NVIDIA NIM /v1/chat/completions returns HTTP 500 or times out while /v1/models works
Hello NVIDIA Developer Support,
I am experiencing a problem with the NVIDIA NIM hosted inference API while integrating it into my local Electron application.
Environment
  • API endpoint: https://integrate.api.nvidia.com/v1
  • Chat endpoint: /chat/completions
  • Client: Node.js / Electron using an OpenAI-compatible SDK, plus independent tests using curl
  • Models tested include meta/llama-3.2-11b-vision-instruct and openai/gpt-oss-20b
Observed behavior
  1. GET /v1/models returns HTTP 200 and lists available model IDs.
  2. A request to meta/llama-3.1-8b-instruct returns HTTP 410, stating that the model reached end of life on August 26, 2026.
  3. A direct, non-streaming POST request to /v1/chat/completions using openai/gpt-oss-20b returned HTTP 500 in approximately 0.10 seconds, with this response:
Missing request extension: Extension of type headers::common::authorization::Authorization<headers::common::authorization::Bearer> was not found. Perhaps you forgot to add it? See axum::Extension.
  1. Requests to meta/llama-3.2-11b-vision-instruct from my application have repeatedly timed out after 60 seconds without receiving HTTP response headers.
  2. Both streaming and non-streaming requests have been tested during troubleshooting.
What I have checked
  • DNS resolution, TCP connection, and TLS handshake complete successfully.
  • The API catalogue is reachable.
  • The direct inference request was tested with curl outside the Electron application, so the HTTP 500 above is not generated by Jerry’s UI or its IPC handlers.
Questions
  1. Is there a known issue with the hosted NIM inference gateway or authorization middleware?
  2. Can you confirm which models currently support hosted inference through this endpoint?
  3. Is the HTTP 500 error above a known server-side issue, and is there a recommended workaround?
  4. Are there any account-specific permissions, quota limits, or endpoint changes I should check?
I can provide sanitized request timestamps, response headers, and additional diagnostics if needed.
Thank you for your help.
