I have a jetson xavier nx with jetpack 4.5.1 installed and nvidia isaac installed.
I have a ubuntu 20.04 system with which I am trying to deploy to my jetson and I am using docker container to do so. bazel run //apps/tutorials/ping_pong
commands works here. When i deploy the same package using isaac/sdk# ./../engine/engine/build/deploy.sh --remote_user taurus1 -p //apps/tutorials/ping_pong:ping_pong-pkg -d jetpack45 -h 192.168.0.96
command, I get the following in the terminal and it seems to be stuck at this level.
root@37723f6c7003:/home/product/isaac/sdk# ./../engine/engine/build/deploy.sh --remote_user taurus1 -p //apps/tutorials/ping_pong:ping_pong-pkg -d jetpack45 -h 192.168.0.96
Starting local Bazel server and connecting to it...
Loading:
Loading: 0 packages loaded
Analyzing: target //apps/tutorials/ping_pong:ping_pong-pkg (1 packages loaded, 0 targets configured)
Analyzing: target //apps/tutorials/ping_pong:ping_pong-pkg (73 packages loaded, 2576 targets configured)
Analyzing: target //apps/tutorials/ping_pong:ping_pong-pkg (74 packages loaded, 4672 targets configured)
I also have tried deploying it from another system with ubuntu 18.04 and it works fine.
Also deploying to the ubuntu 18.04 system from my docker container using isaac/sdk# ./../engine/engine/build/deploy.sh --remote_user panneer -p //apps/tutorials/ping_pong:ping_pong-pkg -d x86_64 -h 192.168.0.65
command also works fine.
