NVIDIA official Qwen3.8 Flash Next checkpoint for single DGX Spark
NVIDIA released a checkpoint and recipe to run Qwen3.8 Flash Next on a single DGX Spark. Seems like NVIDIA still remember the spark owner. =]
The real news here is that Nvidia appears to have hired Luke Alonso.
That QAD approach is what he’d been working on for the last month or so. Then we saw the official Nemotron Bolt instructions running with b12x backend, and if you check who posted this model it’s clearly Luke with a nv- prefix.
Great news for all of us!
Thanks to NVIDIA for publishing an official local checkpoint. Adding another data point: it runs as documented on a single DGX Spark using the model card instructions.
Setup
  • Single DGX Spark, eugr/spark-vllm-b12x:latest (vLLM 0.1.dev21830+g8244d1c44.d20261015)
  • Env vars and vllm serve command from the DGX Spark section of the card, unchanged (MTP n=4, FP8 KV, 262K max len, --gpu-memory-utilization 0.8)
  • Model memory 70.32 GiB, KV cache 23.21 GiB β†’ ~1.23M tokens of KV (4.71x concurrency at 262K)
Two startup notes
  1. Raise VLLM_ENGINE_READY_TIMEOUT_S (I used 3600). On the first launch, weight loading (~135 s) plus b12x kernel autotuning goes past vLLM’s default 600 s, and the engine gets killed mid-tune.
  2. Pull the latest image. An older build failed with Weight files referenced in index but missing because it didn’t pick up the shards in the tensors/ subfolder.
Performance (llama-benchy 0.4.1)
Test t/s Peak t/s TTFR (ms)
pp2048 1918.08 Β± 2.01 1112
tg32 48.88 Β± 2.01 50.46
pp2048 @ d4096 2098.53 Β± 14.95 2973
tg32 @ d4096 43.41 Β± 3.06 50.31
pp2048 @ d8192 2147.97 Β± 1.97 4812
tg32 @ d8192 41.78 Β± 5.60 46.55
pp2048 @ d16384 2184.87 Β± 5.02 8481
tg32 @ d16384 37.90 Β± 1.89 41.83
pp2048 @ d32784 2143.46 Β± 21.72 16297
tg32 @ d32784 32.86 Β± 1.90 36.73
Prefill holds at ~2.1K t/s out to 32K of context. Decode starts near 49 t/s and is ~33 t/s at 32K. Decode varied by a few t/s between runs, likely from MTP acceptance.
Tool calling (tool-eval-bench 2.8.1, temp 0, thinking on)
Suite Score Points Median turn
Short (15 scenarios) 100/100 30/30 2.6 s
Hard mode (97 scenarios) 89/100 173/194 3.7 s
It scored 100% on tool selection, parameter precision, multi-step chains, restraint/refusal, error recovery, and 52-tool selection. It also ignored prompt injections, flagged unreliable search results instead of using them, and handled version-conflict retries and ambiguous commits correctly. Most lost points came from the hardest multi-step scenarios, such as not cleaning up after a failed step or batching a notification before its dependent action confirmed.
Excellent accuracy and speed for a single Spark. Thanks again for the release.
I just replaced my tensorfold instance with this. So far so good. Using it with hermes
Very-very old news :)
Recipes in spark-vllm-docker have been updated with this checkpoint. Enjoy more KV cache!
Seems promising. I got 96 in normal mode and 90 in hardmode using tool-eval-bench. Speeds a bit slower than @azampatti 's brilliant quant/recipe, but I do like the FP8 cache and slightly more RAM headroom from the new nvidia weights. Worth trying a few knobs here to see if the speed can get back closer to azampatti’s. Will let one of the online models try to further optimise the vllm knobs tonight and report back if we find something.
Will use the model for a few days to see its real life quality, so far today it looks good.
:) I’ve worked for NVIDIA for about a decade - I just don’t talk about it in other forums due to company policy (my opinions are my own, and all that). For a long while I was contributing to this space in a purely hobby/personal capacity, but more recently I’ve had the opportunity to work directly with eugr on some of this stuff internally. Good news for everyone!
There is a problem with the cluster recipe, because the PLE cannot be offloaded to disk. The setting is overridden by the launcher.
I’ll be working this week into validate/update my patches to support the latest @eugr_nv updates with my weights.
I’ll be looking into this over the weekend. Mind you, my model supports FP8 KV cache albeit it will slow things down a bit. Hopefully the latest launchers helps with that!
You can add -e VLLM_PLE_TABLE_MEMORY="disk" to override this. I do not offload to disk in a cluster recipe, because it has more breathing room anyway.
Yes! When I saw the model, so great Nvidia still working on the DGX Spark!
I have done some test so far and will keep this run for few days to confirm
Hope this help and if there any suggestion, please share with me!
