headless mode has the same effect.
I’ve tested the onboard camera and the growing latency doesn’t happen. It’s only with rtsp source.
Stumbled across both of these related threads, seems the people had the same issue, but neither proposed solution has helped. I was hopeful that delay=0 and drop-on-latency would help, but alas it did not.
Hello Everyone!
I hooked up a Dahua 4mp IP Camera to my Jetson Nano through a POE Switch and there is some serious lag on the stream; what’s worse is that the lag keeps increasing with time. At first I though it was a memory resource issue, but I checked the memory (using the jtop command) and more than a GB of memory stays free when I play the rtsp stream (on the browser). I have tried everything under the sun - the ‘sudo jetson_clocks’ command, low frame rate, low resolution - but the lag is …
Hi. I am trying to retrieve images from a network camera using RTSP which I will then perform object detection on. I have tried a number of different ways, none of which seem to work well at this stage.
To confirm that my camera (Anpvis UND950W) is OK and that the basics all see to be working, I have executed the following and it produces a nice image with no noticable lag.
$ gst-launch-1.0 rtspsrc latency=0 location=rtsp://admin:secret@192.168.2.17/media/video2 ! rtph264depay ! h264parse ! …
