NVIDIA iron nano super driver problem
Hello any one had a problem with the nvidia iron nano super 8 memory.
Was working with the flash SD and I install a ssd 1 T now the nano doesn’t flash, I re-install sd removed ssd and now the nano doesn’t want to work say is some problem with driver please help
Doesn’t flash anymore .. open to suggestions ???
I will like to reach some of the technical support please nano doesn’t flash asking for a driver
Also I want to buy a 1.0 T with the program install can someone please reach out to me, I feel stock, thanks
Hi @solangeart !
Hope you’re doing well.
Just a couple of quick questions to better understand your setup:
  • Which Jetson module are you using? Is it the Jetson Orin Nano?
  • Which carrier board are you working with? Is it the Jetson Orin Nano super Developer Kit?
  • What commands or tools are you using to flash the SSD? (Is it NVMe?)
Nico
Best regards
Jetson Orion nano developer kit
8 mem ram
Jet don’t doesn’t flash asking for a driver Also
It was flashing with the 32 SD card I was installing the Ssd driver.
Copy the sd to ssd
Look in the manual driver search Orion doesn’t have a driver listed, I attach the list of drivers.
The nano has a manufacturer reset?
Try flash with 1 T go, 2 types, 32 work not for long. Ssd is 1 T tegabate. It’s not flashing
Al
(attachments)
scan_1.pdf (3.58 MB)
Hello
I also want to buy a 1T ssd with the already flash nvidia sale it give me the link to get one im tired of flashing for weeks with problems…
Al
Hi @solangeart !
I’m having a bit of trouble understanding this. I am guessing you need to flash JetPack on Jetson Orin Nano mounted on devkit carrier board with NVMe? If so, can you please share the steps you are doing to flash the board with NVMe?
Best regards,
Nico
Package: nvidia-jetpack Source: 8g Nvidia-iron nano Super, jetpack (6.2.1) Version: 6.2.1
I did every step in the box, fish 1T with windows, 64 gb, 1T with all specifications by the book, over 100 flash one time and when I was installing the SSD drive fallow specifications SD crashed. I was going to clone the SD to the SSD , later I try to flash the SD no luck I did it over 100 times yes, I m not happy about it specially I fallow every video in YOUTUbe and every step by step 2 different computer MAC and windows Northing the Sd is corrupted try Rufus for fast speed and said error :(h.Something went wrong while opening /Users/as/Downloads/jetsoninstaller-0.2.0-r38.2-2025-08-22-01-33-29-arm64.iso. is not a function try Something went wrong while opening /Users/as/Downloads/sd-blob-b01.img.
Error: (0 , h.requestMetadata) is not a function. I do in the Mac and windows download fail.. HELP
I tried SK manager not luck, is any way to get the software with the program on the !T SSD M.2 I westing to much time to flash this program, I using 5 GB internet wired. I don’t know what is the problem. I change the nano it was asking for some drivers. This nano is new I have not able to flash it in to the SD OR SSD drive …
also said the file was corrupted in some flashes, try 5 different SD cards 1T, !T, 64, 264 gb. nothing
I install the ISO it this work but before open the window to enter stay _ stock in the minus for ever docent work.
AL
It is highly recommended to use a native 20.04 later Ubuntu and then install SDK Manager to flash your device.
If you currently use Windows, consider setting up a dual boot system with Ubuntu, which allows you to choose between Windows and Ubuntu each time your computer starts.
