gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1’ ! nvvidconv
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. gstnvarguscamerasrc.cpp, execute:794 No cameras available
Is this issue related to the device tree, or is it something else? How can it be resolved?
Thank you!
Jan 16 16:13:36 Tegra nvargus-daemon[925]: === NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections…=== gst-launch-1.0[3474]: Connection established (FFFF7C5DB840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/modul>
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
Jan 16 16:13:36 Tegra nvargus-daemon[925]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Jan 16 16:13:36 Tegra nvargus-daemon[925]: NvPclHwGetModuleList: No module data found
Jan 16 16:13:36 Tegra nvargus-daemon[925]: NvPclHwGetModuleCalib: Error: Invalid module badge info
Jan 16 16:13:36 Tegra nvargus-daemon[925]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jan 16 16:13:36 Tegra nvargus-daemon[925]: ---- imager: No override file found. ----
Jan 16 16:13:36 Tegra nvargus-daemon[925]: (NvOdmDevice) Error NotInitialized: hDev Table not initialized (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2Lens.cpp, function initialize(), line 54)
Jan 16 16:13:36 Tegra nvargus-daemon[925]: NvPclDriverInitializeData: Unable to initialize driver v4l2_lens
Jan 16 16:13:36 Tegra nvargus-daemon[925]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_lens
Jan 16 16:13:36 Tegra nvargus-daemon[925]: NvPclStartPlatformDrivers: Failed to start module drivers
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)UYVY, framerate=(fraction)30/1’ ! nv3dsink -e
WARNING: erroneous pipeline: could not link nvarguscamerasrc0 to nv3dsink0, neither element can handle caps video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)UYVY, framerate=(fraction)30/1
syslog:
Feb 5 09:34:46 tegra nvargus-daemon[1120]: === gst-launch-1.0[2402]: CameraProvider initialized (0xffff9937e4a0)=== gst-launch-1.0[2402]: CameraProvider destroyed (0xffff9937e4a0)=== gst-launch-1.0[2402]: Connection closed (FFFFA02FB840)=== gst-launch-1.0[2402]: Connection cleaned up (FFFFA02FB840)=== gst-launch-1.0[2477]: Connection established (FFFFA02FB840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Feb 5 09:34:46 tegra nvargus-daemon[1120]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Feb 5 09:34:46 tegra nvargus-daemon[1120]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module10
Feb 5 09:34:46 tegra nvargus-daemon[1120]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module11
Feb 5 09:34:46 tegra nvargus-daemon[1120]: OFParserReadModulePosition: Unsupported module position ‘position11’; Success
Feb 5 09:34:46 tegra nvargus-daemon[1120]: OFParserListModules: failed to enumerate module 3 [/proc/device-tree/tegra-camera-platform/modules/module11]
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvCamHwHalOpen: Failure to open Camera Kernel Node
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvOdmImagerGetModuleList: Camera node not detected - No such file or directory
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvPclHwGetModuleList: WARNING: Failed to get module header
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvPclHwGetModuleList: WARNING: Failed to get module list from a valid source
Feb 5 09:34:46 tegra nvargus-daemon[1120]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Feb 5 09:34:46 tegra nvargus-daemon[1120]: ---- imager: No override file found. ----
Feb 5 09:34:46 tegra nvargus-daemon[1120]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
Feb 5 09:34:46 tegra nvargus-daemon[1120]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
Feb 5 09:34:46 tegra nvargus-daemon[1120]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvPclStartPlatformDrivers: Failed to start module drivers
Feb 5 09:34:46 tegra nvargus-daemon[1120]: NvPclDriver_V4L2_Focuser_Stub_Close: Invalid NULL input pPclDriver
Additionally, we have quite a few cameras, more than 10, so I’m not sure how to write this position
In a three-camera system: bottom, top, and center.
In a six-camera system: bottomleft, bottomright, centerleft, centerright, topleft, and topright.
There are 11 of them. Orin should be able to support 16 channels, right? What should we use for the remaining 5? Although our company currently has a maximum of 12, I don’t know what the 12th one is. When I write about other things, it always prompts:
Feb 5 14:06:41 Tegra nvargus-daemon[941]: === gst-plugin-scanner[4492]: CameraProvider initialized (0xffffa0abcdf0)=== gst-plugin-scanner[4524]: CameraProvider initialized (0xffff94000c90)=== gst-plugin-scanner[4524]: CameraProvider destroyed (0xffff94000c90)=== gst-plugin-scanner[4492]: CameraProvider destroyed (0xffffa0abcdf0)=== gst-plugin-scanner[4524]: Connection closed (FFFF9A6A9840)=== gst-plugin-scanner[4524]: Connection cleaned up (FFFF9A6A9840)=== gst-plugin-scanner[4492]: Connection closed (FFFFA5F2B840)=== gst-plugin-scanner[4492]: Connection cleaned up (FFFFA5F2B840)=== gst-launch-1.0[5292]: Connection established (FFFFA5F2B840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Feb 5 14:06:41 Tegra nvargus-daemon[941]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Feb 5 14:06:41 Tegra nvargus-daemon[941]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Feb 5 14:06:41 Tegra nvargus-daemon[941]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Feb 5 14:06:41 Tegra nvargus-daemon[941]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Feb 5 14:06:41 Tegra nvargus-daemon[941]: NvPclHwGetModuleList: No module data found
Feb 5 14:06:41 Tegra nvargus-daemon[941]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Feb 5 14:06:41 Tegra nvargus-daemon[941]: ---- imager: No override file found. ----
Feb 5 14:06:41 Tegra nvargus-daemon[941]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
Feb 5 14:06:41 Tegra nvargus-daemon[941]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
Feb 5 14:06:41 Tegra nvargus-daemon[941]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
Feb 5 14:06:41 Tegra nvargus-daemon[941]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
v4l2-ctl --all
Driver Info:
Driver name : tegra-video
Card type : vi-output, ar0234b 2-0011
Bus info : platform:tegra-capture-vi:0
Driver version : 5.15.148
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.15.148
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, ar0234b 2-0011
Function : V4L2 I/O
Pad 0x0100001c : 0: Sink
Link 0x02000021: from remote pad 0x100000f of entity ‘13e00000.host1x:nvcsi@15a00000-’ (Unknown sub-device (0002000a)): Data, Enabled
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘UYVY’ (UYVY 4:2:2)
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
