I bought a quadro P4000, but I can’t run it with ansys Mechanical. It seems some problem with comunication between ansys and the graphic card. i installed last version of cuda 9.2, but without results. Any ideas?! Here following the message I got from the solver:
***** ANSYS COMMAND LINE ARGUMENTS ***** BATCH MODE REQUESTED (-b) = NOLIST INPUT FILE COPY MODE (-c) = COPY DISTRIBUTED MEMORY PARALLEL REQUESTED 10 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS TOTAL OF 10 CORES REQUESTED DESIGNXPLORER REQUESTED MPI OPTION = INTELMPI INPUT FILE NAME = C:\Users\ELIA\Desktop\Nuova cartella_ProjectScratch\ScrC86B\dummy.dat OUTPUT FILE NAME = C:\Users\ELIA\Desktop\Nuova cartella_ProjectScratch\ScrC86B\solve.out START-UP FILE MODE = NOREAD STOP FILE MODE = NOREAD GPU ACCELERATOR OPTION REQUESTED 1 GPU ACCELERATOR DEVICES REQUESTED RELEASE= Release 18.0 BUILD= 18.0 UP20161219 VERSION=WINDOWS x64 CURRENT JOBNAME=file0 20:54:17 JUN 09, 2018 CP= 0.203 *** FATAL *** CP = 1.312 TIME= 20:54:18
No supported GPU devices have been detected on machine ELIAC. Only Tesla-series or Quadro K5000/K5200/K6000/M6000 GPU devices are supported. Please verify that a supported GPU device is installed on this machine or rerun without using the -acc command line option.
************************************************************************ The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible. ************************************************************************
This says that p4000 is not supported. I run also on ansys 19 and I got the same result, even if ansys declared it is a tested graphic card, as per this link:
I installed graphic drivers 397.93 version and cuda 9.2.88.1 version.
Thanks in advance
