Nvidia Jetson Nano can’t Setup || Facing Error
Guys I’m having this error can someone help please.
Could you also share the main.py with us?
The error occurs when the script tries to enable a CSI camera.
Could you also validate if the onboard CSI camera works correctly on your Nano?
Thanks for replying. I’m using Lepton 3.5 Flir and it is connected to the Jetson using USB cable the light on camera is blinking not stable.
I ran code again and now this error came up I think the camera is working now
Main.py
import itertools
import os
import time
from concurrent.futures import ThreadPoolExecutor
from queue import Queue
from threading import Thread
import cv2
import numpy as np
from ir import IRThread
from rgb import RGBThread
from ui import make_ir_view, make_rgb_view, make_combined_view
from utils.transforms import transform_boxes
from config import (
HZ_CAP,
LOG_DIR,
SHOW_DISPLAY,
SAVE_FRAMES,
MAX_FILE_QUEUE,
IR_WIN_NAME,
IR_WIN_SIZE,
VIS_WIN_NAME,
VIS_WIN_SIZE,
X_DISPLAY_ADDR,
VIS_BBOX_COLOR,
IR_BBOX_COLOR,
FACE_DET_MODEL,
CALIBRATE,
CALIB_T,
CALIB_BOX,
CMAP_TEMP_MIN,
CMAP_TEMP_MAX,
def exit_handler():
print(“exit handler called”)
rgb_thread.stop()
ir_thread.stop()
rgb_thread.join()
ir_thread.join()
cv2.destroyAllWindows()
def setup_display(display_addr):
if os.environ.get(“DISPLAY”) is None:
os.environ[“DISPLAY”] = display_addr
elif X_DISPLAY_ADDR:
print(“INFO: Using $DISPLAY from environment, not from config”)
cv2.namedWindow(VIS_WIN_NAME)
cv2.namedWindow(IR_WIN_NAME)
cv2.moveWindow(VIS_WIN_NAME, 0, 0)  # move RGB window to upper-left corner
cv2.moveWindow(IR_WIN_NAME, IR_WIN_SIZE[0], 0)  # Align windows side by side
print((IR_WIN_SIZE[0], 0))
def get_reference_temp(arr, calib_box):
(H, W) = arr.shape
box_px = np.array([W, H, W, H]) * calib_box
box_px = np.rint(box_px).astype(np.int)
x1, y1, x2, y2 = box_px
roi = arr[y1:y2, x1:x2]
T = roi.mean()
std = np.std(roi)
return T, std
def get_bb_temps(arr, bboxes):
arr: NumPy array of temperatures in deg C
temps =
(H, W) = arr.shape
for box in bboxes:
    box_px = np.array([W, H, W, H]) * box
    roi = roi[roi > 30]  # reject regions below 30 degrees as background
    if roi.size != 0:
        Tavg = np.mean(roi)
        Tmax = np.max(roi)
        T90th = np.percentile(roi, 90)
    else:
        Tavg, Tmax, T90th = [float("nan")] * 3
    temps.append((Tavg, Tmax, T90th))
return temps
def calibration(temp_arr):
meas_temp, stddev = get_reference_temp(temp_arr, CALIB_BOX)
drift = CALIB_T - meas_temp
temp_arr += drift
# TODO: log this to a temperatures.log
print(
    f"Measured temp of the reference point: {meas_temp:.2f} +- {stddev:.2f} C"
print(f"Drift: {drift:.2f}")
if stddev > 0.5:
    print(
        f"Warning: measured high stddev={stddev:.2f} across the blackbody reference!"
return temp_arr, drift
def mainloop():
for i in itertools.count(start=0, step=1):
    time_start = time.monotonic()
    temp_arr = ir_thread.temps
    rgb_arr = rgb_thread.frame
    scores, boxes, landms = rgb_thread.get_detections()
    # only keep detections with confidence above 50%
    scores = np.array(scores)
    boxes = np.array(boxes)
    landms = np.array(landms)
    keep = scores > 0.5
    scores = scores[keep]
    boxes = boxes[keep]
    landms = landms[keep]
    boxes_ir = transform_boxes(boxes, 1.1, 1.1, 0, 0)
    if CALIBRATE:
        temp_arr, drift = calibration(temp_arr)
    temps = get_bb_temps(temp_arr, boxes_ir)
    # Render UI views
    ir_view = make_ir_view(
        temp_arr,
        scores,
        boxes_ir,
        len(scores) * [None],  # don't feed landmarks
        # TODO: revisit this when we have improved homography-based transform
        temps,
        CALIB_BOX,
        IR_WIN_SIZE,
        CMAP_TEMP_MIN,
        CMAP_TEMP_MAX,
    rgb_view = make_rgb_view(rgb_arr, scores, boxes, landms, VIS_WIN_SIZE)
    # Show rendered UI
    if SHOW_DISPLAY:
        cv2.imshow(VIS_WIN_NAME, rgb_view)
        cv2.imshow(IR_WIN_NAME, ir_view)
        key = cv2.waitKey(1) & 0xFF
        # if the `q` key was pressed in the cv2 window, we break from the loop and exit the program
        if key == ord("q"):
            break
    # Save images to filesystem
    if SAVE_FRAMES:
        if executor._work_queue.qsize() > MAX_FILE_QUEUE:
            print(
                "Error: Too many files in file queue. Not saving frames from this iteration."
        else:
            # TODO: catch writing errors due to full SD card
            # For examlple: libpng error: Write Error
            # The ret value of imwrite can be obtained from:
            # future = executor.submit(...)
            # future.result()
            # OPTIMIZE: we're saving frames with main loop frequency (up to 20Hz)
            # It would be more efficient to check if the frames changed between
            # iterations
            executor.submit(
                cv2.imwrite,
                f"{LOG_DIR}/frames/{session_id}-{i:05d}-rgb.jpg",
                rgb_view,
            executor.submit(
                cv2.imwrite,
                f"{LOG_DIR}/frames/{session_id}-{i:05d}-ir.png",
                ir_view,
    main_latency = time.monotonic() - time_start
    # Quick f-string format specifiers reference:
    # f'{value:{width}.{precision}}'
    print(
        f"INFO: Thread latencies   "
        f"Main={1000*main_latency:6.2f}ms   "
        f"RGB={rgb_thread._delay:6.2f}ms   "
        f"IR={ir_thread.latency:6.2f}ms"
    time.sleep(max(0, 1 / HZ_CAP - main_latency))
if name == “main”:
session_id = int(time.time())
# For an unique id: session_id = uuid.uuid4()
rgb_thread = RGBThread(model=FACE_DET_MODEL)
rgb_thread.start()
ir_thread = IRThread()
ir_thread.start()
if not CALIBRATE:
    CALIB_BOX = None
if SAVE_FRAMES:
    executor = ThreadPoolExecutor(max_workers=4)
if SHOW_DISPLAY:
    setup_display(X_DISPLAY_ADDR)
while rgb_thread.frame is None:
    print("Waiting for RGB frames")
    time.sleep(1)
while ir_thread.temps is None:
    print("Waiting for IR frames")
    time.sleep(1)
try:
    mainloop()
finally:
    exit_handler()
After adjusting the camera it started running but it’s giving this error back again.
The log shows some errors from nvarguscamerasrc.
However, it’s expected to use the V4L2 component for a USB camera.
This might be the reason why your input frame is empty (-215 assertion).
You can find an example to open a camera on Jetson in the below blog.
And please modify your main.py with the corresponding interface and try it again.
https://jkjung-avt.github.io/tx2-camera-with-python/