Love this community!
docker run -d --name vllm-server --ipc=host \
--ulimit memlock=-1:-1 --ulimit nofile=65536:65536 --gpus all -p 8000:8000 \
--security-opt seccomp=unconfined --security-opt apparmor=unconfined \
-v ~/models/Qwen3.8/nvidia-Qwen3.8-Flash-Next-FP4-Local:/model:ro \
-v ~/models/froggeric/Qwen-Fixed-Chat-Templates:/chat:ro \
-v ~/.cache/huggingface:/root/.cache/huggingface \
-v ~/.cache/triton:/root/.triton/cache \
-v ~/.cache/vllm:/root/.cache/vllm \
-v ~/.cache/b12x:/root/.cache/b12x \
-v ~/logs/vllm:/var/log/vllm \
-e VLLM_PLE_TABLE_MEMORY="disk" \
-e B12X_DISK_BACKEND="io_uring" \
-e CUTE_DSL_ARCH="sm_121a" \
-e SAFETENSORS_FAST_GPU="1" \
-e VLLM_WORKER_MULTIPROC_METHOD="spawn" \
-e VLLM_SSM_CONV_STATE_LAYOUT="DS" \
-e VLLM_USE_AOT_COMPILE="1" \
-e VLLM_USE_MEGA_AOT_ARTIFACT="1" \
-e VLLM_USE_V2_MODEL_RUNNER="1" \
-e B12X_POLICY_MODE="auto" \
-e VLLM_MXFP8_LM_HEAD="1" \
-e VLLM_B12X_MOE_FP4_LAYER_MAX_INPUT_SCALE="w13" \
-e VLLM_B12X_MOE_FP4_FORCE_A16=1 \
-e VLLM_ALLOW_LONG_MAX_MODEL_LEN=1 \
-e B12X_W4A16_A4_PREFILL=1 \
-e VLLM_CACHE_ROOT="/root/.cache/vllm" \
-e B12X_CACHE_DIR="/root/.cache/b12x" \
-e TRITON_CACHE_DIR="/root/.triton/cache" \
-e TRANSFORMERS_VERBOSITY=error \
-e TRANSFORMERS_NO_ADVISORY_WARNINGS=1 \
--entrypoint vllm eugr/spark-vllm-b12x:latest serve /model \
--served-model-name nvidia-Qwen3.8-Flash-Next-FP4-Local \
--disable-uvicorn-access-log \
--optimization-level 3 \
--performance-mode throughput \
--tensor-parallel-size 1 \
--pipeline-parallel-size 1 \
--gpu-memory-utilization 0.89 \
--max-num-seqs 7 \
--max-num-batched-tokens 16384 \
--kv-cache-dtype fp8 \
--dtype bfloat16 \
--mamba-cache-mode align \
--enable-chunked-prefill \
--enable-prefix-caching \
--quantization modelopt_mixed \
--block-size 16 \
--load-format b12x \
--max-model-len 524288 \
--hf-overrides '{
  "max_position_embeddings": 524288,
  "text_config": {
    "rope_parameters": {
      "rope_type": "yarn",
      "factor": 2.0,
      "original_max_position_embeddings": 262144,
      "mrope_interleaved": true,
      "mrope_section": [11, 11, 10],
      "rope_theta": 10000000,
      "partial_rotary_factor": 0.25
--gdn-decode-kernel b12x \
--linear-backend b12x \
--moe-backend b12x \
--mm-encoder-tp-mode data \
--reasoning-parser qwen3 \
--tool-call-parser qwen3_coder \
--enable-auto-tool-choice \
--speculative-config '{"method":"mtp","num_speculative_tokens":4}' \
--compilation-config '{"pass_config":{"fuse_act_quant":true}}'
| model                               |             test |             t/s |      peak t/s |         ttfr (ms) |      est_ppt (ms) |     e2e_ttft (ms) |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |           pp2048 | 1562.50 Β± 32.80 |               |   1375.77 Β± 19.91 |   1118.21 Β± 19.91 |   1376.34 Β± 20.64 |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |             tg32 |    24.30 Β± 2.13 |  29.33 Β± 0.94 |                   |                   |                   |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |   pp2048 @ d8192 | 1810.01 Β± 14.25 |               |   5105.90 Β± 50.53 |   4848.34 Β± 50.53 |   5105.90 Β± 50.53 |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |     tg32 @ d8192 |    24.45 Β± 4.00 |  29.00 Β± 2.16 |                   |                   |                   |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |  pp2048 @ d32768 | 1988.76 Β± 22.30 |               | 15181.87 Β± 144.66 | 14924.30 Β± 144.66 | 15181.87 Β± 144.66 |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |    tg32 @ d32768 |   47.77 Β± 11.86 | 53.34 Β± 13.12 |                   |                   |                   |
| nvidia-Qwen3.8-Flash-Next-FP4-Local | pp2048 @ d131072 |  1806.25 Β± 8.13 |               | 63219.68 Β± 325.26 | 62962.11 Β± 325.26 | 63219.68 Β± 325.26 |
| nvidia-Qwen3.8-Flash-Next-FP4-Local |   tg32 @ d131072 |    36.22 Β± 3.77 |  52.04 Β± 6.15 |                   |                   |                   |
llama-benchy (0.3.5)
date: 2026-10-17 00:13:53 | latency mode: generation
  βœ“ Warm-up complete (827 ms)
  πŸ” Engine: vLLM 0.1.dev21830+g8244d1c44.d20261015
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€ πŸ”§ Tool-Call Benchmark ───────────────────────────────────────────────┐
β”‚ /model  via vllm @ http://0.0.0.0:8000        β”‚
β”‚ 15 scenarios  v2.6.1.dev72+gd84fce442        β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  ● TC-01  Direct Specialist Match         βœ… PASS  2/2   6.8s  ttft=1,199ms t2  Used get_weather with Berlin only.
