NVIDIA® Nsight™ Compute 2024.3 is now available for download in the NVIDIA Registered Developer Program.
Updates in 2024.3.2
- Added support for kernel profiling on the Microsoft Compute Driver Model (MCDM). Requires an NVIDIA display driver version of 565 or higher.
- Fixed the calculation of peak throughput values for select pipelines on chips using the Ada GPU architecture, including the NVIDIA L20 and NVIDIA L40 data-center GPUs.
- Re-enabled the target-side data collection for the Acceleration Structure Viewer on Linux (aarch64 and aarch64 sbsa), which was disabled in 2024.3.1.
NVIDIA Nsight Compute
Resolved Issues
Updates in 2024.3.1
- Added the ability to use the ESC button to close the search popup in the views of the Source Page.
- Disabled the Acceleration Structure Viewer on Linux (aarch64 and aarch64 sbsa) as the rendering view may cause a crash of the Nsight Compute UI. The functionality will be restored in a future version.
- Added back the help documentation for command line parameters
--set
and--list-sets
. - Fixed an issue with PM Sampling on Hopper GPUs that could cause the target application to hang during profiling.
- Fixed an issue that caused CPU stack frames to not show up if stack frames could not be fully resolved.
- Fixed an issue with the heights of the tables in the Metric Details window.
- Fixed a possible crash of the Nsight Compute UI while preparing the information for the Source Page.
- Fixed an issue that caused a failure when the request to save a partial profile report is canceled.
Resolved Issues
Updates in 2024.3.0
- Added syntax highlighting support for section and rule files when open these as a new document. These documents now support edit, save (ctrl + s), text search (ctrl + f), zoom in (ctrl + mouse scroll down), zoom out (ctrl + mouse scroll up) functionalities.
- In Source Comparison document, added synchronized horizontal scrolling support across both sides for frozen columns.
- Added hyperlinks for section and rule files in the Metric Selection tool window.
- Improved Inline Table source syntax highlighting.
- The ‘Connect’ button has been renamed to ‘Start Activity’.
- The ‘Connection Dialog’ has been renamed ‘Start Activity’.
- Improved Progress Log window in Start Activity Dialog to show progress status of files being deployed to the remote host machine.
- Added file menu options to Save Filtered Results and Save Selected Results from an opened report to a new report. Also added context menu option Save Results to save the selected results from the Summary Table or Raw Table to a new report.
- Added support for exporting filtered results from an imported profile report to a new file using the -export and -import options together.
- The -kernel-id option now supports regex for specifying the context id and stream id.
NVIDIA Nsight Compute CLI
For a complete overview of all NVIDIA® Nsight™ Compute features and access to resources, please visit the main Nsight Compute Overview page.
Version 2024.3.2 Overview | New Features | Getting Started | Download | Documentation
Latest PRODUCT INFO
- Overview (download, features, platforms, requirements)
- Getting Started
- Documentation
- Downloads (as part of CUDA Toolkit)
- Downloads (outside of CUDA Toolkit)
- Revision History
- Videos
- News & Blogs
- Nsight Compute Forum
