Description
Hello
I’m using a Nvidia Jetson NX for object detection. I’m using yolov3 as algorithm for the detection. What I’m noticing is that without tensorrt, the device freezes while doing detection. I need to abort the program. With tensorRT the performance is better, but lets put this, it has a huge delay on inference. For example, a frame that happened 10 minutes ago is still not processed and it will take a lot more to be processed. The time accumulates exponentially. I’m using yolov3 608 and a webcam that is connected by IP address. To refer that while doing detections I’m writing the frame on a postgres database. I don’t think this is normal, taking into account the power mode is maximum. Is there any trick to improve the performance? I already maximized the clocks.
Thank you in advance
Environment
TensorRT Version: 8.0
GPU Type: Nvidia Jetson NX
Nvidia Driver Version:
CUDA Version: 10.2
CUDNN Version: 8.2.1
Operating System + Version: Ubuntu 18.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