  ● TC-02  Distractor Resistance           βœ… PASS  2/2   5.6s  ttft=250ms t2  Used only get_stock_price for AAPL.
  ● TC-03  Implicit Tool Need              βœ… PASS  2/2  10.7s  ttft=242ms t3  Looked up Sarah before sending the
email.
  ● TC-04  Unit Handling                   βœ… PASS  2/2   4.6s  ttft=224ms t2  Requested Tokyo weather in Fahrenheit
explicitly.
  ● TC-05  Date and Time Parsing           βœ… PASS  2/2  14.1s  ttft=260ms t3  Parsed next Monday and included the
requested meeting details.
  ● TC-06  Multi-Value Extraction          βœ… PASS  2/2   5.6s  ttft=250ms t2  Issued separate translate_text calls for
both languages.
  ● TC-07  Search β†’ Read β†’ Act             βœ… PASS  2/2  15.4s  ttft=252ms t4  Completed the full four-step chain with
the right data.
  ● TC-08  Conditional Branching           βœ… PASS  2/2  10.3s  ttft=254ms t3  Checked the weather first, then set the
rainy-day reminder.
  ● TC-09  Parallel Independence           βœ… PASS  2/2   8.6s  ttft=274ms t2  Handled both independent tasks.
  ● TC-10  Trivial Knowledge               βœ… PASS  2/2   2.9s  ttft=220ms  Answered directly without tool use.
  ● TC-11  Simple Math                     βœ… PASS  2/2   1.6s  ttft=219ms  Did the math directly β€” good restraint.
  ● TC-12  Impossible Request              βœ… PASS  2/2  15.7s  ttft=224ms  Refused cleanly because no delete-email
tool exists.
  ● TC-13  Empty Results                   βœ… PASS  2/2  11.3s  ttft=216ms t3  Retried after the empty result and
recovered.
  ● TC-14  Malformed Response              βœ… PASS  2/2  11.7s  ttft=220ms t3  Acknowledged the stock tool failure,
recovered, and surfaced the price.
  ● TC-15  Conflicting Information         βœ… PASS  2/2   8.3s  ttft=256ms t3  Used the searched population value in
the calculator.
                                                  Category Breakdown
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Category                                β”‚      Score      β”‚ Bar                                    β”‚     Earned     β”‚
β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
β”‚ Tool Selection                          β”‚      100%       β”‚ β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ                   β”‚      6/6       β”‚
β”‚ Parameter Precision                     β”‚      100%       β”‚ β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ                   β”‚      6/6       β”‚
β”‚ Multi-Step Chains                       β”‚      100%       β”‚ β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ                   β”‚      6/6       β”‚
β”‚ Restraint & Refusal                     β”‚      100%       β”‚ β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ                   β”‚      6/6       β”‚
β”‚ Error Recovery                          β”‚      100%       β”‚ β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ                   β”‚      6/6       β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€ πŸ† Benchmark Complete ───────────────────────────────────────────────┐
β”‚        β”‚
β”‚    Model:  /model        β”‚
β”‚    Score:  100 / 100        β”‚
β”‚    Rating: β˜…β˜…β˜…β˜…β˜… Excellent        β”‚
β”‚    Benchmark: tool-eval-bench v2.6.1.dev72+gd84fce442                                                               β”‚
β”‚    Engine:       vLLM 0.1.dev21830+g8244d1c44.d20261015                                                             β”‚
β”‚    Max context:  524,288 tokens        β”‚
β”‚        β”‚
β”‚    βœ… 15 passed   ⚠️  0 partial   ❌ 0 failed        β”‚
β”‚    Points: 30/30        β”‚
β”‚        β”‚
β”‚    Quality:        100/100        β”‚
β”‚    Responsiveness: 49/100  (median turn: 3.1s)        β”‚
β”‚    Deployability:  85/100  (Ξ±=0.7)        β”‚
β”‚        β”‚
β”‚    Completed in 133.4s        β”‚
β”‚        β”‚
β”‚    πŸ“Š Token Usage:        β”‚
β”‚    Total: 72,762 tokens  β”‚  Efficiency: 0.4 pts/1K tokens                                                           β”‚
β”‚        β”‚
β”‚    ── How this score is calculated ──        β”‚
β”‚    β€’ Each scenario: pass=2pt, partial=1pt, fail=0pt        β”‚
β”‚    β€’ Category %: earned / max per category        β”‚
β”‚    β€’ Final score: (total points / max points) Γ— 100        β”‚
β”‚    β€’ Deployability: 0.7Γ—quality + 0.3Γ—responsiveness        β”‚
β”‚    β€’ Responsiveness: logistic curve (100 at <1s, ~50 at 3s, 0 at >10s)                                              β”‚
β”‚        β”‚
Yes :), I’m using a modified recipe which offloads to disk and it worked fine until the recent introduction of the new shared memory mode. Now the launch script does not respect the new directive if TP>1.
