NVIDIA Jetson Thor Module Schematic
I am looking for a schematic of the NVIDIA Jetson Thor module with labels of each component on the device. Where can I find a schematic outlining the module? The carrier board has a schematic with labeled components, found in the carrier board design files, however, the module data sheets and design guide does not provide this level of detail. Assistance would be appreciated, thank you!
For all HW design documents, please find them from Jetson Download Center | NVIDIA Developer
Unfortunately, I have not found any schematics for the module in the Jetson Download Center. Am I potentially missing something from one of the design guides?
This might be it
NVIDIA Jetson Thor Series Modules, Blackwell GPU + Arm® Neoverse® V3AE CPU + LPDDR5X, Data Sheet
Schematics and component locations of the Jetson Thor Module itself cannot be shared.
Note the statement about the Thermal Transfer Plate (TTP) in the Jetson Thor Series Thermal Design Guide:
The TTP is not designed to be removed by the customer. Removal of the TTP is done solely at the customer’s risk.
The block diagram provided in your link does help, thank you for your assistance! Unfortunately, this data sheet doesn’t outline the components, and NVIDIA doesn’t appear to share the schematic for the modules. Nonetheless, this assists me, thank you!
That is unfortunate to hear that the schematic and components locations of the module cannot be shared. Thank you for clarifying.
If you haven’t, take a look at jetson_thor_series_modules_designguide
The following files are attached to this design guide.
Jetson_Thor_Series_Pin_Descriptions_v1.0.nvxlsx
Jetson_Thor_Series_Schematic_Checklist_v1.1.nvxlsx
Jetson_Thor_Series_Layout_Checklist_v1.0.nvxlsx
Jetson_Thor_Series_Bringup_Checklist_v1.1.nvxlsx
edit: Then from my Windows box downloaded and renamed to *.nv.xlsx to let Excel open them.
edit2: The checklists are interesting but may not be germane. Pin_Descriptions may be useful.
