Everything is installed correctly, the monitor/TV set that is connected is detected as a ‘HD Ready’ device with a preferred resolution of 1360 x 768 which is used. Is this the correct native resolution of the screen? Anyway, you should be able to switch to a higher resolution (1920x1080), this is listed as available. Which desktop environment are you using?
The driver is working, but the resolution is really bad !
Using my old GTX660, everything works fine, but with the GTX1050, the resolution is really bad.
My desktop is Cinnamon with Debian 9.7 and a video driver 390.87.
I don’t understand why the resolution is so bad.
But I will change the monitor and sum 4Gb RAM this weekend for doing my job.
Sorry for derailing the thread, but aren’t you supposed to use the 410.x driver with a GTX1050 GPU? Or is this a limitation caused by what driver version the non-free Debian repository is offering?
