Hi, my goal is to refund the NVIDIA Jetson Nano B01, if possible. If not, fair play. I will still buy NVIDIA Jetson products, regardless of if this covers under the Return policy. I see my future with AI and embedded systems.
We bought 2 pcs NVIDIA Jetson Nano B01 through Amazon.com, one for myself and one for a friend to learn AI with embedded systems. The device’s No. 2 CAM0 interface plastic snapped when I tried to install the camera for the first time.
In my opinion, the device’s No. 2 CAM0 interface is too fragile. But, thankfully, the plastic still pinch the cable. So, the FPC cable do not wiggle around.
=== TL:DR, my justification that it was probably defective from the start.
I used the device No. 1 for the past few days, installing the camera on both CAM0 and CAM1 interface. And when my friend wanted to try. At first, I installed the camera on device No. 2 CAM1 interface. But because the Autofocus do not work (device No. 2 CAM1 interface register as /dev/video0 if there is no other camera). I turned off the device No. 2 and move the camera to CAM0 interface. That’s when the device No. 2’s CAM0 interface snapped.
