When i try to install Jetpack 4.6.2 on Jetson TX2 from Ubuntu 16.04 host machine i am facing package download errors during installation from the SDK manager (version 1.8.0-10363).
Note: apt-get update and apt-get upgrade are successful on the host machine and internet is also working fine. I have connected an HDMI display monitor to it. Saw few answers related to these queries, so just quoting these before hand.
Not sure why the package download is failing. Please help me to fix it and flash the Jetson TX2 successfully.
When i retried the download, install; I was getting below errors:-
ERROR: CUDA Toolkit for L4T: DevZone get download url failed: HTTPError: Response code 401 (Unauthorized).
So according the solution mentioned in the below case, i followed the same steps
Then i started to see same old errors again as below,
ERROR: CUDA on Host - host: download failed
and also the below error log is seen,
ERROR:CUDA Cross Compile Package on Host - host: Download CUDA Cross Compile Package on Host failure
Installation of CUDA on host seems to be failing first
One more point to mention is that i am trying to reflash the Jetson TX2 device. It was already having JetPack 4.2.1, moved it to recovery mode and then i am trying to flash it with latest. Can i version missmatches cause any issues like this?? I hope it should not, because in the first step of flash, the older images need to be removed from target.
We found some DRIVE OS output in the log you attached.
Have you tried to install the host package for DRIVE?
12:03:05.150 - info: validating product line for target OS: Linux
12:03:05.153 - info:
12:03:05.153 - info: validating release: DRIVE OS 5.2.6 SDK
12:03:05.154 - warn: No access to devzone program id 879192
12:03:05.154 - warn: No access to release DRIVE OS 5.2.6 SDK.
We’re not sure why can see the DRIVE OS version from your log, suggest to try with a clean Ubuntu 18.04 host PC with the SDK manger to reflas your device via JetPack.
The device OS version and host PC should work on the same version.
The debian file /usr2/samingad/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2021.2.21249.deb is downloaded. But the downgrade installation is failing with below error message.
Reading package lists… Done
E: Unsupported file /usr2/samingad/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2021.2.21249.deb given on commandline
I tried installing it with gdebi installer, but it is not showing anything if click on install package.
I am wondering if the modified home directory location is part of the issue. It shouldn’t be, but in the past there were cases where non-EN-US characters in the home directory location broke something. It is unusual to have a non-“/home” directory, so perhaps it is some quirk just not seen before.
You could log a command line attempt to install and post that:
cd /usr2/samingad/Downloads/nvidia/sdkm_downloads/
sudo dpkg -i ./NVIDIA_Nsight_Graphics_L4T_Public_2021.2.21249.deb 2>&1 | tee log_nsight_install.txt
The output of the above suggested commands is as below:
/Downloads/nvidia/sdkm_downloads$ sudo dpkg -i ./NVIDIA_Nsight_Graphics_L4T_Public_2021.2.21249.deb 2>&1 | tee log_nsight_install.txt
dpkg: error: cannot access archive ‘./NVIDIA_Nsight_Graphics_L4T_Public_2021.2.21249.deb’: Permission denied
Did you use “sudo” to preface the “dpkg” command? If so, then you probably had the wrong filesystem type on the host PC during flash. If so, what do you see from: ls -l /usr/bin/sudo
Is this still an issue to support? Any result can be shared? Thanks
