Nvidia Jetson Xavier Time is lost
Is there a way to retain the system time ? The time seems to reset every time I switches off or restart Xavier.
There is no backup battery, then you may need to consider to add the battery if you want to retain the system time.
Below is the suggestion for Xavier NX, but same concept for AGX Xavier: Coin battery to maintain clock? - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
