nvidia@nvidia:~$ [ 106.888427] hub 2-3:1.0: hub_ext_port_status failed (err = -110)
[ 116.968420] hub 2-3:1.0: hub_ext_port_status failed (err = -110)
[ 127.048395] hub 2-3:1.0: hub_ext_port_status failed (err = -110)
[ 137.128244] hub 2-3:1.0: hub_ext_port_status failed (err = -110)
[ 147.207779] hub 2-3:1.0: hub_ext_port_status failed (err = -110)
[ 157.287470] hub 2-3:1.0: hub_ext_port_status failed (err = -110)
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.113] I> Temperature = 29500
[0000.116] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.121] W> Skipping boost for clk: BPMP_APB
hello wangxin3924,
we would like to check this locally, could you please share your steps to reproduce the issue.
thanks
Hi wangxin3924,
