NVIDIA Logo Stretching Issue on AGX Orin EV Kit
Hello Team,
I have been working on the AGX Orin EV Kit with Jetson Linux 35.5.0 (JetPack 5.1.3). The NVIDIA logo appears stretched whenever the system boots and reboots. This issue has been observed multiple times, and it occurs even on a default JetPack installation without any customizations.
Could you please help me understand why this is happening and what might be causing it?
I have attached an image for reference.
Regards,
Parashuram
Try to change the monitor screen resolution to diff settings and check
I have changed the resolution settings, but the issue remains the same. I am using a 2K display.
Please share the log as follow:
  • /var/log/Xorg.0.log
  • The output of lsmod saved to a file: lsmod > lsmod.txt
  • The output of dmesg saved to a file: dmesg > dmesg.txt
  • ps aux | grep gdm3
Also could you try to flash to the latest version (5.1.5) to cross check?
Please find the details below.
evk@tegra-ubuntu:~$ ps aux | grep gdm3
root        1107  0.0  0.0 240156  8088 ?        Ssl  06:56   0:00 /usr/sbin/gdm3
evk         1683  0.0  0.0 164152  5788 tty2     Ssl+ 06:57   0:00 /usr/lib/gdm3/gdm-x-session --run-script env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --systemd --session=ubuntu
evk         4222  0.0  0.0   8572   676 pts/0    S+   11:20   0:00 grep --color=auto gdm3
dmesg.txt (82.5 KB)
lsmod.txt (2.8 KB)
Xorg.0.log (40.4 KB)
I have tested all JetPack 5.x versions that support the Ubuntu 20.04 root filesystem. the same logo stretch issue.
Regards,
Parashuram
Could you try JP6.x latest version (JP6.2) to cross check whether the issue exist?
JP 6.x requires an Ubuntu 22.04 host, which we do not have, and we are not planning to migrate to JP 6.x for our AGX Orin at this time. We are currently sticking with JP 5.x as we have already developed applications for this version.
Could you please help us resolve this issue within JP 5.x?
Regards,
Parashuram
We need to find the root cause about your issue, so we need you to use JP6.x to cross check.
Hello Kay,
The issue still exists. I have tried with the EV kit and custom boards with different JP5x versions. As of now, we do not have any plans to upgrade to JP6x as you suggested. If you could help us resolve this with the current JP, it would be a great help.
Regards,
Parashuram
We need you to test on JP6.2, so we can clarify the root cause and provide next suggestions.
