Dear support,
I have carried out the following test on two versions of Jetson Orin Jetpack 5.0.1 and 5.0.2 Linux 34.1.1 and 35.1.
I have used the following command:
timeout 10 gst-launch-1.0 -v videotestsrc pattern=ball ! video/x-raw,width=1280,height=720 ! nvvidconv ! nvv4l2av1enc enable-headers=1 maxperf-enable=true control-rate=variable_bitrate preset-level=1 ! filesink location=/tmp/test.5.0.2.ivf -e
orin1 ~ [124]> dpkg -l nvidia-l4t-gstreamer
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii nvidia-l4t-gstreamer 34.1.1-20220516211757 arm64 NVIDIA GST Application files
Linux orin1 5.10.65-tegra #2 SMP PREEMPT Mon Aug 31 08:00:00 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
orin2 ~> dpkg -l nvidia-l4t-gstreamer
ii nvidia-l4t-gstreamer 35.1.0-20220825113828 arm64 NVIDIA GST Application files
Linux orin2 5.10.104-tegra #2 SMP PREEMPT Mon Aug 31 08:00:00 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
When the videos are played using vlc or mpv the 5.0.1 version works as expected while the 5.0.2 version has issues around the movement of the ball:
It looks like there are errors in some of the frames. This results in errors in the video ( ball stuck or leaves junk traces )
as seen in the attached sample files.
test_5.0.2.ivf (902.2 KB)
test_5.0.1.ivf (1.1 MB)
Please advise,
