Nvidia orin nano QSPI 燒入成功,但測試發現沒有QSPI
您好:
我們有自製的Nvidia Orin Nano 4G的板子,燒錄QSPI都正常且可以動作。
但是最近有10塊燒錄QSPI成功,但是到產線安裝測試發現Nvidia自己控制的風扇不會轉,最後發現QSPI沒有燒錄。
請問會有甚麼情況終端顯示QSPI燒錄成功,但實際卻沒有燒錄?
我是發現沒有燒錄QSPI的模組,不跳FC REC 跟 GND也可以燒錄做為沒有燒QSPI的判斷。
The question seems to be asking about the QSPI configuration for the Jetson Orin Nano 4GB module.
QSPI (Quad SPI) is a type of flash memory interface that is used on some NVIDIA Jetson modules, including the Jetson Orin Nano series.
According to the provided context, the Jetson Orin Nano 4GB module (P3767-0004) uses QSPI-NOR and USB/NVMe drive for flashing, but only supports QSPI-NOR and USB/NVMe drive via the l4t_initrd_flash.sh script.
In terms of the QSPI configuration, the context does not provide detailed information about the specific QSPI configuration for the Jetson Orin Nano 4GB module. However, it does mention that the module uses QSPI-NOR, which suggests that it uses a quad SPI interface to access the flash memory.
It’s worth noting that the Jetson Orin NX series and Jetson Orin Nano series have similar characteristics, including identical partition configurations. However, the context does not provide detailed information about the QSPI configuration for these modules.
In comparison, the Jetson AGX Orin series uses eMMC (Embedded MultiMediaCard) for flashing, which is a different type of flash memory interface.
To answer the question, it seems that the Jetson Orin Nano 4GB module uses QSPI-NOR and USB/NVMe drive for flashing, but the specific QSPI configuration is not provided in the context.
Here is a summary of the QSPI configuration for the different Jetson modules mentioned in the context:
  • Jetson Orin Nano 4GB (P3767-0004): QSPI-NOR and USB/NVMe drive
  • Jetson Orin Nano 8GB (P3767-0005): QSPI-NOR and microSD Card/USB/NVMe drive
  • Jetson AGX Orin series: eMMC
It’s worth noting that the context does not provide detailed information about the QSPI configuration for the Jetson Orin NX series.
執行sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
有成功也可以動作,但是有遇到10片成功燒錄,但是測試時發現沒有QSPI。
下圖是有成功燒錄的影像。
最後發現QSPI沒有燒錄
請問你現在是用什麼方式發現這個 “QSPI沒有燒錄”?
接板子測試,一直沒有畫面風扇也沒有轉。
發現FC REC跟GND不短接也可以進行燒錄,正常都會短接。
還是這樣是無法判斷有沒有QSPI。
請問你是要表達你們的orin nano一直都會處於recovery mode嗎?
是的。
只是剛好遇到10塊QSPI燒入成功,但是測試發現QSPI沒有燒錄,但重新再燒一次就正常。
會有甚麼情況會發生類似的問題嗎?
  1. 請問現在測試是使用NV devkit嗎?
  2. 請問你們的module是全新開封之前完全沒使用過得嗎
1.是用自製版,但有用正常地進行交換測試,可以確認自製版是可以運作的。
2.全新的尚未使用過
能先使用NV devkit確認你們有看到一樣的問題嗎?
這算是我們標準的流程, 並不是在質疑你們開發板的正確性.
好的,我先試試看
不過目前還沒有遇到一樣問題的模組。
之前沒有人回報過這個現象, 可能要請你們幫忙複製一下 謝謝
你好,我這邊剛好有留一塊燒錄成功但沒有反應的模組,裝在NV devkit測試,風扇不會轉也無法連線,模組摸起來溫溫的。
另外想確認如果模組本身沒有QSPI,FC REC跟GND不短接也可以進行燒錄嗎?
不太清楚你所謂的沒有連線的連線是什麼意思?
請問你能用UART log確認板子的狀態嗎? 風扇不會轉或是模組摸起來怎樣說實話都是不太有意義的資訊.
UART LOG我是接公版的6、8、10,Baud設定115200,但沒有資料。
我換可以正常運作的模組接也一樣。
Hi @liyongru1998
UART log不是接expansion header上面pin出
請照以下連結接線
有另外的UART debug pin
好的,謝謝。
我用正常的模組與不正常的模組進行交換測試。
正常運作的模組開機Uart會有log,不正常的模組Uart等5分鐘都沒有log。
了解. 請問這些不正常模組在Devkit上也是處於不用接jumper就能直接燒錄的的狀態嗎?
對,目前遇到這情況的模組不接都可以燒。
我還沒有試過全新的不接jumper能不能燒。
我有點不太懂你這邊的意思.
目前遇到這情況的模組不接都可以燒。
所以這些 "有問題"的module跟 “全新的” module到底是不是同樣的意思?
我之前的理解是你這邊想問的是全新的module是不是會自動進recovery mode.
