Nvidia jetson orin nano flash image error
7:07:49 ERROR: Flash Jetson Linux - flash: Error: Could not stat device /dev/sda - No such file or directory.
17:07:49 INFO: Flash Jetson Linux - flash: Flash failure
17:07:49 INFO: Flash Jetson Linux - flash: Cleaning up…
17:07:49 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.linkdome.sh; [error]: 84946 blocks
17:07:49 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:07:49 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition : 0.00 B ]
17:07:49 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 20m24s ]
17:07:49 ERROR: Flash Jetson Linux - flash: command terminated with error
17:07:49 SUMMARY: Flash Jetson Linux - flash: First Error: No such file or directory
Maybe you should give more information but not just these files.
Hi WayneWWW,
I tried the Orion Nano 4G development board and installed Jetpack 6.1 and 5.1.4 using the latest version of SDK Manager. 98% installation progress followed by an error. I tried the same problem on two Ubuntu 20.04 devices.
Regrads
Trying to flash to where? What device you want to flash? NVMe? USB drive?
There is an “export logs” button on sdkmanager. Please use it to share full log. Such partial copy and paste does not help.
I am using USB.
NV_L4T_FLASH_JETSON_LINUX_COMP.log (363.4 KB)
Please dump the serial console log during the flash failure.