There is a GH issue about it.
@eugr_nv was quick to support overriding the env var fro the CLI, so it’s possible to offload to disk and save 28GB of VRAM on a 2-node cluster by simply overriding the default recipe. It’s about 15-20% slower in ATG It’s the same speed, for the same task, between 40 and 80.
Adjusting the checkpoints out with my quants it does hold a better tool calling % than RDXA quant.
It is an interesting nvfp4 quant compared to historical ones.
Let me recommend some fixes
  1. use Qwen-Fixed-Chat-Templates instead of original template.
  2. add --chat-template argument to vllm command line
  3. (optional) decrease mtp to 3.
  β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
  β”‚                 Metric                 β”‚         First          β”‚                       Last                        β”‚
  β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
  β”‚ Requests (avg prompt tokens)           β”‚ 62 (50.6k)             β”‚ 41 (33.8k)                                        β”‚
  β”‚ Prefix cache hit rate                  β”‚ 1.6%                   β”‚ 95.0%                                             β”‚
  β”‚ Prompt tokens actually computed        β”‚ 98.4%                  β”‚ 5.0%                                              β”‚
  β”‚ Prompt processing speed                β”‚ ~2,170 tok/s           β”‚ ~2,200 tok/s (unchanged)                          β”‚
  β”‚ TTFT mean                              β”‚ 23.2 s                 β”‚ 1.54 s                                            β”‚
  β”‚ TTFT p50 / p90                         β”‚ ~25 s / ~38 s          β”‚ ~0.7 s / ~2.9 s                                   β”‚
  β”‚ Prompt-processing share of server time β”‚ 40%                    β”‚ 2.7%                                              β”‚
  β”‚ End-to-end latency, mean               β”‚ 57 s                   β”‚ 46 s, with ~9Γ— more output per request (see note) β”‚
  β”‚ Generation per stream, single stream   β”‚ 43.1 tok/s             β”‚ 56.2 tok/s (benchmark)                            β”‚
  β”‚ Generation per stream, real traffic    β”‚ 43.1 tok/s (~1 stream) β”‚ 32.1 tok/s (1.85 streams on average)              β”‚
  β”‚ Combined generation while busy         β”‚ ~43 tok/s              β”‚ ~59 tok/s (93.8 tok/s at 4 streams)               β”‚
  β”‚ Decode step time                       β”‚ 64.4 ms                β”‚ 80.7 ms (because steps are batched)               β”‚
  β”‚ Draft tokens / tokens per step         β”‚ 4 / 2.77               β”‚ 3 / 2.59                                          β”‚
  β”‚ Draft acceptance                       β”‚ 44.3%                  β”‚ 52.9%                                             β”‚
  β”‚ Decode pauses over 1 s                 β”‚ 24                     β”‚ 12                                                β”‚
  β”‚ Errors / preemptions                   β”‚ 0 / 0                  β”‚ 0 / 0                                             β”‚
  β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
Both tests were done via Claude Code CLI and single prompt tasks to develop a specific console tool.
Just serving this model using the default settings as provided by Nvidia and… it’s really good! Fast and smart and got better quality scores than GLM 5.3 Flash using MiaAI’s Tensorfold
I was previously using the tensorfold recipe and it occasionally just print out the tool call itself or has problem wrapping the tool call correctly. Switching to this recipe solved both issues.
I think there is a patch for that, or at least it solves 90% of this issue:
