NVIDIA jetson orin nano didin't send nack signal
I try to use NVIDIA jetson orin nano and raspberry pi to control a camera module by i2c.
When using NVIDIA jetson orin nano, i can’t see the address(when using “i2cdetect -y -r 7”), but raspberry pi can.
Then, I try to use “i2cget 7 0x33 0x00” to get the data. And I can see there are no nack and stop signal at orin nano, but raspberry pi have those signal.
Did you confirm the bus number?
What’s the BSP version?
Yes.
BSP version:35.3.1
When using “i2cset” can see the correct signal, but “i2cget” can’t.
Does raspberry pi work for that?
Yes!!
Which I2C port did you use? What’s the requested voltage level of your camera I2C? Did you probe the signal to check if that is correct?
I use bus7 (J12 pin3 and pin5).
3.3v
Yes, i saw there are no ack/nack after the camera send the data. Also there isn’t a stop signal.
Suppose the ack/nack is active by camera. Could you remove the camera module to confirm if any broadcast signal by i2c control while do the i2cdetect command.
