Nvidia-powerd fails to start on 4060
I find setting platform-profile actually works, although power cap won’t increase when I set profile to performance, but it do decrease to 33watts when I set profile to quiet
Nevertheless, performance doesn’t work.
Reporting the same with GU605MY. nvidia-powerd doesn’t start with the same error. Nvidia driver works on windows.
nvidia-smi changes wattage on platform profile change, but nvidia power boost doesn’t work because powerd doesn’t start.
nvidia-bug-report.log.gz (1.7 MB)
Hi @generix , sorry for ping you. I tried to strace nvidia-powerd, and find that nvidia-powerd tries to ioctl file descriptor -1
ioctl(-1, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7ffcec4782b0) = -1 EBADF (Bad file descriptor)
getpid()                                = 24215
sendto(3, "<27>Jul 17 08:54:14 nvidia-powerd[24215]: Failed to detach GPU id 256\n", 70, MSG_NOSIGNAL, NULL, 0) = 70
ioctl(-1, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x29, 0x10), 0x7ffcec478d70) = -1 EBADF (Bad file descriptor)
getpid()                                = 24215
sendto(3, "<27>Jul 17 08:54:14 nvidia-powerd[24215]: Failed to initialize Dynamic Boost\n", 77, MSG_NOSIGNAL, NULL, 0) = 77
ioctl(-1, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7ffcec478930) = -1 EBADF (Bad file descriptor)
getpid()                                = 24215
ioctl(-1, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x29, 0x10), 0x7ffcec4793f0) = -1 EBADF (Bad file descriptor)
, do you think this might indicates some issue in nvidia-powerd that can be fixed by nvidia?
Hi All,
We have a bug 4765534 filed internally for tracking purpose. We do have local repro and root caused the issue.
Fix will be incorporated in future release drivers.
Thank you, that means a lot to us.
Is it fixed in 560.35.03? If not, do you mind give us an eta?
Hi @ll525525
Yes, it is fixed in 560.35.03. You can test and share results.
Thanks in advance.
Thank you amrits, it finally works!
However, it’s not fixed on Windows driver. Idle will report about 52W on 4060.
However, it still not working under the version of 560 in my ROG RTX4060 Laptop
This is not yet fixed, ubutnu 22.04 560 nor 570 have stuck power use read:
0 NVIDIA GeForce RTX 4060 Off | 00000000:01:00.0 Off | N/A |
| 0% 42C P8 N/A / 115W
even if I use GPU those number do not change, on RTX 4060 ti it works fine
I have Gigabyte windforce 4060 8GB
