Dear All ,
I have tried steps mentioned in document below and indeed nvenc encoder is working.
Unfortunately nvresize fails with error 400.
My current configuration is Dell-Precision-T1700 (Xeon Dual core, Quadro K620)
{ Ubuntu 14.04, 64 bit, Cuda 7.5 , NVidia SDK 5.0.1 , driver version 352.55}
[b]Error I receive is
[Parsed_nvresize_0 @ 0x180e9a0] nvresize::uninit
[libavfilter/vf_nvresize.c:412]dl_func->cu_launch_kernel(func, DIV_UP(dst_width, BLOCKX), DIV_UP(dst_height, BLOCKY), 1, BLOCKX, BLOCKY, 1, 0, NULL, args_uchar, NULL) has returned CUDA error 400
[/b]
Here is my ffmpeg command and response
ffmpeg -y -i BVE_Localize.mp4 -filter_complex
nvresize=5:s=hd1080|hd720|hd480|wvga|cif:readback=0[out0][out1][out2][out3][out4]
-map [out0] -strict -2 -vcodec nvenc_h264 -vb 5000k -acodec aac -ab 256k -f mpegts BVELocalize_hd.ts
-map [out1] -strict -2 -vcodec nvenc_h264 -vb 4000k -acodec aac -ab 128k -f mpegts BVELocalize_720p.ts
-map [out2] -strict -2 -vcodec libx264 -vb 2000k -acodec aac -ab 96k -f mpegts BVELocalize_480p.ts
-map [out3] -strict -2 -vcodec libx264 -vb 1000k -acodec aac -ab 64k -f mpegts BVELocalize_wvga.ts
-map [out4] -strict -2 -vcodec libx264 -vb 500k -acodec aac -ab 32k -f mpegts BVELocalize_cif.ts
ffmpeg version N-76688-ga01ba7f Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04)
configuration: --prefix=/home/amagi/melt/20151116 --enable-nonfree --enable-gpl --enable-version3 --enable-shared --enable-pthreads --enable-nvenc --enable-runtime-cpudetect --enable-nvresize --extra-cflags=-I…/cudautils --extra-ldflags=-L…/cudautils --disable-doc --enable-libmp3lame --enable-libx264
libavutil 55. 6.100 / 55. 6.100
libavcodec 57. 15.100 / 57. 15.100
libavformat 57. 14.100 / 57. 14.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 15.100 / 6. 15.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.101 / 2. 0.101
libpostproc 54. 0.100 / 54. 0.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘BVE_Localize.mp4’:
Metadata:
major_brand : mp42
minor_version : 18743379
compatible_brands: mp42isom
creation_time : 2015-09-07 11:49:33
Duration: 00:05:22.32, start: 0.000000, bitrate: 12541 kb/s
Stream #0:0(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 320 kb/s (default)
Metadata:
handler_name : Sound Media Handler
Stream #0:1(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv), 1920x1080 [SAR 1:1 DAR 16:9], 12217 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc (default)
Metadata:
handler_name : Video Media Handler
encoder : AVC Coding
[libx264 @ 0x1be0c40] using SAR=640/639
[libx264 @ 0x1be0c40] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 0x1be0c40] profile High, level 3.0
[libx264 @ 0x1be4220] using SAR=640/639
[libx264 @ 0x1be4220] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 0x1be4220] profile High, level 3.0
[libx264 @ 0x1be6f60] using SAR=16/11
[libx264 @ 0x1be6f60] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 0x1be6f60] profile High, level 2.0
Output #0, mpegts, to ‘BVELocalize_hd.ts’:
Metadata:
major_brand : mp42
encoder : Lavf57.14.100
Stream #0:0: Video: h264 (nvenc_h264), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=-1–1, 5000 kb/s, 25 fps, 90k tbn, 25 tbc (default)
Metadata:
encoder : Lavc57.15.100 nvenc_h264
Output #1, mpegts, to ‘BVELocalize_720p.ts’:
Metadata:
major_brand : mp42
Stream #1:0: Video: h264 (nvenc_h264), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1–1, 4000 kb/s, 25 fps, 90k tbn, 25 tbc (default)
Metadata:
Output #2, mpegts, to ‘BVELocalize_480p.ts’:
Metadata:
major_brand : mp42
Stream #2:0: Video: h264 (libx264), yuv420p, 852x480 [SAR 640:639 DAR 16:9], q=-1–1, 2000 kb/s, 25 fps, 90k tbn, 25 tbc (default)
Metadata:
encoder : Lavc57.15.100 libx264
Output #3, mpegts, to ‘BVELocalize_wvga.ts’:
Metadata:
major_brand : mp42
Stream #3:0: Video: h264 (libx264), yuv420p, 852x480 [SAR 640:639 DAR 16:9], q=-1–1, 1000 kb/s, 25 fps, 90k tbn, 25 tbc (default)
Metadata:
Output #4, mpegts, to ‘BVELocalize_cif.ts’:
Metadata:
major_brand : mp42
Stream #4:0: Video: h264 (libx264), yuv420p, 352x288 [SAR 16:11 DAR 16:9], q=-1–1, 500 kb/s, 25 fps, 90k tbn, 25 tbc (default)
Metadata:
Stream mapping:
Stream #0:1 (h264) → nvresize
nvresize:out0 → Stream #0:0 (nvenc_h264)
nvresize:out1 → Stream #1:0 (nvenc_h264)
nvresize:out2 → Stream #2:0 (libx264)
nvresize:out3 → Stream #3:0 (libx264)
nvresize:out4 → Stream #4:0 (libx264)
Press [q] to stop, [?] for help
Last message repeated 971 times
