Nvidia Orin Jetson 32GB not taking voice input when using PvRecorder
When attempting to use PvRecorder for voice recording on an Nvidia Orin Jetson 32GB, encountering a “Runtime Error: Current system is not supported”.
How to fix the issue?
Error: raise RuntimeError(“Current system is not supported.”)
Please run arecord -l and make sure the device is listed. And on AGX Orin developer kit, there is J511 audio panel header. You can connect it out to have 3.5mm audio input/output and give it a try.
The latest Jetpack version is 6.0GA(r36.3). If you use previous release, please consider upgrade to latest release.
