I am interested in creating a virtual factory model that allows for the control of fluid flow using real-time parameters, such as temperature sensor data or humidity sensor data.
Is Nvidia Modulus capable of performing fluid flow simulations based on real data? If so, could you kindly provide a suitable documentation link for accomplishing this task?
Alternatively, if Nvidia Modulus is not suitable for this purpose, is there an alternative method within ISAAC SIM that can be used to achieve the same objective?
