As 3ds Max user I have a HP Z640 dual Xeon, 32 Gb RAM and a NVidia Quadro K4200 4GB RAM videocard.
The last few months the K4200 produces al lot of sound. The files that I use are about 3.5 Gb off size.
When I open the file the card is silent. But when I start to edit the same file after a few minutes the
fan start to rotate at high speed. Temp. off chip 78 degrees. Fanrate see image.
Sometimes I see the message that no open CL device is detected. I use the HP Performance Advisor to
configure the correct drivers. At this moment I use driver 375.86.
What to do about the noisy fan. And the CL error message.
Best regards from me, living in The Netherlands.
Guus
3D Designer a.c.e.
