i ran “nvidia-smi” and it says Nvidia-smi has failed because it couldn’t communicate with the NVIDIA driver and my graphics shows llvmpipe. my nvidia bug report log file is attached.
nvidia-bug-report.log.gz (173.4 KB)
hello @cnptp - The GPUs you have in your system (GT 730) are not Omniverse capable . Omniverse requires NVIDIA RTX GPUs. In addition, the OS GPU driver you have installed does not support those cards for any use. Snippet from your logs:
Jun 20 12:41:11 teuchos kernel: [497090.335991] NVRM: The NVIDIA GeForce GT 730 GPU installed in this system is
Jun 20 12:41:11 teuchos kernel: [497090.335991] NVRM: supported through the NVIDIA 470.xx Legacy drivers. Please
Jun 20 12:41:11 teuchos kernel: [497090.335991] NVRM: visit Unix Drivers | NVIDIA for more
Jun 20 12:41:11 teuchos kernel: [497090.335991] NVRM: information. The 510.108.03 NVIDIA driver will ignore
Jun 20 12:41:11 teuchos kernel: [497090.335991] NVRM: this GPU. Continuing probe…
To use Omniverse on a Linux system you need RTX cards and the proper driver installed.
See following for Driver versions:
https://docs.omniverse.nvidia.com/platform/latest/common/technical-requirements.html#technical-requirements
