Nvidia orin nano GPIO Pull high/low remove
你好
我有一塊Nvidia Orin Nano 4G開發版,我有兩個IR開關裝在GPIO09與GPIO13,但是當IR開關啟動時,GPIO讀值都為0,是否是GPIO內部電阻影響?請問有辦法將上拉電阻或下拉電阻關閉嗎?
下圖是IR開關
Sorry for the late response.
hello liyongru1998,
you should have pinmux configuration update to revise the settings,
please see-also Generating the Pinmux dtsi Files for reference, thanks
您好:
請問更新 pinmux 配置是指紅色圈起來的地方,可以改pull high/pull low嗎?
hello liyongru1998,
please configure to Int PU or Int PD per your pin usage,
you may double check the created pinmux.dtsi file, and gpio.dtsi file for pin definition.
