As shown in the screenshot, I am performing a pressure test on the orin nx in 40w mode, running the CPU and GPU to 100%, and it will automatically shut down after running for a period of time, the running time is not fixed, ranging from a few seconds to several tens of minutes. Can you help me analyze the cause?
Screenshot is the state of automatic shutdown
Moved to Jetson orin NX forum for support
Is it a shutdown issue or reboot issue?
It is a shutdown issue.
Is this a custom board or NV devkit? Shutdown issue is related to voltage and power supply. Not related for software.
It’s a custom board
Please review the design with design guide. This sounds not a pure software issue.
When there is an abnormal shutdown, the power supply shows that there is an output current with a power of about 3W. It should not be a power outage but a system crash. However, there is no record of a crash in the kernel log.
var_log.tar.gz (9.9 MB)
This is my var log.
There is no need to check system log. System crash won’t shutdown the device. It will reboot.
You could try to reproduce your issue with same module on NV devkit.
