Oh! Very nice! I want to see more!
btw… i see there is a framerate issue with this nice test render, Hammadcgi.
You can select the framerate that Omniverse Machinima renders, here:
So if you select for example 24, then in your video editing software, please interpret the video to the same. Adobe Premiere for example does not understand what is the original framerate. It must be changed manually to the same as rendered:
Now the most important part is to make the new timeline to be the same framerate. Then you do not get those little jumps in the video when camera moves around. Here it is made from the img seq in Premiere:
You can see the timeline is also 24 frames per sec.
nice
