NVIDIA® Nsight™ Compute 2026.1 with Nsight Copilot (preview) is now available
NVIDIA® Nsight™ Compute 2026.1 with Nsight Copilot (preview) is now available for download in the NVIDIA Registered Developer Program.
Updates in 2026.1.1
    Resolved Issues
    • Fixed an issue where metric colors in a timeline row could differ from those shown in the corresponding tooltip.
    • Fixed an incorrect calculation in the Roofline Analysis rule that prevented it from triggering in all expected cases.
    • Fixed an issue with the formatting of entries in the Inline Functions table.
Updates in 2026.1.0
    General
    • Added early access support for Nsight copilot!
    • Added support for CUDA 13.2.
    • The minimum supported version of macOS is now 13.0.
    • The Python Report Interface can now be installed as a standalone package from PyPI using pip install ncu-report.
    NVIDIA Nsight Compute
    • Nsight Compute now supports profiling Linux (aarch64 sbsa) targets from macOS hosts.
    • The Start Activity Dialog now support editing multi-line command line arguments.
    • Added the Report Merge Tool. It enables you to combine multiple reports into one. It is particularly useful for multi-GPU systems and scenarios when comparing and analyzing several reports individually becomes impractical.
    • Added the Clustering Window. It helps you analyze and compare multiple profiling reports by grouping similar reports together. This makes it easier to identify performance patterns and find relationships between different profiling sessions.
    • Added Register Dependencies analysis to the Source page. It helps you to identify general purpose register dependencies and occupancy issues due to live register pressure. Added Attributed Live Registers and Output Registers metric columns in the Source page views. Renamed Instructions & Scoreboards to Instructions & Dependencies.
    • The Source metrics page now shows the metric pipelines associated with each instruction.
    • Added a CUDA Graph Viewer tool window that dynamically visualizes CUDA Graphs during interactive profiling.
    • Timelines on the Details page now overlay related metrics in a single row when possible. They now also show a max bar in the background to indicate the maximum value at any zoom level. Rows can be switched between theoretical peak and collected maximum value for the Y-axis scale.
    • The Instruction Statistics section now has thread-level charts.
    • Improved alignment of rule elements on the Details page.
    • Moved the section body dropdowns to the left of the Details page section headers.
    • Renamed “Kernel Analysis” to “SASS Analysis” in Options dialog.
    • The Save As dialog now supports the .ncu-repz file extension for compressed reports.
    NVIDIA Nsight Compute CLI
    • Mandatory concurrent kernels (e.g. NCCL communication kernels) can now be profiled across processes from the same process tree using the --communicator shmem option.
    • The tool now generates a persisted log file in case of non-recoverable errors.
    • The default value of --clock-control is now boost.
    Resolved Issues
    • Fixed issues with OptiX command lists in interactive profiling mode.
    • Added occupancy as an option to --query-metrics-collection.
    • Fixed issues with the Active Clusters graph in the occupancy calculator.
    • Fixed that the inline functions table could show incorrect metrics values in some cases.
    • Fixed issues with syntax highlighting on the Souce page.
    • Improved the performance of the Source Comparison view for large SASS diffs.
    • Fixed issues with alignment of multi-pass PM sampling timelines without context switch trace.
    • Using an unknown metric in a PM sampling timeline section file is now an error.
    • Fixed issues with opcode category tooltips in the Instruction Statistics charts.
    • Fixed issues in node-level profiling of CUDA device launchable graphs.
View full release notes here
For a complete overview of all NVIDIA® Nsight™ Compute features and access to resources, please visit the main Nsight Compute Overview page.
Version 2026.1.0 Overview | New Features | Getting Started | Download | Documentation
Latest PRODUCT INFO
Hello, I tried to run the Linux x86_64 installer however no matter how I downloaded it the archive integrity verification always fails:
$ ./nsight_compute-linux-x86_64-2026.1.1.3.run
Verifying archive integrity...Error in MD5 checksums: d57ede642d60607defd4241430ee76b5 is different from 3b1e4ae2d1984dc104e10594728a9d90
Please help.
Hi, @user160090
I can download and install the package successfully. This is more like your env issue.
Can you please double check or try other packages ?
