Nvidia Jetson Module to/from communication with Industrial HMI in a PLC
I want to accumulate data from a HMI of a PLC on cloud or a on-premise workstation. HMI have ethernet option and I can remotely access the HMI for remote access through port forwarding (TCP/IP).
I am looking for a suitable Jetson device. As the HMI have ethernet port, I was wondering if Nvidia Jetson AGX Orin Module can serve as a gateway device to send data from the HMI to a cloud, and then send the predictions from the model running in the cloud to the HMI.
Has anyone tried this yet?
You can check below topics to see if can gain some ideas:
Jetson nano & PLC CLX 5000 for industrial applications - Jetson & Embedded Systems / Jetson Projects - NVIDIA Developer Forums
Jetson AGX Orin + ZED2 Camera + YOLO4 + Depth Data + MQTT + PLC - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
Nvidia Deepstream + QuickHMI Web-based Scada / HMI system + PLC + Xaiver NX - Jetson & Embedded Systems / Jetson Projects - NVIDIA Developer Forums
Thank you for the links.
