Nvidia Quadro K5200 crash due to a kernel exeption
Nvidia Quadro K5200 crash due to a kernel exeption while working.
Hello together,
on one workstation we have got a problem with Windows10 and the Nvidia Quadro K5200. When working it comes to crashes due to kernel exeption.
The workaround should be disable Deep Color.
[Assimilate Scratch]: The application may crash due to a kernel exception in the NVIDIA OpenGL driver.
If you encounter this issue, roll back the driver to version 385.90, or disable Deep Color within the application as follows:
From the startup screen choose System Settings.
  • In the System Settings Dialog, choose the Advanced tab.
  • From the list (under Graphics) select “OpenGL: Disable ‘deep color’.
  • Click the Boolean button to turn the setting on.
Our problem is, that we can not find these setting. In which startup screen can we choose these mentioned System
settings? In Windows or do the mean the Nvidia Control Pannel? We can not find it. Perhaps someone has got a screenshot for me?
Thank you very much in advance.
Best regards,
Stefan
