NVIDIA Jetson Orin Nano Developer Kit
Hello, I’m having this issue with the nano
So we have UEFI firmware version 36.4.3. We flashed the official JetPack 6.1 SD card image on multiple SD cards(two different brands and were all brand new). With one of the SD cards, we would at least get to the screen with the input of what language and location you are at, but after putting in our name and password, it would give this error:
Then we tried using the same company’s SD card(Sandisk) and another group used the same type of SD card with using the same software to flash(Balena Etcher), and then we got this screen:
Now we don’t know where to go from here
Based on the provided context, it appears that you are experiencing issues with flashing the Jetson Orin Nano Developer Kit with the official JetPack 6.1 SD card image. You have tried using multiple SD cards from different brands, but you are still encountering errors.
To troubleshoot this issue, let’s break down the steps you have taken so far:
  1. You have flashed the official JetPack 6.1 SD card image on multiple SD cards using Balena Etcher.
  2. With one of the SD cards, you were able to get to the screen where you input your language and location, but after entering your name and password, you received an error message.
  3. With another SD card from the same company (Sandisk), you were able to get to a different screen, but you are still unsure of how to proceed.
Based on the provided context, it seems that the issue may be related to the SD card or the flashing process. Here are a few potential solutions you can try:
  1. Verify the SD card: Make sure that the SD card is compatible with the Jetson Orin Nano Developer Kit and that it is properly formatted. You can try using a different SD card or reformatting the existing one.
  2. Check the flashing process: Ensure that you are using the correct flashing tool (Balena Etcher) and that you are following the correct flashing procedure. You can try re-flashing the SD card using the same tool and procedure.
  3. Check the UEFI firmware version: Ensure that the UEFI firmware version is compatible with the JetPack 6.1 SD card image. You can try updating the UEFI firmware to the latest version.
  4. Check the boot order: Ensure that the boot order is set correctly in the UEFI menu. You can try setting the UEFI SD Device to the top of the list.
In comparison to the provided context, it seems that the issue you are experiencing is similar to the one described in the section “Flashing to an SD Card#”. The section provides a step-by-step guide on how to flash the Jetson Orin Nano Developer Kit with an SD card image. You can try following the steps outlined in this section to see if it resolves the issue.
Additionally, you can try checking the device-tree node and the dmesg log to see if there are any error messages that can help you troubleshoot the issue.
In summary, the issue you are experiencing appears to be related to the SD card or the flashing process. You can try verifying the SD card, checking the flashing process, checking the UEFI firmware version, and checking the boot order to see if it resolves the issue. If you are still unsure of how to proceed, you can try following the steps outlined in the “Flashing to an SD Card#” section or checking the device-tree node and the dmesg log for error messages.
We recommend to set up native 20.04 later ubuntu and install sdk manager to full flash your device.
