Linux kernel nvidia modules for version 6.8.0-40 (objects)
rc linux-objects-nvidia-535-6.8.0-45-generic 6.8.0-45.45~22.04.1 amd64 Linux kernel nvidia modules for version 6.8.0-45 (objects)
rc linux-objects-nvidia-535-6.8.0-47-generic 6.8.0-47.47~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.8.0-47 (objects)
rc linux-objects-nvidia-550-6.8.0-47-generic 6.8.0-47.47~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.8.0-47 (objects)
ii nvidia-compute-utils-565 565.57.01-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-dkms-565 565.57.01-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-driver-565 565.57.01-0ubuntu1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-565-565.57.01 565.57.01-0ubuntu1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-565 565.57.01-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-565 565.57.01-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-modprobe 565.57.01-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA’s Prime
ii nvidia-settings 565.57.01-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-565 565.57.01-0ubuntu1 amd64 NVIDIA driver support binaries
ii nvtop 1.2.2-1 amd64 Interactive NVIDIA GPU process monitor
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-565 565.57.01-0ubuntu1 amd64 NVIDIA binary Xorg driver
~ » raph@raphtop
~ » lspci | grep -i nvidia raph@raphtop
01:00.0 3D controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
~ » lspci raph@raphtop
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
00:15.0 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0 (rev 31)
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
00:17.0 SATA controller: Intel Corporation HM170/QM170 Chipset SATA Controller [AHCI Mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #3 (rev f1)
00:1c.3 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #4 (rev f1)
00:1c.6 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 (rev f1)
00:1f.0 ISA bridge: Intel Corporation HM175 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
00:1f.3 Audio device: Intel Corporation CM238 HD Audio Controller (rev 31)
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
02:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
~ » raph@raphtop
~ » lsmod | grep nvidia raph@raphtop
~ » lspci -v raph@raphtop
Subsystem: ASUSTeK Computer Inc. Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
Flags: bus master, fast devsel, latency 0, IOMMU group 1
Capabilities:
Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 2
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: de000000-df0fffff [size=17M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
Capabilities:
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Subsystem: ASUSTeK Computer Inc. HD Graphics 630
Flags: bus master, fast devsel, latency 0, IRQ 136, IOMMU group 0
Memory at dd000000 (64-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities:
Kernel driver in use: i915
Kernel modules: i915
Subsystem: ASUSTeK Computer Inc. Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Flags: fast devsel, IRQ 255, IOMMU group 3
Memory at df430000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities:
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
Flags: bus master, medium devsel, latency 0, IRQ 128, IOMMU group 4
Memory at df410000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family Thermal Subsystem
Flags: fast devsel, IRQ 18, IOMMU group 4
Memory at df42f000 (64-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family Serial IO I2C Controller
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 5
Memory at df42e000 (64-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family MEI Controller
Flags: bus master, fast devsel, latency 0, IRQ 134, IOMMU group 6
Memory at df42d000 (64-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation HM170/QM170 Chipset SATA Controller [AHCI Mode] (rev 31) (prog-if 01 [AHCI 1.0])
Subsystem: ASUSTeK Computer Inc. HM170/QM170 Chipset SATA Controller [AHCI Mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 126, IOMMU group 7
Memory at df428000 (32-bit, non-prefetchable) [size=8K]
Memory at df42c000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at df42b000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #3 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 8
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: df300000-df3fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities:
00:1c.3 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #4 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 9
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: df200000-df2fffff [size=1M]
Capabilities:
00:1c.6 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 10
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: df100000-df1fffff [size=1M]
Capabilities:
Subsystem: ASUSTeK Computer Inc. HM175 Chipset LPC/eSPI Controller
Flags: bus master, medium devsel, latency 0, IOMMU group 11
Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family Power Management Controller
Flags: fast devsel, IOMMU group 11
Memory at df424000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device: Intel Corporation CM238 HD Audio Controller (rev 31) (prog-if 80)
Subsystem: ASUSTeK Computer Inc. CM238 HD Audio Controller
Flags: bus master, fast devsel, latency 32, IRQ 137, IOMMU group 11
Memory at df420000 (64-bit, non-prefetchable) [size=16K]
Memory at df400000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs
Subsystem: ASUSTeK Computer Inc. 100 Series/C230 Series Chipset Family SMBus
Flags: medium devsel, IRQ 16, IOMMU group 11
Memory at df42a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
Subsystem: ASUSTeK Computer Inc. GP107M [GeForce GTX 1050 Mobile]
Flags: bus master, fast devsel, latency 0, IRQ 255, IOMMU group 2
Memory at de000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [disabled] [size=128]
Expansion ROM at df000000 [disabled] [size=512K]
Capabilities:
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Subsystem: Intel Corporation Dual Band Wireless-AC 7265
Flags: bus master, fast devsel, latency 0, IRQ 135, IOMMU group 12
Memory at df300000 (64-bit, non-prefetchable) [size=8K]
Capabilities:
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Flags: bus master, fast devsel, latency 0, IRQ 19, IOMMU group 13
I/O ports at d000 [size=256]
Memory at df204000 (64-bit, non-prefetchable) [size=4K]
Memory at df200000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: r8169
Kernel modules: r8169
Subsystem: ASUSTeK Computer Inc. RTS5229 PCI Express Card Reader
Flags: bus master, fast devsel, latency 0, IRQ 127, IOMMU group 14
Memory at df100000 (32-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
~ » raph@raphtop
Hello, I’m also having problems with my 1050ti M. I can’t install the proprietary drivers on my Solus Budgie system. Installing the 560 drivers and rebooting the system prevents me from starting up, with these errors before the grub.
Error when preparing initrd: Device Error
star_image() returned Device Error
StartImage failed : Device error
The computer shuts down and restarts with this error in a loop.
My system is unusable with proprietary drivers, so I’m forced to use Nouveau
System:
Host: laptop Kernel: 6.10.13-304.current arch: x86_64 bits: 64
Desktop: Budgie v: 10.9.2 Distro: Solus 4.6 convergence
Machine:
Type: Laptop System: ASUSTeK product: GL553VE v: 1.0
serial:
Mobo: ASUSTeK model: GL553VE v: 1.0 serial:
UEFI: American Megatrends v: GL553VE.308 date: 04/29/2019
Battery:
ID-1: BAT0 charge: 29.5 Wh (98.7%) condition: 29.9/48.2 Wh (62.1%)
CPU:
Info: quad core Intel Core i7-7700HQ [MT MCP] speed (MHz): avg: 800
min/max: 800/3800
Graphics:
Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nouveau
v: kernel
Device-3: Realtek USB2.0 HD UVC WebCam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.4 driver:
gpu: i915 resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.2.6
renderer: Mesa Intel HD Graphics 630 (KBL GT2)
Network:
Device-1: Intel Wireless 7265 driver: iwlwifi
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
Drives:
Local Storage: total: 1.36 TiB used: 7.32 GiB (0.5%)
Info:
Memory: total: 8 GiB available: 7.64 GiB used: 1.27 GiB (16.6%)
Processes: 241 Uptime: 21m Shell: Bash inxi: 3.3.36
Ping me if you found the answer
