Description
I have a Jetson and it gives me an error when I try to load a quantized neural network (made on my laptop), and the same error when I try to quantize the model on the Jetson, i.e. quantizing won’t work on my Jetson.
>>> torch.jit.load('../test')
File "<stdin>", line 1, in <module>
File "/home/adam/Desktop/ship-env/lib/python3.6/site-packages/torch/jit/_serialization.py", line 161, in load
cpp_module = torch._C.import_ir_module(cu, str(f), map_location, _extra_files)
RuntimeError: The following operation failed in the TorchScript interpreter.
Traceback of TorchScript, serialized code (most recent call last):
File "code/__torch__/torch/nn/quantized/modules/conv.py", line 35, in __setstate__
self.groups = (state)[8]
self.padding_mode = (state)[9]
_1 = (self).set_weight_bias((state)[10], (state)[11], )
~~~~~~~~~~~~~~~~~~~~~ <--- HERE
self.scale = (state)[12]
self.zero_point = (state)[13]
File "code/__torch__/torch/nn/quantized/modules/conv.py", line 56, in set_weight_bias
_12 = [_10, _11]
_13, _14, = _5
_15 = ops.quantized.conv2d_prepack(w, b, _9, _12, [_13, _14], _6)
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ <--- HERE
self._packed_params = _15
else:
Traceback of TorchScript, original code (most recent call last):
File "/home/adam/.local/lib/python3.9/site-packages/torch/nn/quantized/modules/conv.py", line 177, in __setstate__
self.groups = state[8]
self.padding_mode = state[9]
self.set_weight_bias(state[10], state[11])
self.scale = state[12]
self.zero_point = state[13]
File "/home/adam/.local/lib/python3.9/site-packages/torch/nn/quantized/modules/conv.py", line 402, in set_weight_bias
def set_weight_bias(self, w: torch.Tensor, b: Optional[torch.Tensor]) -> None:
if self.padding_mode == 'zeros':
self._packed_params = torch.ops.quantized.conv2d_prepack(
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ <--- HERE
w, b, self.stride, self.padding, self.dilation, self.groups)
else:
RuntimeError: Didn't find engine for operation quantized::conv2d_prepack NoQEngine
Environment
GPU Type: Jetson AGX
Jetpack Version: 4.4.1
Operating System + Version: Ubuntu
Python Version (if applicable): 3.6.9
PyTorch Version (if applicable): 1.9
Steps To Reproduce
model_fp = torch.load(models_dir+net_file)
model_to_quant = copy.deepcopy(model_fp)
model_to_quant.eval()
model_to_quant = quantize_fx.fuse_fx(model_to_quant)
qconfig_dict = {"": torch.quantization.get_default_qconfig('qnnpack')}
model_prepped = quantize_fx.prepare_fx(model_to_quant, qconfig_dict)
model_quantised = quantize_fx.convert_fx(model_prepped)
